Go to Post Desperation is the mother of accomplishment. - Koko Ed [more]
Unread 04-03-2012, 23:16
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
Team Role: CAD
Rookie Year: 2010
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
pic: A Beautiful Mess?
Unread 04-03-2012, 23:17
Andrew Lawrence
Posts: n/a
Re: pic: A Beautiful Mess?
This looks like something that would chase me in my nightmares.....
Unread 04-03-2012, 23:19
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
Rookie Year: 2011
sand500 is an unknown quantity at this point
Looks like the only thing you are missing is a fuel tank.
Unread 04-03-2012, 23:20
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Render only the electronics: perfect teaser
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 05-03-2012, 00:52
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
I see pneumatics too...
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 05-03-2012, 00:56
Cad posessed
AKA: Derek Stone
Team Role: CAD
Rookie Year: 2010
Due to how inventor utilizes "segments" in building constraints and my unwillingness to route a black and red wire seperately for every connection, I did the following. Under the segments are true black and red wires of correct gauge. The power side of wires is covered in "red chrome" material while the motor sides is a "black chrome". The battery leads are left normal, pwm's are covered by gold material and then the pneumatics is all the orange and very thick "wires".
Unread 05-03-2012, 17:39
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
I see a few issues here. The first is that you have 2 power converters, neither of which is hooked up to the regulated 12 volt output on the PDB. The wireless bridge should be run off of one of the 12 volt regulated supply via one of these adapters to avoid communication drop-outs. The second thing is that your compressor is connected directly to a hose after the check valve. after the check valve should be a tee with whatever you want on oneside, and the pressure relief valve on the other to satisfy [R75]
[R75]
The relief valve must be attached directly to the compressor or attached by suitable brass fittings connected to the compressor output port.
If necessary, teams are required to adjust the relief valve to release air at 125 psi. The valve may or may not have been calibrated prior to being supplied to teams.
Unread 05-03-2012, 18:09
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
That sound you just heard was my husband fainting dead on the floor! He is a master electrician and if the kids don't wire just right, it all gets done over again until it is a thing of beauty!
Unread 05-03-2012, 18:33
Cad posessed
AKA: Derek Stone
Team Role: CAD
Rookie Year: 2010
yes, some parts especially the power convertors are very incorrect, but very difficult to see that, they are infact plugged into the power distrubiution board, and to answer your question the pneumatics is in fact correct, if you trace it, the compressor goes directly to the storage tanks, then goes to the Tee on the Norgren (on one side) and to the pressure relief valve on the other side. After the Norgren are the actuators. You see the compressor going directly to the valve which is not the case it actually snakes underneath that black board to where the tanks are placed then back through the proper system. The wiring on the DC convertors is being fixed, the ribbion cable is being mounted, the classmate, pot/encoders, and solenoids are being wired tonight.
Unread 05-03-2012, 18:39
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
If in the process of plugging in a wire you jostle loose three others, reexamine what you did to get left with the crappiest and smallest place on the bot to mount electronics!
Unread 08-03-2012, 00:56
AKA: Alan Wells
FRC #1350 (Rambots)
The relief valve MUST be connected to the compressor by only brass fittings. The tanks are not brass fittings. The relief valve must be before any hoses, tanks, valves (except for the factory installed check valve), or regulators. The check valve is the small hexagonal piece directly mounted to the compressor. This is allowed since it is factory installed, but every thing in between this component and the relief valve must be BRASS.
Unread 10-03-2012, 18:53
Cad posessed
AKA: Derek Stone
Team Role: CAD
Rookie Year: 2010
now I am really confused, This is what first puts as their diagram...
http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2012_Assets/2012%20FIRST%20Robotics%20Competition%20Pneumatics %20Manual.pdf
Page 8
That is going compressor, storage tanks, relief valve/ regulator....
Any clarification would be great.
Unread 10-03-2012, 19:00
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You've got the dump valve confused with the relief valve.
The relief valve is the small brass thing on top of the compressor in that diagram. The relief valve prevents the pressure from going too high; the dump valve is used to drain all the air out of the system.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-03-2012, 19:06
Cad posessed
AKA: Derek Stone
Team Role: CAD
Rookie Year: 2010
yeah I just realized that, on the old compressor model I was using it was already placed on the output of the compressor, and I didn't even think about it on this one. Yes it is done correctly on our robot, but I made a mistake on the render, luckily you can't see it on the whole render
  #15   Spotlight this post!
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Page 8
[R75]
In the pictures/diagrams that you linked to the pressure relief valve is directly connected to the compressors secondary port.
I believe you may be mixing up the pressure switch (which must be on the high side) and the pressure relief valve (which must be hard connected to the compressor.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
