Re: pic: FRC971 Spartan Robotics Presents: Renegade
We also worked to make new wheels this season, to complement the new drivetrain.
Tread is attached via zipties. Wheels measure around 2 inch wide and 3.5 inch tall w/ tread. Thank you to RC for machining these. They turned out great (so far). |
We also use belts for our drive train. This is our second year using them and as for a a skid steer type drive train is concerned I do not think we will ever go back. We use live axles in our system. It seems like you are using a dead axle system with the sprockets machined directly into your wheels (very cool). I would love to see a up close and personal view of how your power transmission works. |
First of all, Congrats on the win at Sacramento. I'm glad to see you guys coming to the championship this year. I really wish I had seen 971 at St. Louis last year.
Second, I'm curious about the pistons you're using to shift. I've never seen anything like that! How reliable are the "Pancake" pistons? Are there any drawbacks to using them, compared to the standard actuator on an AM supershifter? It looks like they save quite a bit of space and weight. Also, where are they for sale? |
We used the 2 position ones last year and this year. They're no more or less reliable than the standard Bimba line of cylinders. They do require different fittings, since they are so small, and must be face mounted. |
Here's a photo of our Robot competing at the Sacramento Regional. As you can see, we made a few changes in between taking our reveal shot and competing at the competition.
We hope to make some improvements and be even better at SVR. ![]() |
How does the belt drive work for you? Was it hard to do? If so, was it worth the difficulty?
#10
The timing belt drivetrain is nice, but it's best to run force calculations to see how it'll hold up. Belt doesn't stretch like chain does, and its quieter and a bit more efficient. It is also lighter. This, coupled with the fact that we have 2 inch wheel means we should be able to get to where we want to go on the field. The extra traction is useful going up the bridge. |
