Go to Post But frankincense and myrrh will come in handy after your team starts to smell during that first design meeting. - Jessica Boucher [more]
Unread 03-14-2012, 10:08 PM
Nymph808's Avatar
Nymph808 Nymph808 is offline
FRC #2443
Nymph808 is an unknown quantity at this point
Programming the 393 VEX Motor in Java
So we're adding a VEX 393 motor to run a camera mount, and I was wondering how to program the actual motor. We've connected the motor to the speed controller it came with and from there, it connects to a PWM slot on the side car. I've been looking at the Java documentations under the SpeedController interface, but the only classes it implements are the Jaguar and Victor classes. I don't know if the VEX motor uses one of those classes, or if it uses it's own separate class. Any ideas?
Unread 04-11-2012, 04:01 PM
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Re: Programming the 393 VEX Motor in Java
I am pretty sure that almost any time you hook up any motor to a vex or jag you will use the victor class in java because when you use the victor class it wont differentiate what is wired to it. all it will do is send an output of whatever you set it to in the code.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 04-12-2012, 02:17 PM
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
Rookie Year: 2011
sand500 is an unknown quantity at this point
You might want to try the servo class. I believe we got the motor to turn with the servo class. But we were also using the vex speed controller.
Unread 04-12-2012, 04:27 PM
nyaculak nyaculak is offline
FRC #0053 (Area 53)
Rookie Year: 2011
nyaculak will become famous soon enough
I believe you can either control it with the Victor or Jaguar class. I believe it is also possible to control it by creating an instance of the PWM class.
2013 MUC DC 3rd Place, FRC DC Regional, FRC Chesapeake Regional
2012 FRC DC Regional, FRC Chesapeake Regional
ERHS Robotics Club
- FRC Team 53 "Area 53"
www.erhsroboticsclub.org
Unread 04-12-2012, 04:38 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
The Victor class would be correct as the VEX controller PWM timings match those of the Victor. The Jaguar uses different timings. You could certainly use the PWM class and specify the timings yourself but it would be extra work to do so.
Unread 04-12-2012, 05:45 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The update rate for the victor in the control system is 100hz, which is beyond spec but works. However, I'd be hesitant to recommend it for the 393 without testing it. The servo class uses the more conservative 50hz.
Have you tried it?
Unread 04-12-2012, 05:56 PM
Originally Posted by Joe Ross View Post
Have you tried it?
I have, however I didn't do extensive testing to verify that I was actually seeing the free speed at max signal in either direction. The Servo class would certainly seem to be the safer choice.
