Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Unread 21-03-2012, 00:14
Brandon_L Brandon_L is offline
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Ring light not bright enough in camera feed
Hey all-
Last week we bought a red 60mm ring light from superbrightleds.com. We wired it up, and before we mounted it to the robot we looked through the center hole and found that the targets were lighting up a bright blood red. Yet when we mounted it around the camera (the lens is looking through the center of the ring, just as our eyes were) and we look at the camera feed, the targets are only barley tinted red.
Has anyone else had this problem with any other colors? Is there a fix? Im thinking about buying a second (Green? Blue?) light for lenape this weekend. Quick replies would be awesome. Thanks!
EDIT: 12v directly out of the PD board
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 21-03-2012, 00:24
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Ring light not bright enough in camera feed
I haven't seen anybody use red lights. Possibly for that reason.most teams use green. We are using blue LED's. And they are perfect. But they are the LED strips from super brought LEDs. I would go with green our blue.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 21-03-2012, 00:42
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Our team chose to use IR LEDs and put a filter over the camera lens to only allow IR light... it seems to work quite well...
You might try this... it isn't too difficult... you just need an IR source.
We use an IR source meant to be used with a security system...and the filter is a camera filter...taped over the camera lens...
it seems to work quite well... the reflective tape really pops out..
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 21-03-2012, 02:12
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
If you play with the settings of the camera (especially lowering the exposure) you can probably get the image to stand out much more. However, as stated before, I believe that on superbrightleds.com it stated that the green rings had the greatest luminosity.
www.sharkattack744.com
Unread 21-03-2012, 02:36
grimmcoder's Avatar
grimmcoder grimmcoder is offline
grimmcoder
AKA: Justin Grimm
FRC #2046 (Bear Metal)
Rookie Year: 2007
grimmcoder is an unknown quantity at this point
What we use is three Green Rings of 3 different sizes in a ring around our camera. But then we set adjust the exposure and WAY over expose our camera image. ALL we get is super green tape rectangles.
http://sn124w.snt124.mail.live.com/a...UvanBlZw_3d_3d
Unread 21-03-2012, 03:31
AKA: Brandon Liatys
Rookie Year: 2007
How do you lower the camera exposure? Is it in the vision processing vi? camera settings in the browser?
Were using labview, I noticed (I have the classmate here) that our hue wheel is pointing at green. Does this effect the non processed image? If I set it to red would it appear brighter/better?
EDIT: Found it, but I'm not quite sure what it should be set to
Unread 21-03-2012, 09:25
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
While the human eye can see red OK (remember the old submarine movies switching to red light before surfacing) the camera is a little different. The camera has a greater sensitivity to green since the human eye has the greatest in that spectrum as well. There is a paper from Axis that describes how color cameras generally have twice as many green sensors as either blue or red.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-03-2012, 11:35
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
At the Sacramento regional, there were several teams successfully using red lights.
Have you had an opportunity to set the camera's White Balance for the lighting environment you are in? If left to auto, the camera will actually adjust it's self to a point where the red light is almost white. In White Balance auto mode, the camera constantly tries to adjust it's self to present a color balanced image. If there is a large amount of one color, ie. your red targets, it will push the White Balance toward the blue end of the spectrum, thus reducing the color saturation on the red end.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 21-03-2012, 11:46
To parrot the advice given here. I'd first calibrate the exposure using the following procedure. Set the exposure to auto, point the camera at a bright light -- flashlight or overhead light. Wait a few seconds for the camera to change its exposure. Set the exposure to Hold.
Next, you should change the white balance from auto to one of the ones built in. Play with the indoor and outdoor ones to see which results in the most saturated red color.
I typically do this in vision assistant. Feel free to post photos and it may be easier to diagnose.
Greg McKaskle
Unread 21-03-2012, 14:44
AKA: Brandon Liatys
Rookie Year: 2007
Greg McKaskle
My understanding was that exposure is set in the begin.vi, I don't know how you can just switch the settings while the camera is running. Also, you mentioned changing the white balance from auto to something like indoor. Again, when I look in the begin.vi, those settings (indoor, auto, ect) are plugged into the exposure.vi, I do not see anything about white balance.
Is there a simple way to set this up? Is that what vision assistant does, give me settings to use in the program for the camera?
Unread 21-03-2012, 14:47
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Exposure time, exposure time, exposure time. Set it to 1/120s or shorter. This is the single biggest "trick" there is to make the retroreflective targets pop out from the background.
Unread 21-03-2012, 18:32
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I'm curious what people's images look like with the very bright LEDs and messing with exposure times.
We used 6 blue LEDs, and did not change any camera settings, and got good results.
