Go to Post Our robotics lab has been closed for two days, TWO DAYS! :ahh: - Kevin Selavko [more]
Unread 20-03-2012, 16:53
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Programming Pneumatics in Labview
Hello,
Here is our problem:
We have a pneumatic system setup with 1 compressor, 1 pressure switch, and 1 double solenoid.
How would I go about programming so that the compressor will turn on at the cRIO boot and the solenoid would activate when I press a joystick button.
Also... the compressor is connected through a spike into relay 1 on solenoid breakout and the double solenoid is connected to relay 2 and 3 on the solenoid breakout. The pressure switch is connected to digital output 1 on the digital sidecar
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 20-03-2012, 18:43
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Programming Pneumatics in Labview
I think you mistyped and really have the compressor Spike wired to Relay 1 on the Digital Sidecar, not far from the pressure switch that's in DIO 1.
The spike does NOT plug into the solenoid breakout, only the solenoids do that.
To run the compressor:
To fire the solenoid:
Unread 20-03-2012, 18:51
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
So to clear up wiring
Compressor- wired to a spike relay...connected to relay 1 on digital sidecar
Pressure switch- wired to DIO 1....is this is a pwm cable with the middle (power) disabled?
Double Solenoid- Wired with pwm??? to solenoid breakout on cRIO
Unread 20-03-2012, 19:19
Just Itinerant
Yes
Yes
This only uses two pins, so you don't use a regular 3-pin PWM cable for this. There were 2-pin cables include in the KOP that you can cut in half to make two 2-pin solenoid connectors.
