Go to Post [on practice robots:] Twice the work and twice the practice building seem to equal twice the experience so far. - MrBasse [more]
Unread 15-03-2012, 20:02
Suitster's Avatar
Suitster Suitster is offline
AKA: Ethan Pellittiere
FRC #3951 (SUITS)
Rookie Year: 2012
Suitster is on a distinguished road
Adjusting motor speed with battery charge
During regionals, our encoders fried due to them not being able to handle the speed of our throwing wheels.
In lieu of encoders, is there a way to adjust the speed of a motor from the battery voltage so the motor spins at the same general speed, even if the battery is low?
Unread 15-03-2012, 20:09
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Adjusting motor speed with battery charge
If you are using Jaguar speed controllers via CAN bus, you can use Voltage mode command. The Jag will automatically adjust its PWM output to the motor to to provide the commanded voltage (unless of course the available voltage drops below the command).
If you're not using CAN bus, you can read the battery voltage and adjust your command accordingly.
Unread 15-03-2012, 20:56
DonRotolo's Avatar
Back to humble
FRC #0832
However, in general, if you want to control something (like the speed of a motor) you would use a sensor to measure that something.
Unread 15-03-2012, 20:55
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Does this help? http://www.chiefdelphi.com/forums/sh...9&postcount=17
Mentor http://www.teamtitanium.org/
