Go to Post Being rude is easy. Being a compassionate human being takes work. - Joe Johnson [more]
Unread 19-03-2012, 17:17
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
pic: illegal or not?
Unread 19-03-2012, 17:18
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: pic: illegal or not?
So what is it exactly? Does the bumper represent your robot, or another robot?
Unread 19-03-2012, 17:38
adengler's Avatar
adengler adengler is offline
Mr. Dengler
AKA: Aaron Dengler
FRC #2090 (Buffnblue)
Rookie Year: 2007
adengler will become famous soon enough
Originally Posted by jsasaki View Post
jsasaki,
Is it some sort of bumper clamp? Need more details.
2090 BuffnBlue | Punahou School | Honolulu, HI
Unread 19-03-2012, 20:36
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Originally Posted by adengler View Post
jsasaki,
My guess is this is an appendage that extends to either top/bottom of the other bot's bumper plywood, thereby allowing the other bot to travel (or more likely be slowly pushed) to point where its COG is beyond the edge of the bridge (or at least prevent the bot from tipping when a couple wheels lose contact with the bridge)
If I'm right, you going to have to have a very trusting and willing partner to accept that this rig is the only thing hold them from falling a foot or two to the floor.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 19-03-2012, 21:01
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by badger3.14 View Post
we used white numbers with a black outline on out robot and we passed bumper inspection easily.
Originally Posted by Daniel_LaFleur View Post
You should not have passed inspection. Don't expect to pass if you go to another regional or the champs.
It depends on the stroke width of the white part - if 3/4" or more, then it would be OK IMHO.
Unread 19-03-2012, 17:45
Actually, I'd be worried about the bumper number rules. They must be white, or outlined in white. Those are white&black and the white is not the outline color. Also, from a rough guess, I'd say the white portion is not a 3/4" stroke assuming the numbers are 4" tall, and the black wouldn't count since it has hardly any contrast with the red so it does not add to readability.
John Vriezen
Unread 19-03-2012, 17:57
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
If that is a clamp that you put out as an appendage and it is not over 14" from your frame... it is probably ok but remember that many robots have different bumper heights... not much... but a little... and this would not work..if it clamps from both sides..
There is no rule that says you may not clamp onto an alliance partner.
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 19-03-2012, 18:33
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Also, clamping to a robots bumper wont be much of a sure thing.
I imagine that many teams bumpers weren't attached to the chassis with load bearing in mind.
Unread 19-03-2012, 18:38
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
Team Role: Mechanical
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
Are they that strict on the bumpers nowadays? They're definitely white.... and very legible.
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
Unread 19-03-2012, 18:43
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Yes, they're that strict -- either they follow the rules or they don't pass inspection. Lots of teams have had bumper issues trying to pass inspection this year.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 19-03-2012, 18:57
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
One of the more common parts requests on Thursday at the Chesapeake regional was "Team X is looking for white fabric paint (and a brush)." Apparently a lot of people missed the whole number has to be white or outlined in white line that was different from last year.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 19-03-2012, 21:20
jyh947's Avatar
jyh947 jyh947 is offline
FRC #3322 (Eagle Imperium)
Team Role: Leadership
Rookie Year: 2010
jyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to behold
Here are the direct rules on the bumper text color rule:
2011: “<R09>...The numerals must be at least 4” high, at least in ¾” stroke width and in a contrasting color from its background...”
2012: “[R35] ...The numerals must be at least 4 in. high, at least ¾ in. in stroke width, and be either white in color or outlined in white...”
Eagle Emporium: We sell eagle-related products at 50% off!
2012 Rebound Rumble (Elset)
Website Award, Industrial Design Award, Regional Finalist - Kettering District
Website Award, Imagery Award, Regional Winner - Livonia District
2011 Logomotion (Cuddles)
Imagery Award - Ann Arbor District
2010 Breakaway (Seizure)
Rookie All Star Award, Highest Rookie Seed - Ann Arbor District
Rookie All Star Award - Troy District
Unread 19-03-2012, 19:31
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
If they're not a 3/4" stroke & 4" tall, redo them. I had a couple of robots that I inspected at GKC that had to re-do their numbers for this very reason. There may have been others. We also had a lot of other bumper issues that had to be corrected; the other big one was the 8" protection of corners.
Mentor http://www.teamtitanium.org/
Unread 19-03-2012, 19:39
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Yes, they are that strict.
This past weekend at the West Michigan District, the measurers informed us half way through the competition that we were not legal. Our bumper hardware and backing was good, but in the corners where the bumper fabric was folded, it touched their measuring jig (the jig was 2 inches high).
We interpreted the rule differently, in that we believed if a 2 inch jig could easily slide under our bumpers then we were legal. They disagreed, and said our bumpers couldn't touch the top of their 2 inch jig.
A half pound of staples later, out bumpers are aesthetically disgusting, but the fabric no longer brushed the 2 inch jig.
Live and learn.
  #15   Spotlight this post!
Unread 19-03-2012, 20:15
badger3.14's Avatar
badger3.14 badger3.14 is offline
AKA: Hayden
FRC #2512 (Duluth East Daredevils)
badger3.14 is an unknown quantity at this point
