Go to Post FIRST is an amazing combination of principles that, when applied to the world, has had a monstrous effect on the way High School students learn, think, and relate to others. - Amanda M [more]
Unread 03-12-2012, 12:11 AM
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Camera Image Not Sent Over Wireless Connection
Hello Chiefdelphi,
Our team has had the most frustrating time using the camera this year. This issue at hand, however, is that the camera will display an image when connected through the tether, however, when we connect wirelessly (even through the field at competition) we do not get an image. This past weekend, we used driver dead reckoning to aim the robot and did a very good job, if I may say so. However, there were times when we found our shots traveling just to the left or right, and this is where at least having the camera display in the driver station would be helpful.
If it helps, we are using a 4-slot cRio, with the camera connected directly to the radio. The IP of the camera is 10.7.44.11 and the IP of the cRio is 10.7.44.2. We do not get an image when using a classmate or another laptop, nor when using either the smart or regular dashboard.
If anyone has had the same problem, and has solved it, or thinks they know what is happening, please help.
Thank you,
Alex
www.sharkattack744.com
