Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 05-03-2012, 03:07
Francis115 Francis115 is offline
AKA: Daniel
FRC #3481 (Bronc Botz)
Team Role: CAD
Rookie Year: 2010
Francis115 is an unknown quantity at this point
Hex Shaft Collar
Hey,
What kind of collar do I use for a hex shaft?
Unread 05-03-2012, 03:14
tzjin tzjin is offline
AKA: Tony Jin
FRC #0192 (Gunn Robotics Team)
Team Role: Leadership
Rookie Year: 2010
tzjin has a spectacular aura abouttzjin has a spectacular aura abouttzjin has a spectacular aura about
Re: Hex Shaft Collar
Calculate the distance from opposite angles by diameter/ sqrt(3) * 2. Find the nearest size up (ie 7/16" collar for 3/8" hex or 5/8" collar for 1/2" hex).
Alternatively, take out the set screw and broach the shaft collar
With a smile,
Tony
Unread 05-03-2012, 06:51
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Aluminum Clamp On Shaft Collar, 1/2" Hex Bore
Unread 05-03-2012, 09:25
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
We broached 3/8" shaft collars for 3/8th hex shaft ad it worked great!
Unread 08-03-2012, 17:50
Dripto Dripto is offline
AKA: Dripto Debroy
FRC #0694 (StuyPulse)
Team Role: Student
Dripto is an unknown quantity at this point
If you don't have enough collars of the right size (We never thought to check for ALUMINIUM collars, steel would have been overkill for our application) you can also take some aluminium rod stock, drill+broach the hex into it, and then file a flat to drill and tap! Worked great for us and get us the lightweight piece we needed.
Unread 08-03-2012, 20:26
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
We use shaft collars from McMaster. They are definitely overkill but work great.
Unread 08-03-2012, 21:12
Billfred's Avatar
Billfred Billfred is offline
If you have a lathe and know where you want to put things, an E-clip is also an option in some cases. (This is the route we chose on our ball rollers.)
