Go to Post So, as usual, we know pretty much nothing for sure. - Ninja_Bait [more]
Unread 10-03-2012, 10:45
Camren's Avatar
Camren Camren is offline
Mentor
FRC #3081 (RoBoEaGleS)
Rookie Year: 2011
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Gamepad help
Hello
Im semi new to using wind-river though i do a bit of visual studio work so I understand the terminology. My current project is programming a gamepad to work im pretty sure it is a logitech f310 but i can adapt code to work for which ever one i have. So can anyone give me some example code so i can see what i need to work on.
Unread 12-03-2012, 15:52
Jay Meldrum's Avatar
Jay Meldrum Jay Meldrum is offline
FRC #0067 (H.O.T.)
Jay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud of
Re: Gamepad help
First you have to declare them in the main class
Code:
class BuiltinDefaultCode : public IterativeRobot
        //Declare Controllers
        Joystick *m_Gamepad1;
        Joystick *m_Gamepad2;
Then initialize them in the main function
Code:
BuiltinDefaultCode(void)
                //Initialize Controllers
                m_Gamepad1 = new Joystick(1);
                m_Gamepad2 = new Joystick(2);
You then can call the joystick button/axis using various commands. We tend to use the GetRawAxis/Button Function.
WPILib Joystick Doxygen
http://www.virtualroadside.com/WPILi..._joystick.html
Code:
 void TeleopDrive(void)
       m_robotDrive->ArcadeDrive((-m_Gamepad1->GetRawAxis(LEFT_Y)), -(m_Gamepad1->GetRawAxis(RIGHT_X)));
void TeleopArmPosition(void)
         if(m_Gamepad1->GetRawButton(BUTTON_1))
                 ArmPosition(ARM_BRIDGE);
Just for ease we #define all the different axis/buttons
Code:
//Define Buttons
#define BUTTON_1 1
//Define Axis
#define LEFT_X 1
For reference, here is a map for using GetRawButton/Axis with the Logitech F310:
-Buttons 1-8 are used. They are not labeled, you can try reading all 8 and seeing what maps to what. I know that 9-12 are not used.
Axis 1 -> Left X
Axis 2 -> Left Y
Axis 3 -> Sum of L2 and R2 analog triggers - One is positive, the other is negative, both or neither is 0.
Axis 4 -> Right X
Axis 5 -> Right y
Axis 6 -> D-Pad X (binary like above - Note that you can't read D-Pad Y)
Unread 12-03-2012, 18:11
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Rookie Year: 2010
Alexander Meyer is on a distinguished road
Re: Gamepad help
If you do have the F310, I wrote a class a while back to make using it easier. You can find it here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=90022
If you'd like to write your own code, you can at least use it for the axis and button mappings. If not, usage is very similar to a regular WPILib Joystick.
Code:
F310 *gamepad = new F310(1);
float leftX = gamepad->GetX(F310::kLeftStick);
float rightY = gamepad->GetY(F310::kRightStick);
bool leftTrigger = gamepad->GetButton(F310::kLeftTrigger);
delete gamepad;
gamepad = NULL;
jsmeldru, perhaps we have different versions of the F310? I'm able to read all 12 buttons as well as both DPad axes.
