Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
Unread 04-03-2012, 14:10
Peggy Painter Peggy Painter is offline
Catalyst
FRC #5476 (Y Bridge 4H Robotics)
Team Role: Leadership
Rookie Year: 2011
Peggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud of
Balls lodged under bridges??
After our team played at the KC regional this weekend one of the questions I have is:
Are there any reliable and simple methods to deal with balls under the bridges?
I saw robots with great shooters/ball launchers and fairly good bridge & balance manipulators.
Once balls went under a bridge things got interesting. What have you seen at other regionals?
Peggy
Bit by Bit 4-H Robotics/FIRST FRC Team #3784
2012 winners of GKC Regional thanks to Team 16 and Team 1986
2011 winners with Team 525 and Team 1730 @ GKC Regional
2011 High seed rookies @ GKC Regional
2011 Gracious Professionalism @ GKC Regional
Unread 04-03-2012, 14:14
littlejimmy1058's Avatar
littlejimmy1058 littlejimmy1058 is offline
Safety Captain
AKA: Daniel Browne
FRC #1058 (PVC Pirates)
Team Role: Mechanical
Rookie Year: 2012
littlejimmy1058 is an unknown quantity at this point
Re: Balls lodged under bridges??
I attended the BAE Systems GSR regional in New Hampshire. We saw balls get under the bridge and teams lose balance points because of it. I think a simple sweeping bar attached to the front of the robot should do it. Of course this is my first year (pardon the pun) so........
Unread 04-03-2012, 14:20
tanmaker
Posts: n/a
The problem with a sweeping bar is the 14" appendage rule. There needs to be a change to the field design. The ramps that were added under the bridge after week 0 do absolutely nothing. One idea I had was adding an accordion style skirt under the bridges. They would be inset a bit so as not to interfere with robots while the bridges were down.
I really think the GDC or whoever does field design needs to look at this and address it as a massive problem with the game.
Unread 04-03-2012, 14:52
johnmaguire2013's Avatar
johnmaguire2013 johnmaguire2013 is offline
Harps On Websites
AKA: John Maguire
FRC #3322 (Eagle Imperium)
Team Role: Webmaster
Rookie Year: 2011
johnmaguire2013 is an unknown quantity at this point
Actually, if you watch this, you will notice that the ball deflector is designed to only work when the bridge is pushed the other way.
John Maguire
Website Team | PR/Marketing Team
FRC Team 3322 - Eagle Imperium | My Blog
Unread 04-03-2012, 17:00
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
I don't think that the maximum rule of 14" will be enough to sweep under the bridges.
Just tip the bridge away from your robot 1st & then the lexan will roll them out & away so ramp mounting can be initiated.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 04-03-2012, 17:11
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Please avoid making duplicate threads and check for existing threads describing this issue to avoid parallel discussions and minimize forum clutter.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 04-03-2012, 17:26
MarcD79's Avatar
AKA: Marc
What everybody is missing here is that this is real life. Nothing is perfect, things are always changing. Get used to it & flow with it & you will progress in life without too many hitches. Yes the balls get stuck under the ramp, but that is why teams have to rethink their strategy. Think to yourselves, is there a ball underneath? Will I need to tip the ramp away from our robot 1st? Don't bash FIRST because it's not a perfect game. Every game played has had variables. Embrace it & get creative with fun mixed in.
Mentor & Volunteer
Unread 04-03-2012, 17:44
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
I disagree. While the balls getting under the bridges are a pain, they pose the same problem to every team. I saw several different ways teams at KC removed them, and at least one time I saw a robot get up on the bridge even though there was a ball on their side of the bridge. It kind of hopped up in a couple of stages.
I think the bigger problem is knowing that the balls are there, and where they are. That's another engineering problem, and I expect to see some different ways to solve it by the time we get to the St. Louis regional in week 4.
There's also the non-engineering part of the problem. Such as spending too much time trying to remove a ball when there's a better alternative like going to the other side. There were also times where it really wasn't even necessary to use the bridge.
I'd hate to see the field changed at this point. All of the teams have the same problem. I'd much rather see FIRST address the problems associated with volunteer food (seriously -- no filet mignon & lobster?) and inspector compensation. Are we really supposed to believe that working with great teams of both students & mentors is all we get out of this?
Mentor http://www.teamtitanium.org/
Unread 04-03-2012, 18:55
Harps On Websites
AKA: John Maguire
Rookie Year: 2011
They don't exactly pose the same problem to every team though. There are situations where it is actually impossible to get a ball out from under the bridge, and it happens to only one team that match. That match could be a tie-breaker finalist match.
John Maguire
Unread 04-03-2012, 19:01
Safety Captain
AKA: Daniel Browne
Rookie Year: 2012
I saw some teams try to get onto the bridge and get over the balls too. It is just one of those things that makes FIRST so much fun to participate in! If there is a ball under the bridge, well.... what will you do?
Captain of Safety for Team 1058, The PVC Pirates
"Lunacy will be played on a 27-by-54 foot field..."
Awards-
2012-Chairman's Award (Granite State Regional)
Unread 04-03-2012, 19:19
BrendanB BrendanB is offline
AKA: Brendan Browne
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
The trick is that teams who lift the bridge are typically on the same side as the direction that the balls come out which means they hit the robots bumper and go right back under or are stopped right at the bottom of the lexan plates and still block the bridge. Our team has a full width pickup and we started to just ram the pickup under the bridge and clear all the balls out in a few seconds.
On idea is if you are on the same side as the balls lift the bridge and quickly drive back so the balls can roll out. Teams aren't giving the balls the time they need to roll out.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 04-03-2012, 19:25
JPM0887's Avatar
JPM0887 JPM0887 is offline
FRC #1289 (Gearheadz)
JPM0887 is an unknown quantity at this point
Our bridge mechanism was only on the corner of our robot, so many times we just knocked the balls off the bridge from an angle without being directly behind it.
Unread 04-03-2012, 19:26
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
Team Role: Coach
Rookie Year: 2007
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
You crush them with the bridge and keep going.
Video (Match 91): http://www.more.net/content/2012-qualification-matches
At 2:38 in the video you can see that 967 is dealing with a ball under the bridge. Eventually they give up and go to the other side where they knock a ball into the other side of the bridge as well. 1986 come to the original side and crushes the ball with the bridge while climbing on. We do have to stay towards that end to keep the ball from preventing 967 climbing on after us.
PS. This was the exciting match where all 6 robots end up balanced, 2 on each bridge. Blue has a 19 point lead when red completes the double balance to take a temporary lead. Blue counters with their own double balance (even though only a single was needed) for the victory. Meanwhile the co-op bridge is blocked on both ends by ball adding to the drama previously described.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 04-03-2012, 20:37
The field & the rules are the same for everyone. Bad Things happen; where on the spectrum of those things would you like to draw a line that says "change the rules after week one" is right thing to do?
  #15   Spotlight this post!
Unread 05-03-2012, 15:36
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Watch team 231 put a ball under the red bridge. Then 2936 spends the next 10 seconds trying to get it out for the triple balance.
www.179swampthing.org
