Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Unread 17-03-2012, 21:35
Samk Samk is offline
Lead Builder
FRC #0619
Team Role: Mechanical
Rookie Year: 2010
Samk will become famous soon enough
bag and tag tear
Hi all,
We just got back from the VA regional, and one of our ratchet straps broke and attacked our bag through the tarp. This left a pretty significant hole, and some smaller ones. The first thing we did was take pictures, and then taped and ziptied the holes shut. First thing Monday we are calling FIRST to clarify what we should do from here. Has anyone else been in this situation before? Did we do the right thing? Also we are attending a second regional..
Unread 17-03-2012, 23:22
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: bag and tag tear
I feel like what you did was the right response. Get in contact with FIRST as soon as possible; try tomorrow, even if you don't think anyone will pick up, then at least you tried. Do you have an extra bag? Maybe consider putting the ripped-bag robot in it and tagging it up in the meantime.
We look forward to seeing you guys in DC!
Unread 18-03-2012, 09:06
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Sam,
Are the holes large enough that someone could suspect you worked on the robot through the bag? If they are the size of the hold down strap and abrasive holes from jostling around you shouldn't have an issue. If they are really large, the pictures and a second bag (over the first and tagged and recorded) should clear up all doubt. I would expect that First is going to recommend that same course of action but checking with them is the best alternative.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-03-2012, 16:15
Lead Builder
FRC #0619
Rookie Year: 2010
Thank you all for your insight! And Simon the feeling is mutual! I believe David was on your team at one time, he moved down here and is a great member of the team!
Unread 19-03-2012, 18:58
AKA: Simon Bohn
Rookie Year: 2010
He was indeed! Glad to hear he is having a good time, a reunion in DC will be fun.
