#16
Re: Week--2 All regionals OPR
Using oprnet to calculate opr.
Its week 1 and week 2 regionals. |
#17
Ouch. Page 11. I guess we got our act together and our robot in working order a little late. We should be better at St.Louis, after a little more improvement.
#18
I believe Stundt1 is speaking of the opportunity cost of balancing those co-op bridges is not accounted for. Meaning if you spent a lot of time working on that while you could have been making baskets it doesnt take that into account.
#19
Yes it takes to in account if you say double balanced but not coopertition balanced. Thats why its off a lot this year.
#20
It's a system that's over my head is all. |
#21
There appear to be many anomalies in the analysis. See attachment.
Some teams are listed twice, with different OPRs, for the same week. Several teams are listed 3 times with different OPRs. |
#22
Ill fix those tommrow. Thanks for pointing out sorry for the mistakes.
#23
Raw data is available to compute separate power ratings for Hybrid, Bridge, TeleOp, and Foul Points*. Would that be of interest to anyone ? *Foul Points would be computed for the Team committing the foul. Last edited by Ether : 12-03-2012 at 23:23. |
#24
Ether I can add hybrid teleop and bridge balancing rankings tommrow, if you wish?
#25
Yes! Raw data would be awesome!
#26
Basically, yes... OPR (Offensive Power Rating) is an approximation at how many points your team scores in the average match. Since the co-op bridge doesn't provide any points, it's not included, even though it's a testament to the value of your robot.
OPR is calculated the same way every year... I am a little fuzzy on the details, but basically OPR is found using Matrix & Linear Algebra to quickly solve a complex set of simultaneous equations that yields teams' average contribution in points. I believe two equations exist for each match, one for the red alliance (A + B + C = X) and one for the blue alliance (D + E + F = Y)... in which A, B, C, D, E, and F are the teams on each alliance and X and Y are the match scores. If A and D competed with each other in a later match, two more equations might exist: A + D + G = R and H + I + J = S. I believe these equations are then approximated incrementally until values are determined for each team. That's all a combination of speculation and secondhand information, but regardless, each team is treated as a constant for an entire competition. If you start out very poorly, then become very good, there's no telling what OPR you'll end up with! Quote:
Additionally, most OPR calculations (OPRnet included) don't include elimination matches... I think partially because the alliances are the same for each match, making them far less useful in terms of calculating OPR. Again, this is speculation, not the result of comparing OPR calculations of the same event that exclude and include elim matches. For any seeking to learn a bit more about OPR, I recommend Ed Law's explanation for how it works... His statistic CCWM is calculated the same way as OPR, but looks at the winning (or losing) margin instead of alliance score. See: http://www.chiefdelphi.com/media/papers/2174? Nathan |
#27
i like how the winning alliance at Oregon isn't on the first or second page yet several other teams at Oregon are much closer to the top.
seems accurate. |
#28
This has been discussed before but for those that didn't catch it, I will repeat it again. We should not compare OPRs across different regionals/district events. It looks like that is what the OP did. The reason is some events are stronger than others and it is not a fair comparison. The better way to do it is what I called True World Ranking where every match including elimination rounds of every regional/district are all assembled into a giant matrix so all interactions between teams are taken into account. It is not perfect but it will give each team one OPR number that is a reflection of their whole season so far. This year I also calculated the OPR for hybrid, bridge, teleop and cooperition separately using the same method. I publish all these data after each week in the following CD link if anyone is interested. http://www.chiefdelphi.com/media/papers/2174 |
#29
I pasted the week 1 events wrong ED. Thats where the error came from.
#30
Same with the separate 'bridge' calculation - since your robot's bridge skills are clearly related to your ability to balance the CP bridge. I'm not sure if I still think it's a good idea including it in the overall OPR calculation, but it's too late for me to take it back out now. |
