Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 12-03-2012, 18:58
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
Team Role: CAD
Rookie Year: 2010
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
pic: Final Render 2012
Unread 12-03-2012, 19:01
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Rookie Year: 2007
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Re: pic: Final Render 2012
I'm not sure if you noticed, but half of your wheels and lower part of your drive base is cut off due to the ground plane. I recommend constraining everything independent of the ground plane. After you add the wheels, tangent constrain them to the ground plane with an offset for more visual appeal and less "robot loss".
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 12-03-2012, 19:03
Sb28000's Avatar
Sb28000 Sb28000 is offline
FRC #2656 (Quasics)
Team Role: Leadership
Sb28000 is on a distinguished road
From my limited experience with CAD/rendering (I am a little over midway through a high school class that teaches Inventor), it looks very nice. Is there any way you could add your team numbers to your bumpers for that extra little touch of realism? Very impressive though, nice work.
Pittsburgh Regional Finalists 2010
Hoping to come back strong in 2012!
Unread 12-03-2012, 19:19
DonRotolo's Avatar
Back to humble
FRC #0832
That looks less like a shiny floor and more like a..........WATER GAME!
Seriously, awesome CAD render, thanks for sharing that.
Unread 12-03-2012, 19:20
Andrew Lawrence
Posts: n/a
Oh Don....
Unread 12-03-2012, 19:42
Cad posessed
AKA: Derek Stone
Team Role: CAD
Rookie Year: 2010
The ground plane is actually 1/2" below the wheels, due the physical configuration of our robot you can't see them and the reason you see the reflection is that it's a shiny ground plane. If the bottom of the drivetrain were cut off you wouldn't be able to see the full reflection of the wheels etc.
Ahh the infamous team numbers, we have a very good person on our team in charge of graphics, and the issue is, our team number is "mountain dew" font, somehow years ago they got it. Anyhow the graphics person said we could only use that font, and it's saved in a particular image style and when I went to import it into the sketch the transparent background surrounding the letters is turning gray, and they will not allow me to use any other font in native autodesk to emboss the number. And hence why there are no team numbers, currently.
Unread 12-03-2012, 19:52
Rookie Year: 2007
Originally Posted by crazyStone View Post
The ground plane is actually 1/2" below the wheels..."
Over the past few years CADing in Inventor, I've ran into the same problem before. I guarantee that in the process of rendering, you lost part of your robot beneath the reflection plane. I understand if you left it the way you did for visual purposes. Just pointing out that you may want to consider offsetting the robot from whatever plane you based the reflection rendering off to avoid this.
Founding Member
