Go to Post This isn't a science fair, sometimes it's okay to give away the answer, especially if they learned something on the way there. - Karthik [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:07
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
joystick problem
Posted by Igor Likhotkin.
Engineer on team #419, Rambots, from U Mass Boston and NASA.
Posted on 2/12/2000 8:37 PM MST
Hi all!
My name is Igor. I am from team 419.
We seem to have a problem with one of our joysticks. When I run default program on our robot,
eventually one of the motors keeps getting some 'juice' even though nobody is touching the joysticks.
I tried swapping the joysticks which made the other motor act the same way. I tried looking at what is
happening to the input variable responsible for that joystick and found out that even though the joystick
sits in the middle, the variable value can be as high as 130-160 decimal. I tried calibrating the y-axis
with the wheel on the joystick, but, alas, after moving the joystick back and forth and then leaving it
alone it would still leak some 'juice' into the motor.
I assumed that since we ran the robot with the default code and since the recalibration of the joystick had
no effect on the performance, the joystick was bad.
Has anyone else had that problem? I really don't know what to think at this point.
If anyone has any input, please reply.
Thank you.
Igor.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
The problem with scouting... archiver 2001 10 23-06-2002 23:49
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
