Go to Post What really matters is what you got out of the FIRST season, and how you can use it to build on what you know. - Adam Richards [more]
Unread 17-03-2012, 21:57
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
Rookie Year: 2012
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
driving with an xbox360 controller
Hello there! My team, 3753, just got back from our regionals, so naturally some of us have lots of thoughts and questions about plans for next year! Our current programmer is a senior and I'm going to be replacing him next year as (probably) our team's only programmer (it's a pretty small team -- about 12 people total).
This was my first competition so I went around asking all the questions I could think of, and one thing I was told was that in order to use an xbox 360 controller, you have to install a separate driver. What exactly is the driver, where can I get it, does it cost anything, what would I need to do to set it up, etc? Is it a file I just download and put somewhere and we're good, or does it make things entirely different from joysticks and the ps2-like controllers? Can you use a regular wired x360 controller (and a wireless with the wired attachment thing) or do you have to buy a special one?
P.S. If anyone has any advice on different types of controls (joysticks vs ps2-like controllers vs x360 vs who knows what else), that would also be greatly appreciated. Thanks!
Team 3753 BulahBots
Unread 18-03-2012, 12:11
amoose136's Avatar
amoose136 amoose136 is offline
FRC #3140 (The Flagship)
Team Role: Leadership
amoose136 is an unknown quantity at this point
Re: driving with an xbox360 controller
In labview controllers are treated just like joysticks and windows seems to auto install all the drivers you need when you plug in the controller. Just be aware that wireless controllers are not legal.
Unread 18-03-2012, 12:42
ctccromer's Avatar
Animus
Rookie Year: 2012
So I won't need to do anything? That's awesome What if I program the robot in c++ instead of labview? Is the connection window I saw everyone using labview no matter what the robot's programmed in?
I know wireless controllers are illegal, but is it legal to use a wireless controller attached wired with this? It treats it just like a wired controller and I could just use one of mine from home, but since we've never used controllers, we're unfamiliar with the rules.
Team 3753 BulahBots
Unread 18-03-2012, 13:48
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
1675 started using Xbox controller this year. I just put an inital commit of our code on Github last night (WARNING: SUPER GROSS, NEEDS CLEANING AND REORGANIZING). Here's a link to our wrapper class for the controller. We use Java but it is essentially the same for C++.
https://github.com/pordonj/frc1675-2...ontroller.java
Caveats:
  • The trigger buttons are their own axis. It stays at 0.0, one trigger makes it go up, one makes it go down. So you can't really tell whether a number is a mix of the 2 triggers or not. We don't use them on the robot right now but this code treats a push of the trigger as a boolean button based on whether the axis went up or down. If you use this the triggers will have to be pushed mutually exclusively for intended functionality. (If both are pushed the same amount, neither will evaluate to true).
  • The D-pad has left and right as an axis, and we couldn't seem to access the up/down D-pad buttons. Our code uses them like buttons because pressing the D-pad buttons makes the axis go to 1.0 / -1.0
  • We found it more intuitive to make up on the Y axis be positive, so all Y axes are flipped in this class.
  • We have an implicit 10% deadzone on all analog stick axes.
  • The "bumpers" are the shoulder buttons.
  • We didn't program in the Start/Back/Center(XBox Logo) buttons, I just realized.
Last edited by BigJ : 18-03-2012 at 14:05. Reason: cleaned up code a bit and realzied additional caveat
Unread 19-03-2012, 15:57
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Except it does not when you don't have the drivers. You need the standard xbox 360 driver from microsoft's website: http://www.microsoft.com/hardware/en...indows#support
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 19-03-2012, 23:01
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is on a distinguished road
I do not know anything about the xbox drivers. I believe that the logitech game pad on the andymark site will work fine.
And as far as coding. I believe LabVIEW and C++ treat it just like a Joystick and KNOW Java does, have worked with other Joysticks from many brands on it. (occasional glitch with some types, but overall great performance)
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
