Go to Post We are customers to FIRST. In that comes expectations. I don't want to hear another, "You should be grateful for everything FIRST does" nonsense when FIRST royally screws up. - MikeDubreuil [more]
Unread 16-03-2012, 23:36
FlyingMonkeys FlyingMonkeys is offline
FRC #0771
FlyingMonkeys is an unknown quantity at this point
Graphing information on smartdashboard?
We were wondering if it was possible to receive multiple pieces of information (i.e. encoder rate [rpm]) and graph them into an rpm / time graph without having to system.out.print every single encoder value that comes up then manually going into excel and plugging the numbers in? What would be an easy way to graph data on a line graph while you're receiving it? We are trying to see at what speed the rpm levels out when we set a motor speed to say, 30% of maximum speed.
Thank you!
