Thread Tools |
Rating:
Display Modes |
SmartDashboard not streaming from M206
Hi CD,
We have been struggling with the camera stream to SmartDashboard. General info about our setup:
We had it working at Pittsburgh but ditched it because it was lagging the DS (assuming now that it was due to FPS being 30). I'll run through everything I can remember we've done to it.
We ended up crashing onto our camera in the quarterfinals. We nabbed another M206 from a friendly team in Milwaukee because our old camera doesn't seem to reset itself correctly. Anyway, the new one was reset and set up the same exact way as the old one. However, now I cannot get a stream with default settings or lower. TL;DR:
EDIT: Upon turning everything on this morning, it miraculously decided to work again... sigh. I did try restarting everything on Thursday but I guess it working again is a good thing. EDIT 2: After changing the FPS settings and power cycling, the stream is not going to the SmartDashboard again although we can go to it in a browser and ping it. It also worked one time yesterday before failing. Back to square 1! We're checking to see if it works at least once more with a full shutdown and reset of everything again. EDIT 3: We've determined that the cause of not working is changing the FPS setting of the M206. If the setting is anything except "Unlimited" or 30 (from the range of 10 to 30) the stream refuses to go through to the SmartDashboard. Does anyone have any ideas on how to lower the FPS while still being able to stream to SmartDashboard? Last edited by BigJ : 17-03-2012 at 11:46. Reason: Works now... |
