Auto Question
Just to make sure (because this is my first try at autonomous) would the structure presented in this picture enable the Shooter motor to start spinning at the beginning of auto and then the Window Motor 1 to spin 2 seconds after? Any advice is much appreciated!
Re: Auto Question
Yes you are all set to go. Just remember you can't do it like that if you want it to drive. Safety Config will make it stop. You would have to set the speed in a while loop, resetting it i'd say every 10 ms
Re: Auto Question
If you are looking to update Drive motor values, you may disable your Safety config if you so choose. If you'd prefer to keep it enabled, be sure to update the motors every 20ms. Any longer and you'll be disabled by Watchdog.
Re: Auto Question
Thanks a bunch guys!
