Re: Week--2 All regionals OPR
This has been discussed before but for those that didn't catch it, I will repeat it again. We should not compare OPRs across different regionals/district events. It looks like that is what the OP did. The reason is some events are stronger than others and it is not a fair comparison. The better way to do it is what I called True World Ranking where every match including elimination rounds of every regional/district are all assembled into a giant matrix so all interactions between teams are taken into account. It is not perfect but it will give each team one OPR number that is a reflection of their whole season so far. This year I also calculated the OPR for hybrid, bridge, teleop and cooperition separately using the same method. I publish all these data after each week in the following CD link if anyone is interested. http://www.chiefdelphi.com/media/papers/2174 |
I pasted the week 1 events wrong ED. Thats where the error came from.
Same with the separate 'bridge' calculation - since your robot's bridge skills are clearly related to your ability to balance the CP bridge. I'm not sure if I still think it's a good idea including it in the overall OPR calculation, but it's too late for me to take it back out now. |
Our first hand experience competing at an event this year shows that it is easier to balance with your own alliance partner than with someone who is over 50 feet away from you. This is the reason I want to look at balancing alliance bridge and coopertition bridge separately. |
Ouch. Page 11. I guess we got our act together and our robot in working order a little late. We should be better at St.Louis, after a little more improvement.
It's a system that's over my head is all. |
Basically, yes... OPR (Offensive Power Rating) is an approximation at how many points your team scores in the average match. Since the co-op bridge doesn't provide any points, it's not included, even though it's a testament to the value of your robot.
OPR is calculated the same way every year... I am a little fuzzy on the details, but basically OPR is found using Matrix & Linear Algebra to quickly solve a complex set of simultaneous equations that yields teams' average contribution in points. I believe two equations exist for each match, one for the red alliance (A + B + C = X) and one for the blue alliance (D + E + F = Y)... in which A, B, C, D, E, and F are the teams on each alliance and X and Y are the match scores. If A and D competed with each other in a later match, two more equations might exist: A + D + G = R and H + I + J = S. I believe these equations are then approximated incrementally until values are determined for each team. That's all a combination of speculation and secondhand information, but regardless, each team is treated as a constant for an entire competition. If you start out very poorly, then become very good, there's no telling what OPR you'll end up with! Quote:
Additionally, most OPR calculations (OPRnet included) don't include elimination matches... I think partially because the alliances are the same for each match, making them far less useful in terms of calculating OPR. Again, this is speculation, not the result of comparing OPR calculations of the same event that exclude and include elim matches. For any seeking to learn a bit more about OPR, I recommend Ed Law's explanation for how it works... His statistic CCWM is calculated the same way as OPR, but looks at the winning (or losing) margin instead of alliance score. See: http://www.chiefdelphi.com/media/papers/2174? Nathan |
For those interested in the math, a short explanation of the matrix math required to solve the normal equations is given here. |
#10
Thanks for all you guys bring to those of us who use and appreciate the stats but lack the software and statistical experience to generate them. Nathan |
#11
Interesting numbers! I think graphs always help data make a lot more sense. I accidentally left my laptop charger at a friends, so I don't have access to my best friend Stata right now. However, Excel works in a pinch.
The first graph essentially plots the distribution of OPRs since they are ranked in the data file. You can see that there is a very sharp drop off among the truly excellent teams, a wide flat region, and then a drop off on the tail end. If I had to bet, I would say the teams that are ranked extremely poorly probably played mostly with excellent teams in bad matches, and to make the math work out ended up with negative numbers. Since penalties do not subtract from scores this year, you'd have to be intentionally awful to interfere with your partners enough to really hurt their OPR. Also, there were 1009 points in this data set, so going by 100s you can basically break OPR up into percentiles. ![]() The next graph shows OPR versus team number (which is a fairly decent approximation for age). With an R-square of .076, it obviously doesn't explain all of the variation, but I think it is interesting to see the general trends (and watch 2056 absolutely decimate one of them). ![]() Finally, the last one to me is the most interesting. It plots the distribution of Week 1 and Week 2 OPRs, and is normalized by the number of teams since significantly more teams played Week 1 than Week 2. I apologize for the smallness of the graph, but this computer is ancient and apparently asking Powerpoint to resize this was asking way too much as the computer crashed a couple of times just getting to this point. As you can see, the top tier teams didn't change much, and the teams that didn't score much stayed essentially the same. However, the middle of the road teams to upper middle of the road got a couple of points better. I would think this is exactly what we'd hope to see (although more lifting on the extreme low end would be nice too), it should provide more exciting balanced matches. ![]() (one you can blow up more) |
#12
Has anyone run the hybrid, teleop and bridge power ratings for Week 2? (as in Week 1) Also, I hope it doesn't make too big an impact, but do the teleop ratings include foul points? As I understand it, the TPs FIRST reports in the standings include fouls, but the Twitter feed breaks them out.
#13
2056's teleop: Wow. Code:
0 Hybrid 67 13.2136 0 Hybrid 2056 11.8122 0 Hybrid 341 11.7323 0 Hybrid 1983 11.5823 0 Hybrid 3618 10.9527 0 Hybrid 836 10.5504 1 Hybrid 2852 10.3684 0 Hybrid 3205 10.129 0 Hybrid 180 10.1057 0 Hybrid 48 10.0291 1 Hybrid 2067 10.019 0 Hybrid 224 9.84828 0 Hybrid 2052 9.56086 2 Hybrid 1114 9.02976 2 Hybrid 1884 9.01958 1 Hybrid 1676 8.96045 1 Hybrid 3357 8.78736 1 Hybrid 2046 8.62482 1 Hybrid 103 8.4832 1 Hybrid 4373 8.43816 1 Hybrid 2866 8.33456 0 Hybrid 3316 8.32457 2 Hybrid 1719 8.29162 2 Hybrid 1523 8.27897 1 Hybrid 2530 8.21279 1 Hybrid 469 8.16767 3 Hybrid 4252 8.14791 3 Hybrid 3242 8.1073 2 Hybrid 1540 8.03206 2 Hybrid 708 7.96769 4 Hybrid 342 7.95542 3 Hybrid 177 7.84907 3 Hybrid 4342 7.80864 1 Hybrid 1574 7.80067 1 Hybrid 379 7.76812 4 Hybrid 2180 7.75142 2 Hybrid 2062 7.75139 5 Hybrid 1218 7.68549 2 Hybrid 2603 7.68037 4 Hybrid 558 7.66851 5 Hybrid 1065 7.65327 5 Hybrid 3280 7.61335 3 Hybrid 714 7.53921 6 Hybrid 1902 7.28756 4 Hybrid 188 7.26662 7 Hybrid 744 7.26604 5 Hybrid 907 7.22311 3 Hybrid 3883 6.96193 2 Hybrid 247 6.853 6 Hybrid 2234 6.80343 2 Hybrid 1228 6.71998 2 Hybrid 1662 6.6111 3 Hybrid 2614 6.6068 8 Hybrid 3556 6.58972 6 Hybrid 4097 6.49691 7 Hybrid 357 6.39657 3 Hybrid 3098 6.37218 6 Hybrid 610 6.36655 8 Hybrid 225 6.35537 4 Hybrid 2220 6.2888 4 Hybrid 217 6.21639 5 Hybrid 2957 6.20531 5 Hybrid 888 6.1321 9 Hybrid 1592 6.06154 6 Hybrid 1714 5.99029 9 Hybrid 365 5.95353 7 Hybrid 2538 5.9057 3 Hybrid 1403 5.85862 7 Hybrid 1547 5.80896 6 Hybrid 612 5.78015 10 Hybrid 2729 5.73514 11 Hybrid 316 5.7307 8 Hybrid 2472 5.71538 10 Hybrid 3164 5.68616 8 Hybrid 3386 5.67405 9 Hybrid 3061 5.63188 12 Hybrid 486 5.56051 3 Hybrid 2439 5.56009 2 Hybrid 3234 5.54942 4 Hybrid 1425 5.54372 7 Hybrid 192 5.53511 3 Hybrid 1731 5.47815 4 Hybrid 573 5.46913 5 Hybrid 3636 5.45773 7 Hybrid 1100 5.4547 10 Hybrid 2169 5.43168 6 Hybrid 3192 5.42553 4 Hybrid 2252 5.42163 5 Hybrid 2834 5.24228 7 Hybrid 2635 5.22304 8 Hybrid 2374 5.16704 8 Hybrid 2028 5.11478 4 Hybrid 1942 5.0881 11 Hybrid 3261 5.03336 5 Hybrid 1675 5.03024 3 Hybrid 2474 5.02999 6 Hybrid 620 4.98711 9 Hybrid 4334 4.98596 12 Hybrid 3018 4.88283 13 Hybrid 834 4.88181 8 Hybrid 3930 4.85998 9 Hybrid 2130 4.82041 13 Hybrid 1625 4.8155 5 Hybrid 1576 4.75154 14 Hybrid 222 4.72912 7 Hybrid 3492 4.6707 14 Hybrid 2826 4.65281 15 Hybrid 3122 4.64892 10 Hybrid 1246 4.63637 11 Hybrid 2185 4.63248 6 Hybrid 3211 4.60632 11 Hybrid 2383 4.59367 9 Hybrid 4254 4.58742 4 Hybrid 3314 4.5799 15 Hybrid 2229 4.56882 7 Hybrid 3351 4.55214 8 Hybrid 4320 4.52513 10 Hybrid 3182 4.49761 16 Hybrid 433 4.43778 16 Hybrid 876 4.4274 5 Hybrid 4347 4.41855 17 Hybrid 2191 4.37886 9 Hybrid 204 4.36537 12 Hybrid 2994 4.35892 10 Hybrid 2002 4.24461 18 Hybrid 2539 4.21473 13 Hybrid 2625 4.20358 11 Hybrid 753 4.14729 17 Hybrid 2499 4.08128 6 Hybrid 2851 4.05547 8 Hybrid 1708 4.04356 12 Hybrid 4043 4.00642 10 Hybrid 2528 4.00523 9 Hybrid 128 3.97007 11 Hybrid 2068 3.96341 13 Hybrid 2733 3.95854 12 Hybrid 768 3.94528 18 Hybrid 1816 3.93414 9 Hybrid 4326 3.93193 12 Hybrid 108 3.8832 11 Hybrid 23 3.87201 12 Hybrid 467 3.86144 10 Hybrid 3504 3.84239 10 Hybrid 3775 3.80811 11 Hybrid 1503 3.77597 13 Hybrid 237 3.75212 14 Hybrid 2557 3.74813 14 Hybrid 2198 3.74351 19 Hybrid 816 3.73789 14 Hybrid 244 3.7217 15 Hybrid 2411 3.68555 6 Hybrid 555 3.61197 13 Hybrid 4222 3.57526 7 Hybrid 2016 3.50185 8 Hybrid 223 3.49218 13 Hybrid 1991 3.47436 15 Hybrid 4288 3.40547 14 Hybrid 1251 3.37075 12 Hybrid 4027 3.34857 15 Hybrid 4066 3.33441 16 Hybrid 945 3.33293 13 Hybrid 1533 3.32134 19 Hybrid 3747 3.30625 7 Hybrid 3620 3.29115 17 Hybrid 25 3.27133 14 Hybrid 279 3.2613 4 Hybrid 2075 3.25978 16 Hybrid 2199 3.17965 17 Hybrid 3748 3.17326 20 Hybrid 1807 3.16937 20 Hybrid 2264 3.14659 18 Hybrid 1629 3.13849 15 Hybrid 3260 3.06149 16 Hybrid 156 3.0592 11 Hybrid 1690 3.02987 18 Hybrid 801 3.02876 17 Hybrid 3138 2.97827 9 Hybrid 1811 2.95156 18 Hybrid 3567 2.94152 14 Hybrid 1687 2.93768 10 Hybrid 1302 2.93747 21 Hybrid 4054 2.88198 16 Hybrid 360 2.85676 12 Hybrid 2216 2.81367 13 Hybrid 1937 2.80031 5 Hybrid 201 2.79706 17 Hybrid 2093 2.7747 15 Hybrid 548 2.76719 8 Hybrid 3570 2.75994 22 Hybrid 2506 2.74069 14 Hybrid 3358 2.73775 15 Hybrid 663 2.69203 19 Hybrid 3511 2.62583 19 Hybrid 181 2.61498 18 Hybrid 2443 2.59843 23 Hybrid 2491 2.59261 9 Hybrid 3655 2.58401 19 Hybrid 3611 2.58269 16 Hybrid 2370 2.56205 10 Hybrid 3175 2.55563 20 Hybrid 3627 2.54914 24 Hybrid 2177 2.54888 16 Hybrid 1815 2.52203 15 Hybrid 3087 2.50772 21 Hybrid 3489 2.49891 17 Hybrid 1075 2.47794 18 Hybrid 1241 2.46013 22 Hybrid 86 2.44638 6 Hybrid 2586 2.44358 21 Hybrid 484 2.44195 20 Hybrid 2912 2.43753 11 Hybrid 4405 2.41728 11 Hybrid 56 2.41268 23 Hybrid 1612 2.40801 12 Hybrid 11 2.35184 16 Hybrid 3774 2.34721 22 Hybrid 3929 2.34477 13 Hybrid 3142 2.33768 24 Hybrid 179 2.32778 7 Hybrid 107 2.32688 19 Hybrid 3711 2.32359 19 Hybrid 1404 2.31578 21 Hybrid 509 2.28984 12 Hybrid 226 2.2776 8 Hybrid 3639 2.26153 9 Hybrid 4363 2.26037 14 Hybrid 41 2.23953 20 Hybrid 781 2.22054 23 Hybrid 3974 2.21517 10 Hybrid 904 2.1837 20 Hybrid 3210 2.18259 17 Hybrid 1952 2.17873 25 Hybrid 3846 2.17769 18 Hybrid 2231 2.16235 25 Hybrid 2556 2.16045 13 Hybrid 3539 2.15021 19 Hybrid 1578 2.13344 21 Hybrid 1510 2.13176 20 Hybrid 3065 2.12425 22 Hybrid 1895 2.11365 14 Hybrid 4216 2.11139 23 Hybrid 1155 2.10669 24 Hybrid 53 2.06586 24 Hybrid 2495 2.02148 17 Hybrid 549 2.01935 25 Hybrid 1111 1.99227 26 Hybrid 3056 1.98634 22 Hybrid 1700 1.98482 23 Hybrid 847 1.96232 11 Hybrid 1596 1.94237 26 Hybrid 2534 1.90812 27 Hybrid 288 1.9025 21 Hybrid 1577 1.87663 27 Hybrid 3788 1.8717 18 Hybrid 228 1.83643 15 Hybrid 1025 1.82188 28 Hybrid 2846 1.81845 24 Hybrid 956 1.81313 28 Hybrid 2377 1.811 22 Hybrid 3339 1.79198 23 Hybrid 1954 1.7844 12 Hybrid 4003 1.78326 15 Hybrid 1089 1.75531 16 Hybrid 869 1.72209 24 Hybrid 1657 1.70321 17 Hybrid 1626 1.67405 29 Hybrid 3650 1.66768 30 Hybrid 2537 1.65772 13 Hybrid 1076 1.65572 20 Hybrid 3062 1.64557 16 Hybrid 1 1.63921 19 Hybrid 839 1.61999 14 Hybrid 66 1.61399 20 Hybrid 3623 1.58487 25 Hybrid 2679 1.58268 31 Hybrid 3283 1.55716 21 Hybrid 1743 1.55238 15 Hybrid 4391 1.53487 16 Hybrid 3772 1.52862 29 Hybrid 3828 1.52319 30 Hybrid 3036 1.51058 18 Hybrid 203 1.50961 25 Hybrid 321 1.50794 26 Hybrid 1557 1.49663 17 Hybrid 3547 1.48381 18 Hybrid 3542 1.48253 32 Hybrid 1980 1.47441 31 Hybrid 3839 1.46155 27 Hybrid 665 1.46101 32 Hybrid 2470 1.45701 28 Hybrid 233 1.43493 26 Hybrid 2213 1.43156 26 Hybrid 1257 1.38549 33 Hybrid 3419 1.37522 19 Hybrid 2619 1.36605 34 Hybrid 88 1.34579 17 Hybrid 141 1.34157 21 Hybrid 348 1.32471 22 Hybrid 4049 1.316 20 Hybrid 1998 1.3001 18 Hybrid 3537 1.29397 25 Hybrid 3673 1.28593 21 Hybrid 68 1.2824 19 Hybrid 2458 1.27912 23 Hybrid 306 1.27221 24 Hybrid 3955 1.26639 29 Hybrid 4064 1.26235 19 Hybrid 74 1.22511 21 Hybrid 3705 1.22508 22 Hybrid 1250 1.21956 23 Hybrid 503 1.20721 27 Hybrid 3835 1.20695 30 Hybrid 1875 1.19724 25 Hybrid 4032 1.17151 26 Hybrid 4150 1.16018 33 Hybrid 3294 1.12928 27 Hybrid 375 1.10261 34 Hybrid 2518 1.10061 26 Hybrid 3841 1.09066 28 Hybrid 3193 1.07974 27 Hybrid 4110 1.07877 31 Hybrid 4091 1.05401 35 Hybrid 358 1.04184 29 Hybrid 2656 1.02943 32 Hybrid 3502 1.0288 20 Hybrid 3603 1.01669 28 Hybrid 2898 0.993155 36 Hybrid 3389 0.975565 29 Hybrid 2192 0.960488 35 Hybrid 2526 0.959725 22 Hybrid 4042 0.952699 30 Hybrid 3472 0.951946 20 Hybrid 613 0.950548 36 Hybrid 2574 0.943649 21 Hybrid 4377 0.920986 21 Hybrid 1168 0.914169 33 Hybrid 4333 0.911822 31 Hybrid 2811 0.909541 37 Hybrid 3755 0.864894 38 Hybrid 2845 0.848772 32 Hybrid 4127 0.838184 34 Hybrid 4223 0.838175 27 Hybrid 423 0.835798 22 Hybrid 3637 0.818239 23 Hybrid 3515 0.818071 23 Hybrid 1735 0.814347 37 Hybrid 3150 0.80693 30 Hybrid 2428 0.786439 24 Hybrid 102 0.78496 22 Hybrid 3509 0.784461 33 Hybrid 2605 0.778923 23 Hybrid 830 0.764401 24 Hybrid 3688 0.752203 31 Hybrid 4050 0.751874 22 Hybrid 1219 0.714996 24 Hybrid 3667 0.70751 34 Hybrid 1595 0.705067 35 Hybrid 4065 0.70413 35 Hybrid 3145 0.695616 36 Hybrid 4257 0.692122 28 Hybrid 2214 0.670104 25 Hybrid 2145 0.655837 39 Hybrid 4217 0.634083 37 Hybrid 3812 0.624305 38 Hybrid 841 0.621766 36 Hybrid 79 0.619085 23 Hybrid 3117 0.618904 29 Hybrid 3388 0.602339 25 Hybrid 1672 0.571357 24 Hybrid 4410 0.555331 28 Hybrid 1495 0.548056 26 Hybrid 303 0.529917 25 Hybrid 4044 0.525173 30 Hybrid 2630 0.491139 37 Hybrid 4321 0.479274 39 Hybrid 1359 0.475072 40 Hybrid 4181 0.466711 26 Hybrid 857 0.465807 27 Hybrid 4128 0.461999 41 Hybrid 4230 0.458366 40 Hybrid 3024 0.447482 42 Hybrid 3102 0.434707 32 Hybrid 4031 0.414625 33 Hybrid 2641 0.386663 24 Hybrid 4307 0.380617 41 Hybrid 2521 0.378679 38 Hybrid 2546 0.364695 31 Hybrid 2212 0.359065 25 Hybrid 4248 0.358127 34 Hybrid 2618 0.351456 38 Hybrid 4197 0.336743 28 Hybrid 1143 0.33228 43 Hybrid 2512 0.31946 32 Hybrid 4319 0.315711 29 Hybrid 1367 0.302588 39 Hybrid 3790 0.289026 40 Hybrid 3782 0.261891 26 Hybrid 3398 0.257032 30 Hybrid 2577 0.220944 29 Hybrid 3151 0.219386 26 Hybrid 3550 0.203748 30 Hybrid 709 0.167972 41 Hybrid 4024 0.162215 27 Hybrid 3548 0.147994 42 Hybrid 3132 0.143099 42 Hybrid 4109 0.140014 33 Hybrid 2230 0.135296 25 Hybrid 246 0.11727 27 Hybrid 4376 0.105604 43 Hybrid 1649 0.0985122 44 Hybrid 3276 0.0902737 27 Hybrid 3387 0.0485563 28 Hybrid 3657 0.0422735 31 Hybrid 3123 0.0336234 44 Hybrid 4352 0.0333324 45 Hybrid 4238 0.01415 29 Hybrid 2612 0.0119725 30 Hybrid 4384 0.00504222 45 Hybrid 3410 -0.0301949 31 Hybrid 308 -0.0351156 39 Hybrid 216 -0.0513294 31 Hybrid 1881 -0.0692589 32 Hybrid 3414 -0.0764897 28 Hybrid 2626 -0.0882658 40 Hybrid 27 -0.08988 46 Hybrid 3740 -0.121599 47 Hybrid 3267 -0.124406 28 Hybrid 1711 -0.137003 29 Hybrid 3767 -0.151324 30 Hybrid 1896 -0.177746 48 Hybrid 3840 -0.185597 33 Hybrid 3601 -0.19942 49 Hybrid 3130 -0.200174 46 Hybrid 4190 -0.201999 29 Hybrid 2809 -0.210659 43 Hybrid 3131 -0.212155 47 Hybrid 4133 -0.217562 32 Hybrid 3340 -0.233303 50 Hybrid 2175 -0.240158 44 Hybrid 2542 -0.289897 51 Hybrid 2500 -0.297559 52 Hybrid 3381 -0.299438 32 Hybrid 2559 -0.301822 53 Hybrid 2977 -0.307606 33 Hybrid 136 -0.310058 41 Hybrid 1389 -0.32337 42 Hybrid 4067 -0.325928 31 Hybrid 4398 -0.341283 34 Hybrid 752 -0.348087 48 Hybrid 1543 -0.360168 32 Hybrid 835 -0.371772 45 Hybrid 2471 -0.380408 46 Hybrid 4051 -0.388433 43 Hybrid 3307 -0.402433 34 Hybrid 2672 -0.458362 44 Hybrid 2819 -0.469994 33 Hybrid 2245 -0.484592 35 Hybrid 4338 -0.493525 34 Hybrid 470 -0.556162 35 Hybrid 1370 -0.568025 54 Hybrid 3197 -0.570521 47 Hybrid 2915 -0.571689 30 Hybrid 1325 -0.583712 36 Hybrid 75 -0.591845 36 Hybrid 3052 -0.605608 45 Hybrid 7 -0.605927 49 Hybrid 386 -0.607356 33 Hybrid 304 -0.614793 50 Hybrid 4214 -0.62436 48 Hybrid 1544 -0.642388 46 Hybrid 1915 -0.666092 49 Hybrid 3712 -0.669644 50 Hybrid 2990 -0.670297 31 Hybrid 865 -0.725893 35 Hybrid 291 -0.74627 37 Hybrid 1573 -0.748061 51 Hybrid 2916 -0.74927 52 Hybrid 4013 -0.755722 51 Hybrid 2517 -0.760437 55 Hybrid 93 -0.763961 52 Hybrid 957 -0.783133 36 Hybrid 4289 -0.80674 37 Hybrid 117 -0.827716 34 Hybrid 3602 -0.831271 53 Hybrid 2550 -0.834105 56 Hybrid 4011 -0.838868 47 Hybrid 2265 -0.84018 57 Hybrid 3754 -0.85567 32 Hybrid 1221 -0.868668 53 Hybrid 21 -0.885624 48 Hybrid 686 -0.896236 49 Hybrid 2849 -0.898379 38 Hybrid 3766 -0.899111 33 Hybrid 3988 -0.913765 35 Hybrid 4390 -0.917923 54 Hybrid 3674 -0.922143 34 Hybrid 3985 -0.936405 35 Hybrid 4375 -0.957172 55 Hybrid 1823 -0.972508 26 Hybrid 2621 -0.975162 50 Hybrid 623 -0.980681 51 Hybrid 3714 -0.983258 54 Hybrid 2152 -0.988847 39 Hybrid 1946 -0.99465 27 Hybrid 2064 -1.01172 28 Hybrid 4041 -1.01445 56 Hybrid 2412 -1.01712 29 Hybrid 3499 -1.02384 40 Hybrid 4406 -1.02486 36 Hybrid 3770 -1.03049 37 Hybrid 1188 -1.03562 37 Hybrid 2554 -1.05898 57 Hybrid 4132 -1.07334 36 Hybrid 4392 -1.09025 58 Hybrid 3367 -1.09627 55 Hybrid 3376 -1.11159 38 Hybrid 2544 -1.11518 38 Hybrid 1989 -1.13471 58 Hybrid 2437 -1.17856 59 Hybrid 955 -1.19284 52 Hybrid 4266 -1.19782 56 Hybrid 3998 -1.20977 37 Hybrid 2246 -1.20994 53 Hybrid 3941 -1.21369 30 Hybrid 230 -1.21392 57 Hybrid 3557 -1.27023 59 Hybrid 4009 -1.32324 58 Hybrid 2757 -1.33819 59 Hybrid 3011 -1.35573 39 Hybrid 3954 -1.36701 54 Hybrid 1748 -1.37417 41 Hybrid 3075 -1.40026 40 Hybrid 3957 -1.45657 60 Hybrid 1432 -1.47795 61 Hybrid 3995 -1.48747 60 Hybrid 2797 -1.5342 41 Hybrid 1270 -1.62615 61 Hybrid 3659 -1.64135 38 Hybrid 2153 -1.67277 42 Hybrid 1943 -1.71369 43 Hybrid 1944 -1.74471 55 Hybrid 3793 -1.75093 39 Hybrid 219 -1.78078 42 Hybrid 2051 -1.81763 62 Hybrid 4125 -1.83575 43 Hybrid 3962 -1.85896 62 Hybrid 1604 -1.86864 39 Hybrid 3617 -1.89609 56 Hybrid 533 -1.90664 57 Hybrid 2421 -1.96536 63 Hybrid 568 -2.01173 38 Hybrid 3538 -2.04331 44 Hybrid 1580 -2.0696 58 Hybrid 1643 -2.09675 44 Hybrid 63 -2.28848 39 Hybrid 2627 -2.29245 64 Hybrid 4057 -2.32677 60 Hybrid 3054 -2.3754 31 Hybrid 2648 -2.4064 40 Hybrid 4281 -2.41221 61 Hybrid 877 -2.43875 62 Hybrid 4228 -2.43995 32 Hybrid 190 -2.46448 59 Hybrid 1446 -2.51296 34 Hybrid 1791 -2.5436 41 Hybrid 1279 -2.56567 35 Hybrid 3360 -2.57799 60 Hybrid 449 -2.59119 61 Hybrid 3733 -2.62558 45 Hybrid 3083 -2.77994 62 Hybrid 1195 -3.23722 33 Hybrid 2877 -3.30971 65 Hybrid 997 -3.491 63 Hybrid 3312 -3.71904 35 Hybrid 4035 -4.05459 36 Hybrid 3553 -7.71641 Code:
0 Teleop 2056 23.2447 0 Teleop 2169 15.8049 0 Teleop 341 14.4474 0 Teleop 1676 14.0926 0 Teleop 67 14.0786 0 Teleop 1592 13.1581 1 Teleop 1218 13.0268 1 Teleop 469 12.7512 0 Teleop 620 12.4123 0 Teleop 1629 12.3624 0 Teleop 2474 12.3455 1 Teleop 1714 12.2658 1 Teleop 1114 11.8559 0 Teleop 1983 11.6952 1 Teleop 2471 11.6623 1 Teleop 103 10.6405 2 Teleop 744 10.6159 1 Teleop 2377 10.5978 2 Teleop 217 10.4872 3 Teleop 1065 10.2044 2 Teleop 1241 10.0904 2 Teleop 222 10.048 4 Teleop 180 9.32391 3 Teleop 365 8.68109 1 Teleop 2614 8.62772 1 Teleop 1143 8.50688 2 Teleop 48 8.49449 3 Teleop 188 8.48882 2 Teleop 56 8.45749 4 Teleop 2626 8.32437 3 Teleop 27 8.27306 0 Teleop 1690 8.15331 1 Teleop 1662 8.1356 2 Teleop 2834 7.49043 0 Teleop 177 7.3363 2 Teleop 2826 7.31831 3 Teleop 224 7.23497 4 Teleop 4342 7.19294 2 Teleop 1700 7.13421 5 Teleop 610 7.05601 3 Teleop 1425 7.05177 4 Teleop 1719 6.96239 3 Teleop 876 6.64134 6 Teleop 2852 6.62026 2 Teleop 1574 6.56531 4 Teleop 3314 6.55121 4 Teleop 3130 6.47232 5 Teleop 2016 6.43727 1 Teleop 3234 6.4026 5 Teleop 342 6.39362 6 Teleop 1523 6.37065 5 Teleop 3929 6.24771 5 Teleop 2052 6.20352 6 Teleop 316 6.05237 1 Teleop 228 6.00876 7 Teleop 548 5.98698 4 Teleop 2557 5.98102 2 Teleop 3537 5.94297 3 Teleop 1942 5.90702 2 Teleop 3205 5.89541 7 Teleop 179 5.87342 3 Teleop 3357 5.86817 5 Teleop 2002 5.85803 8 Teleop 1251 5.81243 5 Teleop 2199 5.80585 3 Teleop 3962 5.7857 4 Teleop 2679 5.71637 6 Teleop 2521 5.7033 6 Teleop 2528 5.70171 7 Teleop 612 5.67868 6 Teleop 2530 5.60972 7 Teleop 484 5.59881 7 Teleop 3755 5.56917 8 Teleop 3389 5.52254 4 Teleop 2544 5.31079 8 Teleop 3294 5.22895 5 Teleop 3138 5.18015 6 Teleop 2252 5.15517 8 Teleop 357 5.14909 9 Teleop 2729 5.12158 9 Teleop 1649 5.04439 8 Teleop 907 4.99561 7 Teleop 1503 4.99281 3 Teleop 3280 4.97557 9 Teleop 3117 4.95195 4 Teleop 4392 4.8943 5 Teleop 3083 4.84064 6 Teleop 2213 4.79209 9 Teleop 3846 4.72758 3 Teleop 3098 4.72374 4 Teleop 1025 4.71654 4 Teleop 3930 4.7049 7 Teleop 2192 4.68116 8 Teleop 2603 4.58783 6 Teleop 1403 4.52619 10 Teleop 2506 4.50524 7 Teleop 1577 4.47562 10 Teleop 4334 4.46366 9 Teleop 2912 4.44938 9 Teleop 1533 4.40166 5 Teleop 348 4.3915 6 Teleop 558 4.38793 11 Teleop 2809 4.37681 10 Teleop 4091 4.32718 8 Teleop 2093 4.32686 10 Teleop 375 4.29477 11 Teleop 1902 4.28205 11 Teleop 2538 4.26017 12 Teleop 1875 4.25011 7 Teleop 1228 4.24018 10 Teleop 834 4.20988 8 Teleop 869 4.20731 7 Teleop 2648 4.20684 11 Teleop 63 4.15039 9 Teleop 2374 4.0744 13 Teleop 801 4.06397 8 Teleop 1100 4.04701 12 Teleop 1625 3.99262 5 Teleop 3770 3.98057 8 Teleop 3211 3.97703 10 Teleop 1540 3.94313 12 Teleop 2185 3.88529 13 Teleop 877 3.84783 9 Teleop 3339 3.83788 11 Teleop 4127 3.81989 12 Teleop 3841 3.80088 10 Teleop 3419 3.76608 14 Teleop 3276 3.75881 12 Teleop 4027 3.73308 10 Teleop 1576 3.72311 15 Teleop 3747 3.70052 9 Teleop 230 3.61974 11 Teleop 192 3.52293 11 Teleop 3316 3.51793 12 Teleop 888 3.51303 11 Teleop 2180 3.48818 16 Teleop 3312 3.48382 12 Teleop 2216 3.4739 9 Teleop 1302 3.46133 13 Teleop 1675 3.42917 13 Teleop 836 3.42707 10 Teleop 2370 3.42696 14 Teleop 1895 3.38718 13 Teleop 1944 3.38286 13 Teleop 3550 3.37697 6 Teleop 573 3.3713 14 Teleop 1946 3.31851 17 Teleop 2957 3.30497 15 Teleop 3283 3.29278 16 Teleop 1915 3.27859 18 Teleop 3883 3.27809 12 Teleop 3123 3.1954 14 Teleop 3193 3.17713 15 Teleop 2230 3.12077 16 Teleop 1954 3.11879 14 Teleop 4024 3.10576 11 Teleop 3623 3.07731 12 Teleop 2067 3.05047 13 Teleop 1359 2.9749 5 Teleop 904 2.97245 14 Teleop 3705 2.9708 17 Teleop 1731 2.9617 14 Teleop 3812 2.96056 15 Teleop 2198 2.95516 13 Teleop 486 2.86711 15 Teleop 79 2.83122 19 Teleop 2264 2.82935 15 Teleop 2046 2.82445 20 Teleop 2518 2.7966 16 Teleop 3711 2.79193 15 Teleop 2051 2.78307 7 Teleop 247 2.77489 17 Teleop 2439 2.7686 16 Teleop 25 2.75791 14 Teleop 2234 2.75641 21 Teleop 3261 2.74935 10 Teleop 3515 2.74077 16 Teleop 3260 2.69391 22 Teleop 3197 2.67716 15 Teleop 816 2.67668 17 Teleop 21 2.66614 6 Teleop 4391 2.65889 23 Teleop 3061 2.65224 13 Teleop 190 2.64765 18 Teleop 3410 2.64043 19 Teleop 3998 2.63863 14 Teleop 3499 2.63365 18 Teleop 1510 2.63122 17 Teleop 4032 2.62308 19 Teleop 3192 2.61669 16 Teleop 3386 2.59375 20 Teleop 955 2.59165 17 Teleop 2866 2.58583 11 Teleop 1367 2.58033 20 Teleop 2383 2.56599 18 Teleop 3492 2.56135 21 Teleop 4132 2.54707 18 Teleop 3087 2.54566 18 Teleop 2265 2.52887 19 Teleop 1389 2.50216 24 Teleop 3828 2.49249 25 Teleop 2472 2.48594 19 Teleop 4406 2.48388 20 Teleop 2214 2.46697 21 Teleop 2630 2.45178 21 Teleop 3164 2.45101 8 Teleop 1188 2.4457 22 Teleop 3358 2.42929 19 Teleop 3954 2.40417 16 Teleop 423 2.40371 15 Teleop 23 2.39952 22 Teleop 360 2.39413 23 Teleop 3775 2.38556 17 Teleop 225 2.38478 26 Teleop 4230 2.35899 12 Teleop 11 2.33835 13 Teleop 203 2.33678 23 Teleop 4057 2.30987 20 Teleop 379 2.28096 9 Teleop 3538 2.27969 20 Teleop 1155 2.27687 21 Teleop 4266 2.27537 7 Teleop 2586 2.2642 21 Teleop 3511 2.2542 16 Teleop 839 2.21459 22 Teleop 7 2.21078 22 Teleop 3567 2.2085 27 Teleop 2845 2.20778 8 Teleop 3602 2.19881 24 Teleop 753 2.18914 9 Teleop 2075 2.17678 22 Teleop 4333 2.17656 25 Teleop 3210 2.1606 10 Teleop 74 2.14932 23 Teleop 1557 2.13261 24 Teleop 1657 2.10353 24 Teleop 4321 2.10284 26 Teleop 2733 2.0832 27 Teleop 956 2.06404 11 Teleop 1076 2.05576 14 Teleop 4347 2.05284 28 Teleop 3018 1.98744 23 Teleop 306 1.98673 25 Teleop 3351 1.98565 15 Teleop 1089 1.98535 16 Teleop 4128 1.98206 17 Teleop 1219 1.9769 18 Teleop 2994 1.97599 28 Teleop 2443 1.97536 24 Teleop 4031 1.97043 26 Teleop 1937 1.96183 29 Teleop 4238 1.9539 23 Teleop 2534 1.94786 30 Teleop 2512 1.94389 25 Teleop 4013 1.93237 10 Teleop 503 1.92241 12 Teleop 4398 1.92163 24 Teleop 509 1.90892 29 Teleop 957 1.89952 31 Teleop 2220 1.89336 26 Teleop 4065 1.8907 25 Teleop 237 1.87797 26 Teleop 768 1.86587 11 Teleop 68 1.86562 12 Teleop 4405 1.86335 27 Teleop 4133 1.85787 30 Teleop 847 1.84223 27 Teleop 4326 1.83734 18 Teleop 709 1.8312 31 Teleop 2517 1.81092 28 Teleop 3242 1.80711 27 Teleop 358 1.80454 25 Teleop 1743 1.78589 28 Teleop 1952 1.77859 26 Teleop 128 1.77694 13 Teleop 66 1.76588 28 Teleop 714 1.76266 13 Teleop 3601 1.76023 14 Teleop 226 1.74605 29 Teleop 665 1.73605 32 Teleop 3636 1.73271 30 Teleop 86 1.73265 17 Teleop 4041 1.7258 33 Teleop 841 1.72105 19 Teleop 865 1.72058 17 Teleop 1672 1.65812 15 Teleop 1250 1.65128 32 Teleop 4217 1.63472 27 Teleop 2428 1.62326 28 Teleop 1270 1.58595 18 Teleop 4042 1.58094 34 Teleop 2811 1.5748 29 Teleop 2537 1.5722 35 Teleop 3131 1.55408 19 Teleop 2191 1.53186 31 Teleop 4222 1.5131 36 Teleop 2990 1.49125 14 Teleop 3618 1.48007 30 Teleop 3793 1.46133 29 Teleop 2641 1.45071 29 Teleop 3052 1.43445 15 Teleop 201 1.42631 16 Teleop 4390 1.42584 19 Teleop 1884 1.42405 32 Teleop 3659 1.41274 30 Teleop 2231 1.41221 16 Teleop 3509 1.39578 31 Teleop 88 1.38484 17 Teleop 4363 1.38337 17 Teleop 3539 1.37295 30 Teleop 117 1.37052 33 Teleop 4214 1.34835 37 Teleop 3673 1.33438 38 Teleop 3674 1.33424 18 Teleop 1711 1.33009 33 Teleop 3102 1.32568 34 Teleop 3054 1.31951 34 Teleop 3556 1.30928 39 Teleop 2605 1.307 20 Teleop 663 1.30498 18 Teleop 3637 1.3012 21 Teleop 4097 1.29748 35 Teleop 2526 1.29537 19 Teleop 2458 1.28047 20 Teleop 2229 1.27241 22 Teleop 467 1.27109 40 Teleop 2437 1.26611 36 Teleop 2846 1.26202 20 Teleop 1325 1.26021 18 Teleop 3570 1.24534 20 Teleop 223 1.24019 21 Teleop 1881 1.23776 31 Teleop 4319 1.23703 37 Teleop 3122 1.22308 19 Teleop 2619 1.2213 19 Teleop 141 1.2171 21 Teleop 1807 1.20173 38 Teleop 3056 1.18208 41 Teleop 2411 1.17943 39 Teleop 4181 1.17003 35 Teleop 2152 1.16581 20 Teleop 3547 1.1577 42 Teleop 4125 1.15419 23 Teleop 246 1.12077 31 Teleop 1708 1.11645 40 Teleop 2491 1.10366 41 Teleop 2499 1.08641 32 Teleop 3504 1.08516 20 Teleop 3617 1.08384 33 Teleop 4289 1.08283 21 Teleop 107 1.07986 22 Teleop 1896 1.06786 42 Teleop 2177 1.06063 23 Teleop 3688 1.04454 21 Teleop 4307 1.04216 22 Teleop 3142 1.03569 43 Teleop 2062 1.02435 22 Teleop 2539 1.01297 43 Teleop 2542 1.00617 44 Teleop 2574 0.999854 45 Teleop 1816 0.999013 24 Teleop 830 0.983436 32 Teleop 3388 0.945121 23 Teleop 3974 0.941989 32 Teleop 2849 0.926835 33 Teleop 181 0.921777 21 Teleop 470 0.91593 33 Teleop 2212 0.910037 34 Teleop 3957 0.892321 22 Teleop 3398 0.884998 46 Teleop 3840 0.869862 24 Teleop 1495 0.867866 25 Teleop 835 0.862337 34 Teleop 4338 0.856798 36 Teleop 3790 0.854176 37 Teleop 1612 0.841107 26 Teleop 3639 0.840275 38 Teleop 4064 0.824942 39 Teleop 2757 0.822827 22 Teleop 3985 0.814767 23 Teleop 1246 0.808793 40 Teleop 3611 0.795071 23 Teleop 75 0.790427 35 Teleop 3065 0.768177 24 Teleop 1279 0.767727 23 Teleop 4044 0.767407 34 Teleop 2028 0.764942 47 Teleop 4228 0.761761 24 Teleop 1547 0.758619 27 Teleop 4377 0.750656 25 Teleop 2554 0.744004 44 Teleop 4043 0.731277 24 Teleop 3620 0.720897 25 Teleop 2495 0.694373 35 Teleop 3733 0.686605 45 Teleop 4110 0.680456 36 Teleop 2819 0.679233 37 Teleop 3650 0.671493 41 Teleop 2556 0.664687 28 Teleop 4376 0.660598 29 Teleop 2246 0.647817 26 Teleop 1811 0.644985 24 Teleop 3182 0.640001 42 Teleop 4066 0.6383 48 Teleop 2470 0.611176 46 Teleop 3024 0.601843 47 Teleop 2130 0.600567 38 Teleop 3307 0.597004 48 Teleop 3995 0.59412 49 Teleop 3381 0.58986 25 Teleop 4384 0.573184 43 Teleop 3557 0.543587 49 Teleop 3472 0.542053 44 Teleop 3627 0.518648 36 Teleop 1573 0.514298 50 Teleop 3712 0.483933 37 Teleop 2672 0.483871 25 Teleop 3387 0.474536 45 Teleop 3376 0.468262 39 Teleop 449 0.448551 35 Teleop 4150 0.445701 26 Teleop 321 0.435191 30 Teleop 4375 0.428701 27 Teleop 1626 0.42668 31 Teleop 2153 0.426309 28 Teleop 219 0.407911 51 Teleop 2898 0.405779 26 Teleop 2625 0.405212 27 Teleop 1257 0.403514 29 Teleop 102 0.394626 36 Teleop 291 0.393235 30 Teleop 3340 0.373817 32 Teleop 3603 0.361142 37 Teleop 4050 0.3397 25 Teleop 2621 0.336006 38 Teleop 3075 0.333858 31 Teleop 1168 0.333248 26 Teleop 2851 0.333151 46 Teleop 386 0.331598 32 Teleop 41 0.328743 40 Teleop 1643 0.323594 33 Teleop 3767 0.322609 50 Teleop 3839 0.304221 28 Teleop 304 0.296333 33 Teleop 136 0.29445 34 Teleop 555 0.289645 47 Teleop 108 0.289242 41 Teleop 623 0.284868 27 Teleop 3655 0.273411 48 Teleop 4190 0.257356 42 Teleop 3150 0.24925 52 Teleop 1432 0.218748 29 Teleop 1791 0.216398 51 Teleop 2175 0.212658 43 Teleop 2421 0.197574 52 Teleop 3754 0.186849 38 Teleop 3062 0.18628 26 Teleop 1735 0.185546 49 Teleop 2916 0.179691 53 Teleop 4051 0.146128 35 Teleop 1989 0.112046 50 Teleop 945 0.0988139 30 Teleop 4035 0.0950182 34 Teleop 4003 0.0873894 31 Teleop 4373 0.0842908 28 Teleop 2627 0.0824077 29 Teleop 2612 0.0791022 44 Teleop 1195 0.0740187 54 Teleop 2635 0.0610225 53 Teleop 4011 0.0595625 36 Teleop 2577 0.0476985 45 Teleop 2068 0.0454691 54 Teleop 93 0.013353 39 Teleop 2618 0.00720899 51 Teleop 4197 0.00645091 55 Teleop 4054 -0.0215712 37 Teleop 1370 -0.0218575 55 Teleop 568 -0.0324236 27 Teleop 1075 -0.0501286 56 Teleop 2550 -0.0718805 56 Teleop 3267 -0.081116 46 Teleop 244 -0.0861692 28 Teleop 781 -0.10861 30 Teleop 3667 -0.108709 38 Teleop 752 -0.149308 31 Teleop 3175 -0.179307 27 Teleop 549 -0.202386 52 Teleop 233 -0.21894 40 Teleop 279 -0.227104 41 Teleop 3955 -0.227193 47 Teleop 2546 -0.235017 57 Teleop 3036 -0.254161 35 Teleop 857 -0.278522 39 Teleop 3774 -0.278618 57 Teleop 3145 -0.289582 48 Teleop 4288 -0.290505 58 Teleop 3367 -0.345454 28 Teleop 2877 -0.351117 32 Teleop 708 -0.356045 53 Teleop 3489 -0.381429 40 Teleop 3766 -0.382831 29 Teleop 4410 -0.421969 42 Teleop 2656 -0.423758 36 Teleop 3772 -0.42536 58 Teleop 1823 -0.428255 49 Teleop 204 -0.437896 54 Teleop 1604 -0.477082 39 Teleop 303 -0.48863 32 Teleop 3414 -0.492368 55 Teleop 3132 -0.514305 29 Teleop 1815 -0.514324 59 Teleop 1595 -0.515141 40 Teleop 613 -0.517097 33 Teleop 3542 -0.526265 56 Teleop 3011 -0.532967 59 Teleop 2977 -0.554125 30 Teleop 1221 -0.559556 30 Teleop 1687 -0.57852 34 Teleop 308 -0.605474 31 Teleop 4248 -0.616082 50 Teleop 216 -0.619748 41 Teleop 4281 -0.623409 35 Teleop 1 -0.629458 37 Teleop 2245 -0.661142 36 Teleop 4216 -0.670692 60 Teleop 2915 -0.699392 37 Teleop 3548 -0.70159 51 Teleop 3748 -0.706638 52 Teleop 533 -0.710118 32 Teleop 3988 -0.74447 53 Teleop 288 -0.760979 60 Teleop 2500 -0.813395 61 Teleop 4009 -0.822886 54 Teleop 1111 -0.826704 33 Teleop 1404 -0.832768 57 Teleop 2797 -0.838483 58 Teleop 3502 -0.904934 38 Teleop 2145 -0.944092 33 Teleop 433 -0.959758 41 Teleop 3835 -0.999257 34 Teleop 3151 -1.01704 31 Teleop 2064 -1.02785 38 Teleop 1998 -1.03451 43 Teleop 4049 -1.04001 42 Teleop 4320 -1.05514 55 Teleop 1980 -1.10845 39 Teleop 3657 -1.19352 56 Teleop 3714 -1.20263 61 Teleop 4257 -1.24472 59 Teleop 1543 -1.36656 34 Teleop 4252 -1.37266 43 Teleop 1580 -1.40965 62 Teleop 4109 -1.4743 32 Teleop 1991 -1.50586 35 Teleop 2559 -1.52459 60 Teleop 4352 -1.56792 33 Teleop 4254 -1.57309 44 Teleop 156 -1.62368 61 Teleop 4223 -1.6837 62 Teleop 3788 -1.70191 57 Teleop 4067 -1.87653 58 Teleop 3941 -1.8774 62 Teleop 3782 -1.8842 59 Teleop 1446 -2.11456 39 Teleop 1596 -2.16043 63 Teleop 2412 -2.24966 44 Teleop 1578 -2.28774 60 Teleop 53 -2.32985 61 Teleop 1748 -2.374 64 Teleop 997 -2.44754 65 Teleop 1544 -2.47367 63 Teleop 3740 -2.48105 35 Teleop 3360 -2.74325 62 Teleop 686 -3.17989 45 Teleop 1943 -3.52077 36 Teleop 3553 -5.43676 Code:
0 Bridge 2557 13.9926 0 Bridge 1100 13.5119 0 Bridge 67 12.1721 1 Bridge 2412 10.4227 0 Bridge 3419 10.1244 0 Bridge 2246 10.0451 0 Bridge 233 10.0012 2 Bridge 4057 9.9247 3 Bridge 3636 9.81351 1 Bridge 3930 9.66467 0 Bridge 1657 9.55387 2 Bridge 4410 9.52658 1 Bridge 3548 9.32508 3 Bridge 2067 9.26401 0 Bridge 3840 9.26134 4 Bridge 3145 9.1913 0 Bridge 610 9.16999 0 Bridge 834 9.13575 0 Bridge 3138 9.07113 1 Bridge 225 9.05225 1 Bridge 107 8.99915 1 Bridge 379 8.93982 2 Bridge 573 8.84797 5 Bridge 1983 8.83383 2 Bridge 48 8.49644 2 Bridge 341 8.39467 1 Bridge 2846 8.38083 3 Bridge 3601 8.30853 0 Bridge 1302 8.28189 1 Bridge 2630 8.27172 3 Bridge 486 8.24529 1 Bridge 3011 8.19932 4 Bridge 469 8.19626 2 Bridge 2264 8.193 4 Bridge 177 7.97163 1 Bridge 4334 7.93985 5 Bridge 3205 7.88927 3 Bridge 1714 7.82624 6 Bridge 228 7.77239 2 Bridge 3617 7.55885 3 Bridge 2614 7.54548 4 Bridge 156 7.50831 6 Bridge 3812 7.35056 1 Bridge 869 7.30434 7 Bridge 4097 7.09556 2 Bridge 1168 7.09068 4 Bridge 2512 6.93953 2 Bridge 1523 6.93464 5 Bridge 2826 6.83357 2 Bridge 2231 6.78851 1 Bridge 2866 6.73856 3 Bridge 180 6.7246 6 Bridge 2220 6.64033 7 Bridge 2538 6.50624 5 Bridge 226 6.50595 2 Bridge 2199 6.47566 3 Bridge 4067 6.46336 4 Bridge 2068 6.45904 5 Bridge 279 6.448 5 Bridge 27 6.34165 2 Bridge 1114 6.34121 3 Bridge 907 6.31809 3 Bridge 1676 6.31414 4 Bridge 2152 6.28323 8 Bridge 839 6.22791 6 Bridge 237 6.22285 3 Bridge 3351 6.22256 7 Bridge 957 6.13633 4 Bridge 1662 6.07461 8 Bridge 360 6.06257 7 Bridge 192 6.00294 8 Bridge 1629 5.97556 5 Bridge 386 5.9411 3 Bridge 1076 5.93672 6 Bridge 3620 5.93192 6 Bridge 103 5.91742 4 Bridge 3637 5.88318 8 Bridge 3747 5.80339 7 Bridge 2797 5.80041 4 Bridge 3360 5.75092 5 Bridge 3387 5.71366 9 Bridge 348 5.70895 7 Bridge 1025 5.70039 4 Bridge 1218 5.67713 4 Bridge 3602 5.57694 5 Bridge 3974 5.57413 6 Bridge 222 5.56647 7 Bridge 3123 5.49345 9 Bridge 877 5.4858 6 Bridge 2626 5.47015 10 Bridge 4228 5.46675 6 Bridge 2641 5.41272 10 Bridge 3623 5.40129 9 Bridge 3131 5.3838 8 Bridge 4333 5.37675 5 Bridge 1711 5.37436 11 Bridge 1625 5.31665 5 Bridge 1279 5.31565 10 Bridge 2439 5.30031 11 Bridge 3024 5.24875 7 Bridge 2852 5.22025 8 Bridge 2627 5.15895 12 Bridge 1700 5.15468 11 Bridge 1735 5.15062 9 Bridge 888 5.14987 7 Bridge 3492 5.10546 8 Bridge 1219 5.10061 9 Bridge 2619 5.07436 12 Bridge 246 5.07354 9 Bridge 2383 5.04445 10 Bridge 247 5.01822 12 Bridge 2175 5.00067 6 Bridge 2075 4.98694 10 Bridge 3242 4.98344 9 Bridge 781 4.97199 13 Bridge 2443 4.95893 11 Bridge 68 4.94837 12 Bridge 3539 4.93168 13 Bridge 3667 4.92066 14 Bridge 1425 4.91035 10 Bridge 2534 4.90257 5 Bridge 1574 4.84962 11 Bridge 3502 4.84399 13 Bridge 2648 4.77633 15 Bridge 2093 4.761 14 Bridge 3182 4.68139 16 Bridge 847 4.67013 13 Bridge 2526 4.63492 12 Bridge 25 4.61267 6 Bridge 1946 4.59954 6 Bridge 223 4.59047 11 Bridge 1111 4.58691 14 Bridge 2834 4.5526 7 Bridge 1576 4.52953 12 Bridge 2537 4.52007 7 Bridge 2016 4.51924 17 Bridge 4051 4.51633 18 Bridge 568 4.49481 8 Bridge 1577 4.47532 9 Bridge 1731 4.43602 10 Bridge 1241 4.40418 8 Bridge 128 4.38465 7 Bridge 4398 4.2702 19 Bridge 753 4.23522 15 Bridge 663 4.22692 14 Bridge 3018 4.21709 8 Bridge 484 4.21292 20 Bridge 2521 4.21264 21 Bridge 4257 4.20154 8 Bridge 1626 4.19933 9 Bridge 11 4.19281 15 Bridge 876 4.19089 10 Bridge 1228 4.15674 9 Bridge 433 4.15195 10 Bridge 4373 4.15008 8 Bridge 904 4.11286 11 Bridge 365 4.1119 9 Bridge 2586 4.07337 13 Bridge 86 4.03475 11 Bridge 1404 4.00113 12 Bridge 708 4.00037 16 Bridge 549 3.9709 11 Bridge 3142 3.91738 13 Bridge 423 3.90878 12 Bridge 56 3.9075 17 Bridge 230 3.90435 14 Bridge 3132 3.88558 14 Bridge 3151 3.87667 13 Bridge 714 3.86096 15 Bridge 2539 3.84099 18 Bridge 4041 3.83637 9 Bridge 2252 3.82285 15 Bridge 2556 3.81635 10 Bridge 3962 3.81345 16 Bridge 2180 3.79969 16 Bridge 801 3.78117 10 Bridge 141 3.76654 12 Bridge 548 3.76617 19 Bridge 4042 3.74918 17 Bridge 79 3.73548 15 Bridge 3175 3.73324 20 Bridge 3499 3.70449 13 Bridge 4307 3.70444 22 Bridge 2898 3.69275 10 Bridge 3065 3.67923 23 Bridge 2990 3.67746 18 Bridge 4064 3.67527 21 Bridge 558 3.67181 11 Bridge 3339 3.66685 11 Bridge 4003 3.62625 13 Bridge 4128 3.60355 12 Bridge 1943 3.57113 16 Bridge 4238 3.55324 19 Bridge 4013 3.54578 11 Bridge 3957 3.52881 24 Bridge 1510 3.48442 12 Bridge 2603 3.47583 13 Bridge 1533 3.47435 16 Bridge 470 3.44993 17 Bridge 3883 3.42436 20 Bridge 342 3.42108 18 Bridge 93 3.40831 21 Bridge 1557 3.38798 25 Bridge 3995 3.38735 14 Bridge 53 3.35832 15 Bridge 216 3.344 12 Bridge 4376 3.31695 14 Bridge 63 3.29913 15 Bridge 3193 3.29493 26 Bridge 3841 3.29455 19 Bridge 2518 3.29107 17 Bridge 503 3.27324 18 Bridge 1 3.26328 16 Bridge 612 3.23151 22 Bridge 1687 3.18093 14 Bridge 2056 3.13561 17 Bridge 358 3.12934 15 Bridge 2185 3.12628 19 Bridge 1188 3.09879 13 Bridge 4392 3.09332 20 Bridge 1816 3.0872 13 Bridge 2216 3.07625 22 Bridge 1251 3.05451 17 Bridge 2229 3.04441 20 Bridge 308 3.0407 14 Bridge 2230 3.03758 27 Bridge 4110 2.98975 14 Bridge 1989 2.9859 21 Bridge 3102 2.98413 18 Bridge 2377 2.9665 16 Bridge 1815 2.9265 15 Bridge 3835 2.90799 18 Bridge 709 2.89466 22 Bridge 2052 2.8779 19 Bridge 3929 2.86973 16 Bridge 3954 2.86811 19 Bridge 1155 2.86514 14 Bridge 3618 2.85948 23 Bridge 467 2.85498 20 Bridge 2495 2.84755 20 Bridge 623 2.84714 23 Bridge 2957 2.84236 24 Bridge 4217 2.83829 17 Bridge 2544 2.82361 18 Bridge 4032 2.81008 25 Bridge 3197 2.80048 21 Bridge 768 2.78688 28 Bridge 2471 2.76059 23 Bridge 3611 2.74545 26 Bridge 2506 2.74323 16 Bridge 1937 2.73509 24 Bridge 3556 2.72057 29 Bridge 2517 2.71338 17 Bridge 4320 2.68724 21 Bridge 3770 2.66703 27 Bridge 2470 2.62507 18 Bridge 2679 2.56076 19 Bridge 4031 2.52676 22 Bridge 3398 2.52655 28 Bridge 2472 2.52052 25 Bridge 21 2.51851 15 Bridge 830 2.50996 22 Bridge 217 2.50973 26 Bridge 1604 2.50785 23 Bridge 2528 2.49136 23 Bridge 3542 2.46249 24 Bridge 3547 2.46124 29 Bridge 3036 2.43515 24 Bridge 836 2.4218 27 Bridge 3557 2.40548 17 Bridge 1547 2.39409 28 Bridge 3998 2.39196 30 Bridge 1359 2.38288 30 Bridge 3130 2.37415 25 Bridge 3650 2.35354 26 Bridge 7 2.31141 19 Bridge 3052 2.3053 15 Bridge 1403 2.30216 16 Bridge 4375 2.29975 20 Bridge 1503 2.24493 27 Bridge 2819 2.21753 17 Bridge 74 2.20637 31 Bridge 3755 2.19396 20 Bridge 3083 2.19074 21 Bridge 1690 2.17459 29 Bridge 744 2.1691 18 Bridge 4363 2.14743 16 Bridge 75 2.14532 21 Bridge 4049 2.14029 32 Bridge 3312 2.12939 18 Bridge 188 2.11091 17 Bridge 555 2.10048 22 Bridge 1270 2.09082 23 Bridge 375 2.08619 28 Bridge 509 2.06614 33 Bridge 3381 2.04783 31 Bridge 997 2.02113 18 Bridge 1370 1.97417 29 Bridge 3389 1.96709 19 Bridge 4391 1.94323 32 Bridge 1540 1.94073 30 Bridge 1902 1.94025 33 Bridge 3711 1.93565 24 Bridge 4150 1.90402 24 Bridge 1884 1.90317 19 Bridge 224 1.87059 30 Bridge 449 1.86605 25 Bridge 3098 1.85797 34 Bridge 2733 1.85371 20 Bridge 3234 1.85128 35 Bridge 3210 1.78445 36 Bridge 841 1.72016 37 Bridge 1595 1.71752 34 Bridge 3828 1.71735 38 Bridge 2130 1.71263 21 Bridge 2234 1.71157 19 Bridge 865 1.71016 22 Bridge 1578 1.64784 31 Bridge 1592 1.63219 20 Bridge 613 1.6296 35 Bridge 4230 1.61791 25 Bridge 620 1.58157 21 Bridge 2554 1.57844 36 Bridge 3839 1.57019 20 Bridge 1075 1.56782 22 Bridge 1811 1.5075 32 Bridge 4190 1.46469 23 Bridge 1089 1.46458 31 Bridge 181 1.40489 26 Bridge 3511 1.40017 21 Bridge 4377 1.37678 32 Bridge 1895 1.37203 37 Bridge 3846 1.33635 23 Bridge 2214 1.33567 39 Bridge 1432 1.29027 27 Bridge 1708 1.28926 38 Bridge 3276 1.2763 22 Bridge 2559 1.27622 24 Bridge 3316 1.26591 22 Bridge 66 1.2508 23 Bridge 3603 1.24509 39 Bridge 2530 1.23499 21 Bridge 4252 1.234 26 Bridge 3657 1.2244 33 Bridge 1065 1.21268 34 Bridge 3376 1.20302 25 Bridge 1573 1.19027 24 Bridge 303 1.18091 40 Bridge 1544 1.17982 40 Bridge 3261 1.1783 24 Bridge 857 1.16918 33 Bridge 2028 1.15852 22 Bridge 4248 1.13356 35 Bridge 3489 1.11902 27 Bridge 4405 1.11085 28 Bridge 291 1.09855 28 Bridge 2851 1.09236 23 Bridge 4035 1.07691 34 Bridge 2849 1.07523 41 Bridge 4011 1.05943 35 Bridge 3150 1.05641 36 Bridge 3782 1.01033 29 Bridge 3655 1.01019 42 Bridge 2574 1.00259 36 Bridge 4288 1.00129 24 Bridge 1257 0.986775 37 Bridge 686 0.949524 37 Bridge 3627 0.934576 25 Bridge 3688 0.924323 25 Bridge 1791 0.906685 25 Bridge 2577 0.872041 26 Bridge 1367 0.868122 26 Bridge 304 0.863959 30 Bridge 2612 0.861021 27 Bridge 1143 0.857368 31 Bridge 4390 0.765726 25 Bridge 23 0.732524 26 Bridge 3537 0.723141 41 Bridge 2605 0.721146 43 Bridge 2499 0.702624 42 Bridge 1823 0.690244 44 Bridge 3367 0.664498 27 Bridge 321 0.662307 45 Bridge 2500 0.639685 38 Bridge 3748 0.633737 38 Bridge 3164 0.633196 23 Bridge 2625 0.63003 32 Bridge 3414 0.611257 29 Bridge 1743 0.607551 39 Bridge 4321 0.600078 43 Bridge 2915 0.59834 28 Bridge 816 0.59371 46 Bridge 3267 0.590081 44 Bridge 2542 0.540256 33 Bridge 1250 0.523787 26 Bridge 3087 0.483255 39 Bridge 1389 0.461528 27 Bridge 3388 0.45827 47 Bridge 2062 0.453356 48 Bridge 2177 0.450385 40 Bridge 4352 0.431866 40 Bridge 1719 0.42844 30 Bridge 4050 0.427625 45 Bridge 4132 0.423298 31 Bridge 3260 0.409845 29 Bridge 1495 0.408753 41 Bridge 288 0.407093 28 Bridge 1942 0.388482 42 Bridge 244 0.388081 41 Bridge 4133 0.344811 42 Bridge 1875 0.338358 46 Bridge 3192 0.337356 29 Bridge 1952 0.325752 24 Bridge 3386 0.317577 30 Bridge 316 0.309211 31 Bridge 357 0.285317 27 Bridge 2145 0.259875 32 Bridge 2656 0.249172 43 Bridge 3410 0.243638 43 Bridge 2912 0.227322 47 Bridge 2411 0.214848 34 Bridge 3538 0.213803 44 Bridge 179 0.200816 32 Bridge 2729 0.181396 30 Bridge 2213 0.159326 31 Bridge 3775 0.15726 33 Bridge 1807 0.150544 28 Bridge 2458 0.147943 44 Bridge 533 0.113279 33 Bridge 1675 0.090067 34 Bridge 4027 0.0700422 35 Bridge 3570 0.0441321 49 Bridge 3061 0.0350142 26 Bridge 190 -0.00876373 29 Bridge 136 -0.0128127 32 Bridge 1954 -0.0200009 45 Bridge 4223 -0.028839 46 Bridge 4065 -0.0866517 47 Bridge 4066 -0.094236 28 Bridge 1596 -0.0954 30 Bridge 3515 -0.100801 48 Bridge 4043 -0.112464 45 Bridge 1915 -0.131764 49 Bridge 2811 -0.171647 50 Bridge 2977 -0.181177 36 Bridge 1998 -0.181653 29 Bridge 2245 -0.186717 27 Bridge 2877 -0.20277 50 Bridge 2046 -0.206505 34 Bridge 2191 -0.219405 25 Bridge 3988 -0.221556 30 Bridge 3767 -0.227466 48 Bridge 4091 -0.230471 49 Bridge 4197 -0.237139 51 Bridge 3788 -0.25652 52 Bridge 2169 -0.29085 26 Bridge 1221 -0.300408 50 Bridge 945 -0.322569 31 Bridge 3314 -0.327034 31 Bridge 2474 -0.332358 37 Bridge 4216 -0.357101 32 Bridge 752 -0.399658 51 Bridge 2635 -0.466469 46 Bridge 88 -0.525671 52 Bridge 3674 -0.528653 32 Bridge 2153 -0.550006 47 Bridge 204 -0.598725 51 Bridge 108 -0.605863 35 Bridge 306 -0.643034 38 Bridge 4044 -0.659756 28 Bridge 2064 -0.672765 33 Bridge 1881 -0.673758 34 Bridge 1672 -0.67839 33 Bridge 201 -0.682765 36 Bridge 3567 -0.691227 34 Bridge 3772 -0.694421 33 Bridge 3211 -0.698047 52 Bridge 4214 -0.698138 48 Bridge 1980 -0.706734 53 Bridge 4024 -0.753557 34 Bridge 4326 -0.774634 53 Bridge 4109 -0.83425 27 Bridge 3705 -0.836106 29 Bridge 2370 -0.857988 54 Bridge 2374 -0.860519 28 Bridge 2809 -0.861522 35 Bridge 3357 -0.870007 36 Bridge 835 -0.882186 35 Bridge 3774 -0.908794 53 Bridge 3056 -0.927198 35 Bridge 102 -0.931452 54 Bridge 1543 -0.935976 35 Bridge 4342 -0.941405 37 Bridge 117 -0.955157 36 Bridge 4281 -0.955578 29 Bridge 2994 -0.961161 30 Bridge 4254 -0.9715 30 Bridge 2198 -0.978131 38 Bridge 4289 -0.987825 36 Bridge 3358 -0.998726 39 Bridge 2051 -1.02435 31 Bridge 3280 -1.02611 55 Bridge 955 -1.03569 37 Bridge 1580 -1.08307 49 Bridge 3941 -1.08754 54 Bridge 4181 -1.09248 50 Bridge 2265 -1.09671 51 Bridge 3793 -1.13357 56 Bridge 3712 -1.1557 40 Bridge 3504 -1.17576 38 Bridge 4319 -1.1773 37 Bridge 3509 -1.20691 55 Bridge 4222 -1.22379 31 Bridge 1325 -1.22428 39 Bridge 1944 -1.24647 40 Bridge 4406 -1.25574 56 Bridge 2916 -1.25687 38 Bridge 3639 -1.29919 37 Bridge 219 -1.42815 55 Bridge 3294 -1.43146 57 Bridge 1649 -1.48007 52 Bridge 3283 -1.57155 53 Bridge 2421 -1.57984 39 Bridge 1896 -1.58794 57 Bridge 2437 -1.5956 38 Bridge 41 -1.61293 58 Bridge 2002 -1.6295 41 Bridge 2428 -1.66144 41 Bridge 4338 -1.79556 59 Bridge 3472 -1.83489 54 Bridge 1643 -1.83526 39 Bridge 4384 -1.85318 58 Bridge 3790 -1.86917 32 Bridge 1246 -1.87525 60 Bridge 956 -1.87781 42 Bridge 2672 -1.88857 43 Bridge 2212 -1.92932 44 Bridge 3075 -1.94957 33 Bridge 3985 -1.95485 34 Bridge 3550 -2.00829 59 Bridge 3659 -2.031 55 Bridge 3307 -2.07898 32 Bridge 1991 -2.10004 61 Bridge 2192 -2.11757 56 Bridge 4009 -2.16208 60 Bridge 665 -2.16348 62 Bridge 4125 -2.1794 56 Bridge 3733 -2.22018 57 Bridge 1195 -2.23947 39 Bridge 203 -2.25265 35 Bridge 3117 -2.27096 40 Bridge 3340 -2.28575 45 Bridge 3766 -2.32486 57 Bridge 3054 -2.33999 58 Bridge 3714 -2.36555 42 Bridge 2618 -2.36934 59 Bridge 1748 -2.40403 58 Bridge 2845 -2.41937 60 Bridge 2546 -2.44456 59 Bridge 3740 -2.44473 61 Bridge 2757 -2.49799 63 Bridge 3673 -2.6237 41 Bridge 4347 -2.79536 60 Bridge 2491 -2.88889 61 Bridge 1446 -2.92542 33 Bridge 2621 -2.9451 43 Bridge 3955 -3.13267 62 Bridge 1612 -3.58713 44 Bridge 3062 -3.69922 62 Bridge 4266 -3.84555 64 Bridge 2550 -3.92147 61 Bridge 3122 -3.97264 65 Bridge 4127 -4.13385 62 Bridge 3754 -4.34223 36 Bridge 3553 -4.49028 63 Bridge 4054 -4.98665 Last edited by Bongle : 15-03-2012 at 07:51. |
#14
Bongle,
I checked my data with yours and I am glad to see that they are the same. I just want to clarify for everyone on CD who uses our data why it does not seem to match. In my spreadsheet that is found at http://www.chiefdelphi.com/media/papers/2174, I report on the OPRs for each event separately in its own tab. In column O is the overall OPR. Column AA to AD are the OPRs for hybrid, bridge, teleop and coop respectively. From what I understand, the foul points are included in the overall OPR. To calculate OPR for foul points, it would be OPR foul = overall OPR - OPR hybrid - OPR bridge - OPR teleop Based on my understand, you are giving 5 bridge points and 5 overall OPR points for each Coop point. Is that correct? If it is, then Adjusted overall OPR = overall OPR + 5 X OPR coop Adjusted bridge = OPR bridge + 5 X OPR coop When I adjust my data this way, it matches yours based on spot checking. However I am confused with your statement "the TeleOp and OPR scores both include foul points accrued". Did you adjust the OPR TeleOp points also and add the OPR Foul Points to it? From my understanding, the cummulative TeleOp points that FIRST publish do not include the foul points in it, and I believe we are using the same numbers to calculate OPR components. I would appreciate it if you can clarify. Thanks. |
#15
TeleOp and overall OPR include fouls, because there is no easy way to separate them out. It's not by any concious addition by OPRNet. There aren't any adjustments made for fouls in OPRNet. I have fixed my previous post again. Last edited by Bongle : 14-03-2012 at 16:30. |
