Go to Post its kind of a bad idea to implement traction control when you have no traction in the first place. - Uberbots [more]
Unread 05-03-2012, 21:18
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
CPU usage 100% & twitchy robot?
When we enable our robot the code seems to run fine for a couple of seconds then it becomes twitchy and/or laggy. What I mean by twitchy is the light on the motor controllers flicker periodically and the motors controlled by joystick buttons do not respond quickly. Also, the CPU usage on the DS graph changes from 65% to 100% at the same time that the robot seems to become twitchy. In previous years we have had much larger code without problem.
In addition, when I put probes in the teleop vi the probes indicate that the code is running perfectly. However, the motors on the robot do not.
I have included a picture of our teleop code. Any ideas?
Name:	LabView Code_Teleop.jpg
Unread 05-03-2012, 21:21
Re: CPU usage 100% & twitchy robot?
The attached image is tiny, so I can't help much.
Greg McKaskle
Unread 05-03-2012, 21:38
FRC #2147
Here is a bigger picture.
Name:	LabView Code_Teleop_2.jpg
Unread 05-03-2012, 21:43
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
You can also attach a .vi file.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 05-03-2012, 21:44
I don't think the behavior has much to do with the teleop code. To see how often it is being called, you may want to put the Elapsed Times VI into teleop. You can find it in the support folder in your project window.
I think the twitch is likely caused by the robot drive motors being updated less than every 100ms. The next issue is to find the code that runs so often or takes so long that it slows down teleop. One place to look is vision, the other is periodic tasks. Finally, Since I can't see the code run in the other case of the button 5 switch, it could be that it is sleeping for a long time and causing the issue, but I suspect this isn't the case.
Greg McKaskle
Unread 05-03-2012, 21:55
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Your problem could also be caused by unhandled errors within your code - this often takes up a lot of CPU resources (the watchpuppies are a good example of this). On your driver station, go to the "Diagnostics" tab and look at the errors. If it's telling you about an error somewhere in your code, see how fixing it affects your robot response times.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 05-03-2012, 21:58
FRC #2147
Thanks for the help. I'm not at the shop to hook up to the test bot. I'll run the teleop code with the Elapsed time VI tomorrow. What should I be looking for? If it is not calling the teleop vi fast/slow enough what else should I look for?
PS- I attached a picture of button 5.
Unread 05-03-2012, 22:11
plnyyanks's Avatar
AKA: Phil Lopreiato
Rookie Year: 2010
I'd check that all your refnums all match and are correct. That's a common error. And I'd check that your safety isn't tripping (like Greg suggested). Check for code that takes a long time to execute (one iteration of your Teleop VI should take ~20 ms, the amount of time it takes for a new DS packet to reach the robot).
And once you get access to your robot, if there's an error, the error message should tell you exactly what is wrong and which VI it's located in.
Unread 05-03-2012, 23:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I don't think your bridge manipulator motor is going to work the way you want it to. You're setting it in two places, and the second one (on the right) is going to win.
Unread 06-03-2012, 01:27
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Actually, we can't know which one will win: They are not dependent on each other, since the motor ref branches before the set vis. In the purist analysis, either one can fire first and their firing order could be "randomly" re-chosen each iteration. In reality, the optimizer might clump those two commands in an arbitrary order determined at compile time. The "winning" set will still be "randomly" chosen as the fpga timing interacts with the CPU timing, though one will be heavily favored over the other.
Regardless, the result will be a twitchy bridge manipulator. It will toggle between the two set commands unpredictably.
My prediction is that you actually have two problems: The twitchiness is caused by the two set commands racing eachother, and your CPU is being pegged to 100% by a separate error (likely a while loop with no wait in it).
Unread 06-03-2012, 01:37
Software Architect
Oops, you're right. I thought the device reference went from the output of one to the input of the other. I guess I was distracted by the odd placing of the functions, with a bunch of right-to-left wires running along with the left-to-right ones.
Unread 06-03-2012, 22:29
FRC #2147
Rookie Mistake!
Phil you were right. We named two of our motors with the same refnum name. DUH!
Alan- We did have to fix the bridge manipulator motor.
We are new to programming and rely on this forum to get a robot running.
Thanks for the help
