GetLocation() or GetAlliance()
Hello,
I am wondering how to use either of the two functions (GetLocation() or GetAlliance()) whic gets the location or alliance off of the Driver Station. I want to make it so that I can have 2 or more different autonomous'. How would I fully implement this? Thanks, Davis |
Re: GetLocation() or GetAlliance()
You can actually read the joysticks during disabled. I setup a snippet of code this week to read the driver joystick and check if the trigger is held for 3 seconds, and switch to a different autonomous routine.
For reference, here's that chunk out of my code Code:
static Timer button_combo_timer;
if (BUTTON_COMBO_SWITCH_AUTONOMOUS() == true)
button_combo_timer.Start();
else
button_combo_timer.Reset();
button_combo_timer.Stop();
if (button_combo_timer.Get() > 3.00)
switch (autonomousMode)
case AUTONOMOUS_MODE_1:
autonomousMode = AUTONOMOUS_MODE_2;
break;
case AUTONOMOUS_MODE_2:
autonomousMode = AUTONOMOUS_MODE_3;
break;
case AUTONOMOUS_MODE_3:
autonomousMode = AUTONOMOUS_MODE_1;
break;
default:
driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 1");
break;
driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 2");
break;
driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 3");
break;
driverStationLCD->UpdateLCD();
Interesting, where would I place that to read it before a match?
Thanks |
If your using iterative robot, in
Code:
void DisabledPeriodic(void){
