Go to Post It's been said before--sports are fine and good, as long as you've got your priorities in the right order for you. - Billfred [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 21:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Blowing Relay Fuses
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/22/2000 8:56 AM MST
Has anybody else run into this problem? With the rotating light wired as per the documentation, as soon as we connect the battery, the 20A fuse on the relay blows. We've triple-checked all our wiring, and there doesn't appear to be any wires damaged or connected in a way that would cause problems. Any ideas?
Nate
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Blowing Relay Fuses
Posted by Tony K.
Student on team #292, PantherTech, from Western High School and DaimlerChrysler.
Posted on 2/22/2000 10:31 AM MST
In Reply to: Blowing Relay Fuses posted by Nate Smith on 2/22/2000 8:56 AM MST:
Open up the light housing and see if the positive terminal is shorting to the housing. Also, make sure it's mounted on Lexan or something else to insulate it from the robot body (ground fault, maybe?). Have you tried another spike?
Tony
#0047 (ChiefDelphi)
Posted on 2/22/2000 11:40 AM MST
In Reply to: Re: Blowing Relay Fuses posted by Tony K on 2/22/2000 10:31 AM MST:
We've tried a few different spikes, and about 10 fuses so far...I actually called Eric earlier today, and he mentioned making sure we didn't have a ground fault, but didn't say anything about checking inside the housing...I'll pass this along to our pit crew, still hard at work tweaking the machine...luckily(?) the drayage site for our first event(Great Lakes) is just on the other side of town, so we can just drive it over there.
Nate
[IMG] code is Off
20 amp fuses for Spikes Andrew Schuetze Electrical 8 01-04-2003 22:18
Wiring the relay for the pnumatics Placebo OCCRA 3 05-11-2002 23:04
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
Triping Timed Fuses Joe Canavan Electrical 2 21-02-2002 09:34
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
