Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
Unread 01-03-2012, 18:50
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Print into User Messages on DS
So this question is pretty simple, how do I print a message into the User Messages box on the Driver Station?
Also is there a different #include needed?
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 01-03-2012, 19:12
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Print into User Messages on DS
Check out the DriverStationLCD class. You should not need any additional includes, it should be covered by the wpilib.h include (I'm pretty sure on that, but it's been a while since I've used that particular feature).
Unread 07-03-2012, 09:18
normpear2 normpear2 is offline
Team Programming/Electrical Co-Lead
FRC #2603 (Highland FIRST Robotics Team #2603)
Rookie Year: 2011
normpear2 is an unknown quantity at this point
Send a message via AIM to normpear2 Send a message via MSN to normpear2 Send a message via Yahoo to normpear2
I will post the lines needed for printing to the Dashboard LCD when my school lets out today. (If I remember anyway...)
Unread 08-03-2012, 22:28
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Some uncompiled code:
Code:
DriverStationLCD ds = DriverStationLCD::GetInstance();
int val = 42;
ds.Printf(DriverStationLCD::kUser_Line1, "My Value is: %d", val);
ds.UpdateLCD(); // Call at the end of teleop periodic if you're doing multiple printfs.
Unread 09-03-2012, 01:52
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Code:
int val = 42;
Minor correction. GetInstance gives you a pointer. So it should be:
Code:
DriverStationLCD *ds = DriverStationLCD::GetInstance();
int val = 42;
ds->PrintfLine(DriverStationLCD::kUser_Line1, "My Value is: %d", val);
ds->UpdateLCD(); // Call at the end of teleop periodic if you're doing multiple printfs.
Unread 10-03-2012, 19:09
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Windriver => File => New => Example => VxWorks Downloadable Kernel Module Sample Project => Next => FRC Driver Station LCD Text => Finish
gives you a working example.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
