Re: D-link dropping out
Depending on the model of wireless adapter in use, the proximity of speed controllers to the wireless may have play in the issue. My teem found a few years back that when the speed controllers are running at a high voltage, the EM radiation produced can mess with wireless if the wireless is only a few inches away. An easy way to test to see if this is an issue is getting your wireless as far from your jags as possible (even just duck-taping it at max cord length works). Keep in mind that moving it may also solve other issues.
We were having this problem at LA also. First of all, if you see that your bridge turns off during a match, check the power wire to the bridge, to check for any breaks in the wire. Also, any soldered connections should be resoldered. If this still doesn't work, just replace the whole wire. Also, it could be a problem with the DC to AC converter. If you are getting power to the bridge, but are still having problems, you may want to check your ethernet cable.
I realize that this issue has been resolved but for any other teams that might be experiencing problems:
Last year we had a problem losing communication and it turned out to be a zip-tie that we used to secure our router to the robot was flipping the AP-AUTO-BRIDGE switch, causing the router to power-cycle during a match. Solution: Remove the Ziptie |
Saw the exact same "zip-tie" problem at LA.
I have a few more obvious-in-retrospect tips for anyone who has problems like this in the future:
Check that you're using the right cable. When FIRST switched from a Linksys to the D-Link, we forgot to make a new cable. The old one almost worked, but didn't fit snugly, so it jiggled out when we drove the robot. If you have the parts, replace each element in the chain one at a time and see if the problem goes away. We thought we had a problem with the wiring to the signal light, but discovered it was a damaged Digital Sidecar. |
We've also been having a bridge issue in our tests, and we think it was solved. Basically, when we'd enable, our robot would keep constantly "losing communication". I say that in quotes, because on the Driver Station of things, it doesn't show that, it still says the robot is enabled, battery voltage still shows, etc... Just we lose split second connection, almost as if our robot is constantly disabling itself, while the DS shows it as enabled. Our compressor basically goes on and off, as do motors and everything. The only errors we were getting on our DS were Watchdog errors, reaching numbers as high as the 200s, and each watchdog error would coincide with "loss of communication"
We swapped out our bridge (both were RevA) and reset it and it seemed to keep working, but this issue just appeared all of a sudden. |
The watchdog and communications are related, but let me dig a bit deeper in your symptoms.
If your robot loses communications with the DS, the FPGA System watchdog will disable the robot outputs. This is the same as the disable mode of the DS, but the DS doesn't have to send it. Incoming packets allow the robot to be a mode other than disabled. Your Diagnostics should contain a message each time this happens with the total times the FPGA disables it. If you are using a User watchdog in your code and you don't feed it, your robot will be disabled even though it still has communications. This is useful for debugging code, for runaway code without a runaway robot, etc. The Diagnostic window will get a printout and the User number should be the one that is increasing. Can you say which was causing your issue? Greg McKaskle |
First off, make sure the 12v to 5v converter is properly connected to the +12v out from the PDB. Not just a breaker, but the +12v dedicated for that purpose. Next, and this is what turned out to be our whole issue, make sure every connection in the wiring between the PDB and converter are solid as well as the output from the converter to the radio power plug. We had not one, but four, pour soldered connections. Once we found those and made them right, we had no more issues. Watch the radio next time it fails, if it is rebooting, you can be sure the issue is on the power side. Additionally, if you gain control again after about 45 seconds, that also indicates a radio reset. |
We have also been getting D-Link drop outs. During our competition at Traverse City and at Western Michigan District we had several communications drop outs. Our robot was not driving hard and no major current draws on the battery. The Field controls personal said our radio reset. I am questioning this answer because I see the radio takes about 1 minute to power-up and starts its wireless communications. We loss communications for about 40 seconds. After 40 seconds we are off and running again. My thoughts are we having a wireless network access point/network problem on the field control access point. We saw several other teams with the same problem at these two events.
#10
