Go to Post It will really be different for us (ESPECIALLY since our robot drives consistently this year). - Karibou [more]
Unread 05-03-2012, 13:02
DFZXA DFZXA is offline
FRC #3055 (Furious George)
Rookie Year: 2007
DFZXA is infamous around these parts
Ignoring voltage drops
I'd like to make a program that ignores extreme drops in voltage, but the way I'm thinking of it I would need to get the voltage at one time and get it at a different time in order to compare it. Is there a vi to do this or is there a simpler way.
Unread 05-03-2012, 13:16
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Ignoring voltage drops
There is a vi to grab the robot voltage on the WPI -> Driver Station pallete.
Unread 05-03-2012, 13:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The simplest way to ignore voltage drops is to, well, ignore them.
But of course that's not what you meant.
I think you meant you want to compensate for changes in voltage.
For example, you want to maintain the same torque on a motor even if the available battery voltage fluctuates (due to other loads). If you are using Jaguars on a CAN network, you can do that using the Jag's built-in PID controller to control current to the motor. Motor current and motor output torque are very closely related so that would accomplish the task.
Or perhaps you want to maintain a steady speed, like the speed of a shooter wheel, even when the battery voltage fluctuates. This can be done by using a speed PID controller to control the motor's speed. If the battery voltage drops, the PID automatically increases the output PWM% as necessary to maintain the desired speed.
LabVIEW contains a PID vi. Check out the help.
