Go to Post If regolith ever makes a return, I will jump out of a window. - Oblarg [more]
Unread 14-03-2012, 18:09
Dochartaigh's Avatar
Dochartaigh Dochartaigh is offline
AKA: John Doherty
FRC #2647 (Mustang Robotics)
Team Role: Teacher
Dochartaigh is an unknown quantity at this point
Deployment to cRio
Anyone available to help a novice deploy a VI to the cRio? Keep getting Real-Time Target error. Have been reading and watching video, and well, I'm just out of time.
Thanks,
John
Unread 14-03-2012, 18:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Deployment to cRio
What vi are you trying to deploy, how are you trying to deploy it, and what exactly is the message you are seeing?
Unread 14-03-2012, 20:03
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
To add to this, note that the window that may pop up that says "This VI is part of a Real-Time Startup Application" is a warning not an error. You can safely click through that window and things will work properly.
