Re: Kinect usage at competitions
Only one team legitimately used it once, however 79 Krunch realized about halfway through Orlando that it was a great opportunity to have someone dance through the first 15 seconds for the rest of their games
1540 and 2443 both used it in Oregon. 1540 was first pick by the 1 seed and used it to time when they would drive toward the bridge. If they got beat to it they would just stop and not risk driving under the bridge and ensuring it rolled any leftover balls off the bridge. I'm not positive what 2443 used it for but they were still using it all the way through the finals.
I know that the cable FIRST is using is designed specifically for the Kinect with a powered repeater, so that would explain why the hub didn't work for you. Sorry you had so many issues though! |
It seems to me like the Kinect was never a very good idea. Not only does it not allow for precise control, but it is probably worse than a good autonomous program. Was there a similar lack of enthusiasm for 2008's remote control thingy that could be used during autonomous?
Our team isn't currently using the Kinect. We considered doing a "shoot now" type of thing, so we didn't overlap with other robots shooting. I like HOT's idea, but part of me believes that trying to correct a first missed shot using the Kinect would only result in a second air ball. |
The 2008 IR remote was very important for one reason: The Randomizer. Game pieces were put in random locations prior to each match, and the IR remote was a way to tell your robot where they were.
Rebound Rumble has no equivalent aspect of randomness. Sure, you might get beat to the bridge, or the balls might be placed slightly different on the bridge, but imagine if there were 2 more "wildcard" balls that were placed somewhere on the floor pre-match. THAT would have been a strong incentive to use the Kinect. |
Here is a copy of my post on this from another thread (which references another thread discussing the same thing...)
I'm still quite suspicious that it was a cabling problem. I don't recall reading hearing about a repeater; I thought Microsoft simply tested with the cable length first used and gave them the nod for using it. We were able to drive it around for about 5 minutes in our build area, and we had what seemed to be much better control. Has anybody else using the kinect observed similar issues to mine? |
Dj,
Personally, I would be much more suspicious of the physical environment than of the cabling. The Kinect is fairly free to move around inside that black box that it is housed in, especially as robots collide with the field. It is also pretty easy to ratchet the Kinect servo so it is tilted up or down instead of straight ahead. If you plan to continue trying to use the Kinect at your next event, have your Kinect operator make sure the Kinect is centered, pulled out towards the edge of the box (so the box does not block any of the image) and level. If your laptop can handle it without trouble, you may want to run the Kinect Server in debug mode (the shortcut is in the FRC Kinect Server folder) to verify what the Kinect is seeing at the start of each match. If you need the screen real estate you can hide the debug mode window behind your dashboard after verifying that the Kinect is positioned properly. |
#10
We are definetly planning on using it this weekend at GVSU.
->5-speed shooter control-right arm (0,.2785,.35,.59,1) and conveyor operation-left arm (off-off, on-off, on-on). ->Last but not least, Pretty Light control w/ Head buttons! We tested it yesterday and it works like it should! But we can also operate w/ old boken timing code from Gull Lake by flipping z-throttle on joystick before match begins. |
#11
I would agree with your suspicions. In practice the classmate yielded delayed results for our team, but using a more powerful laptop greatly increased the response time. It will be interesting to see if this holds true on a real competition field.
4096 plans to use the Kinect at the Midwest Regional next week. |
#12
We use ours. For the first ~7 seconds, its preprogrammed shooting. Then control is givin to our kinect driver and our ball collector is turned on. Our kinect driver drives around for the remainder of hybrid trying to collect balls.
#14
So yes our Kinect code works perfectly in the shop......
But when we use the exact same DS w/ exact same USB hub we are unable to get the Field Kinect to work w/ the DS at all. This is @ GVSU/West Michigan. Anyone else have similar issues? |
#15
The problem is probably the hub. I'd imagine that extension cable may not play nicely with some USB hubs.
