Week 1 Stats
Here are some stats for week one:
Rank based on alliance average score: 341 45.58333333 1986 39.55555556 1218 37.75 3528 37.33333333 118 35 16 35 716 33.8 1208 31.77777778 1982 30.88888889 935 30.11111111 1987 29.88888889 1477 29.55555556 3467 28.6 148 28.44444444 131 27.90909091 486 27.75 3322 27.08333333 1730 26.33333333 357 26.08333333 1997 26 1825 26 126 25.45454545 58 25.3 319 25.18181818 811 24.9 3284 24.55555556 525 24.55555556 2590 24.41666667 95 24.4 1775 24.2222 Rank based on (average alliance score / regional average score): 341 3.382968601 1986 2.935616873 1218 2.801617507 118 2.7804632 3528 2.770694577 16 2.597526166 716 2.508468126 1208 2.358388836 1477 2.347946703 1982 2.292419918 148 2.25967803 935 2.234697114 1987 2.218204884 3467 2.122549952 131 2.071274111 486 2.059467174 772 2.038277512 3322 2.009990485 234 1.990430622 1730 1.95432921 357 1.935775452 1997 1.929590866 1825 1.929590866 2393 1.90430622 126 1.889109939 58 1.877640343 319 1.868869475 2386 1.866028708 811 1.847954329 175 1.844815 Rank based on Average alliance score - Average opposing alliance score (I believe this is irrelevant but its still a way of ranking teams): 118 31.55555556 341 30.75 1218 25.41666667 1986 25.22222222 3528 23 716 21.1 148 20.77777778 1477 20.44444444 3322 18.08333333 1987 17.77777778 772 16.55555556 1208 15.22222222 16 13.77777778 1997 13.55555556 1775 13.55555556 131 13.54545455 488 13.33333333 538 13.22222222 234 13.11111111 1982 12.77777778 2393 12.77777778 862 12.58333333 2016 12.41666667 2468 12.22222222 2949 12.22222222 2386 12.11111111 935 11.88888889 1730 11.88888889 3035 11.44444444 3568 11.33333333 Regional Stats: Regional, Total Alliance Pts, Max Alliance Pts, Avg Alliance Pts KC 10950 72 19.01041667 PAH 8565 74 18.78289474 NH 9393 54 18.59927273 GG 6306 44 13.47435897 STX 7167 60 12.58783069 TN 5643 52 11.61111111 SDC 5091 40 9.01525974 |
Re: Week 1 Stats
Hatboro-Horsham had a match that was 103-0, so you need to update your stuff. Good post otherwise.
Re: Week 1 Stats
To exemplify how much teams are struggling, notice that every regional, with the exception of San Diego, has an average alliance score under 20.
If you aren't sinking in any balls, JUST GO FOR THE BRIDGES. PLEASE. |
Re: Week 1 Stats
Where is Gull Lake? I don't see any aggregate stats for MIGL, and don't see any teams from there on your lists...
http://www2.usfirst.org/2012comp/Eve...chresults.html I think he's just doing qualification rounds; otherwise, the high score at Kettering would be 80. |
Re: Week 1 Stats
Re: Week 1 Stats
Re: Week 1 Stats
For some reason the FMS was not connected to the internet so they did not upload any scores until Friday evening.
Re: Week 1 Stats
At that time, that was the least of our worries.
Re: Week 1 Stats
Do you have an aggregate average for all matches? (a histogram showing the distribution would be really cool as well) It would be interesting to compare against the predictions from this thread.
Also, I agree very much with the point about balancing. Despite the fact that most teams could not score enough points to make up for a balance, balancing seemed to be a complete afterthought in most of the matches that I watched (the matches involving 148 in the elims being a spectacular exception). |
#10
Re: Week 1 Stats
While I agree that an average match score of around 15 points is not great, I don't think it is a sign of teams doing worse than is typical. My rule of thumb from the last 9 years of FIRST has been the mean robot can score it's starting load in the middle task. Otherwise, it can do the main scoring task once give of take a half. For example, this year that would be 2 balls in the middle goal. times 3 and you've got 12 points. Last year, 1.5 tubes scored per robot (although the Minibot kind of messed that one up). In 2010, 1.5 soccer balls per robot per match. |
#11
Re: Week 1 Stats
I just threw this together for my own interests. Simply alliance score averages for each event, separated by Qualification, QF, SF, F, and all Eliminations.
![]() As you see, scores essentially doubled between Qualifications and QF. Last edited by kjohnson : 04-03-2012 at 19:34. Reason: Updated with San Diego results |
#12
Re: Week 1 Stats
The averages you have listed in the last column seem to be based on the averages per event rather than for all matches at once. The difference probably wouldn't be too much, but it probably will be noticeable.
#13
Re: Week 1 Stats
Attached are two histograms of winning (and tying) and losing (and tying) alliance scores in qualifying rounds at the Granite State Regional in 2012. Interesting distribution shapes... winning scores are essentially normal, but losing scores are very positive skewed. 84 matches were played, the mean winning score was 25.4 points, mean losing score was 11.8 points. Standard deviation of winning scores was 11.2, standard deviation of losing scores was 8. Max winning score was 52, max losing score was 30.
#14
Re: Week 1 Stats
EDIT: Here are the total averages for Week 1, not just each regional averaged together. The difference is negligible. All Qualification: 15.36 Quarter-Finals: 32.09 Semi-Finals: 39.01 Finals: 46.18 All Eliminations: 36.00 Last edited by kjohnson : 05-03-2012 at 09:37. Reason: Added new data |
