Go to Post Learn the ideas, look up the formulas. The other way round will drive you mad - Joe Johnson [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 16-03-2012, 23:48
FlyingMonkeys FlyingMonkeys is offline
FRC #0771
FlyingMonkeys is an unknown quantity at this point
Where IS PID code for Labview?
Hi guys! Sorry, yes, this is a very stupid question but it's been 45 minutes and I cannot locate the file for the labview already prepared PID code. Would anybody be able to point me in the right direction? I looked through all of the projects and templates and nothing says, PID.vi or anything along those lines? What am I missing?
Thank you very much!
Unread 17-03-2012, 00:50
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Where IS PID code for Labview?
In the upper-right corner of the Functions Palette (the thing you right-click and pick VIs from) is a Search Button. If you click it and enter the thing you are looking for, it will usually find it.
In the case of PID it will take you right to it. There is actually a PID sub-section. It's two lines above the WPI Robotics Library on my LabVIEW.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 17-03-2012, 01:01
Robobuff1.0's Avatar
Robobuff1.0 Robobuff1.0 is offline
FRC #1633
Robobuff1.0 is an unknown quantity at this point
Do you mean Examples if so its in the Getting started window>Support>Find Frc examples> and on the top right hand corner their should be a search tab click on
it and search pid. Their should be a list of pid examples like general pid simulator.vi hope that helps.
FRC: 1633
FTC: 2873
