Go to Post Too many people have worked too long and too hard to have the selfish actions of one person derail our teams reputation because they want to vent online. - Koko Ed [more]
Unread 11-03-2012, 22:14
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Rookie Year: 2010
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Re: Why I love the coopertition bridge
Originally Posted by Koko Ed View Post
Oh. My mistake then. I thought the two team balancing ont he bridge were the only ones getting the Co-Opertition points.
[G41] If a Robot from each Alliance is balanced on the Coopertition Bridge when the final score for a Qualification Match is assessed per Rule [G37], each Alliance earns 2 Coopertition Points. If the Coopertition Bridge is not balanced, but a Robot from each Alliance is fully supported by the Coopertition Bridge, each Alliance will earn 1 Coopertition Point.
I thought only the two balanced robots got the coop points too, until I reread the rules. This certainly changes things. I'm sure this is a rule that many teams do not understand.
In an elimination match the best strategy would be to have the two weaker robots immediately go and double balance and have the best robot score balls and then go balance on the coopertition bridge at 60 seconds.
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 11-03-2012, 22:20
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
In an elimination match, the co-op bridge does not count for anything.
My opinion: If your alliance is outgunned you should send your weakest balancing bot to try and co-op while your other two bots balance on your bridge and secure a win.
Unread 11-03-2012, 22:39
470-RBTX's Avatar
470-RBTX 470-RBTX is offline
Team Schmooze Captain
FRC #0470 (Alpha Omega Robotics)
470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of
I love the bridge because it forces opposing alliances to interact in a positive way in a game where without it there would be no interaction. It's a spawning point for chemistry between drive teams before eliminations, and when all the teams start working for a common purpose as one unit, it strengthens FIRST as a whole. The bridge is just a microcosm of it.
Unread 12-03-2012, 02:07
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
You should send your best driving team to climb to assure the bridge will be successfully balanced.
Unread 12-03-2012, 02:30
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Strategically, the Co-Op bridge is more important than the alliance bridge, and thus you should send your best bots to balance. Ranking wise, it is identical, except for the fact that 3 other teams in an event of 60 move up faster. It also helps build good will, which is not to be underestimated. In general, it is more polite for both alliances to send their best scoring bots to the bridge so that the other one doesn't see it as a ploy to win the match by pulling away their scoring capabilities.
