Go to Post Maybe between Art, skimoose, and some of the other intelligent folks on CD (most of us), we can force a redesign of the game.... - EricH [more]
Unread 18-03-2012, 21:11
bam-bam bam-bam is offline
Rookie Year: 2010
bam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond repute
Re: Stopping a Triple Balance
Originally Posted by dellagd View Post
I must say, this is my rookie year and all this strategy stuff is really interesting
I found this year to be one of the more difficult years for scouting, because of the (somewhat) heightened difficulty with shooting, and the importance balancing with the bridges. In addition, the cooperation bridge was an freakin' huge wrench thrown into a lot of teams' plans.
Last year and 2010 was pretty easy in terms of functions required, as you only needed two defining actions in order to win the regional (For 2010, it was kicking and raising yourself up on the towers, while 2011 was being able to put tubes on the wall and having a fast minibot.)
If you want to be able to defense OR balance, you need high traction.
Unread 18-03-2012, 21:12
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Well our team is using pneumatic tires, so this might work for us! This is cool...
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 18-03-2012, 23:29
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
Rookie Year: 2010
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
If you want to be able to balance, you need high traction.
Oh? All of the effective balancing alliances that I've seen have consisted of two or three teams--one or two that lower the bridge and get on, and one that pushes them up to balance. Only this last robot needs to have high traction...
Unread 19-03-2012, 00:51
kjmccarx's Avatar
kjmccarx kjmccarx is offline
FRC #1540
kjmccarx is an unknown quantity at this point
Sure, the strategy with having one team push up another robot or two works great. But only if two or more of the robots have short drive bases.
Our team has a robot that has high traction wheels. Our bot can make it up the bridge, and push people up with no problem - but we are a long robot. Because we're long we can't triple balance with ease. In the quarter finals in at the Autodesk Oregon regional we were beat by the only alliance that could triple balance. In such a situation it would have been necessary to have two of our alliance partners balance, while one of us defends the opposing alliance from getting the triple balance.
Has anyone seen a strategy that could prevent even ONE of the robots from getting on the bridge to turn a 3x balance into a 2x balance? This would make the final outcome of the match come down to the number of baskets - rather than only the team that can make a 3x balance.
Unread 19-03-2012, 03:28
College...
Rookie Year: 2010
Well, you could do what 118's alliance did and ram the third robot across the field, but that rarely works out perfectly. If you played your cards right, you could make sure that you don't have to face a triple balancing alliance, or you could make one yourself.
I love Rebound Rumble if only because it penalizes teams who choose to use the most common drive train configuration in FRC.
Last edited by ThirteenOfTwo : 19-03-2012 at 03:32. Reason: removed tantalizing hint
Unread 19-03-2012, 16:03
Rookie Year: 2010
You are correct.
Not quite.
I'm assuming that you are talking about double/triple balancing (if it was singular, then yes, the robot does not necessarily need high traction). From what I've seen in balancing, it usually comes down to the robots on either end. If you're pushing up two robots with something like mecanum, then what will you do when the bridge tips over to the other side? Back up slowly and risk tipping over the robot on the other end of the bridge (which I've seen was extremely likely) and lose the triple balance?
Unread 19-03-2012, 17:49
College...
Rookie Year: 2010
Not quite.
Many of the more effective triple balancers have robots with special attachments to help them balance. A mecanum, for instance, might have a "stinger" to stop the bridge from tilting too far in the other direction. Depending on the angle of the bridge I could definitely see a low-traction drive like a mecanum having the force to slowly push a higher-traction robot.
You're correct, though, that lower traction certainly would make balancing harder. Does anyone have video of a high-traction and low-traction combo trying to balance?
Unread 18-03-2012, 14:47
Yankeefan181's Avatar
Yankeefan181 Yankeefan181 is offline
1540 Co-Captain
AKA: Tucker
FRC #1540 (Flaming Chickens)
Team Role: Leadership
Yankeefan181 is a jewel in the roughYankeefan181 is a jewel in the roughYankeefan181 is a jewel in the rough
Originally Posted by sst.thad View Post
I saw 488 defend the triple balance in week 1. what they did is get inbetween the bridge and the robots trying to get up. it worked well, and actually stopped the triple that match.
I saw this match too, they were extremely effective at pushing the third robot into the fender and keeping them away from the bridge. Here's video
http://www.thebluealliance.com/match/2012stx_sf1m2
The strategy is to keep the third robot away from the bridge, while avoiding penalties. It sounds difficult, but it can be done, as seen here. Kudos to 488 and their alliance partners for putting together a smart strategy like that in week 1.
Tucker Gordon
Team 1540: The Flaming Chickens
Co-Captain
Drive Coach
Manager: Competitive Analysis
Co-Manager: Mechanical Engineering
Unread 18-03-2012, 18:40
JakeD's Avatar
JakeD JakeD is offline
FRC #0360 (The Revolution)
Rookie Year: 2007
JakeD will become famous soon enoughJakeD will become famous soon enough
This is essentially what I was saying earlier. At about the 1:45 mark you can see 488 push 922 into the corner like i was talking about. The difference is I believe with skillful driving you can essentially trap them there by forcing their driver to use less space to maneuver around you.
Unread 18-03-2012, 19:01
dellagd's Avatar
AKA: Griffin D
Rookie Year: 2011
So we dont believe there is a way to really defend if all robots are going onto the bridge from the side of the field on their alley?
Unread 18-03-2012, 19:22
George Nishimura's Avatar
George Nishimura George Nishimura is offline
Lurker
Rookie Year: 2007
George Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud of
You have to block them from getting to the alley.
Team 1884 - The Griffins (2007-2014)
Unread 17-03-2012, 22:02
deadman666's Avatar
deadman666 deadman666 is offline
JW
AKA: Jonathon Wilson
FRC #3487 (Earthquakers)
Team Role: Mechanical
Rookie Year: 2011
deadman666 can only hope to improve
My team, 3487, just compeated in the bmr here in Indiana, and I was wondering if it was leagal for another robot on the blue alliance to run into our robot on purpose? I ask this because this happened to us in the simi-finals and they pentilized us and caused an electrical blow out on our robot.
I've not failed, I've just found 10,000 ways that don't work.
Thomas A. Edison
If it ain't broke don't kick it!!
2012 Boilermaker Reginals Runner-ups
2011 Boilermaker Reginals Rookie Allstars
Unread 17-03-2012, 22:04
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
I would recommend that you check the rulebook (as well as a dictionary), but in general, running into another robot is allowed.
Does anyone else remember when TBA signatures actually worked?
Unread 17-03-2012, 22:09
deadman666's Avatar
JW
Rookie Year: 2011
not my fault for having the worst spelling on the planet, but thank you.
Thomas A. Edison
  #15   Spotlight this post!
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
That's quite off topic and there aren't enough details in your post to respond in your case. That being said there are many places in the rules this year where one robot could cause another to get a foul by pushing them into the opposing alliance's key, alley, or bridge.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
