Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Unread 22-03-2012, 01:20
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Digital Side car short
Hi what ended up happening was that there was a short at the plug of the incoming 12v source to the DSC but now on my the battery light turns on and the 5v and 6v lights won't. I know that everything else works because I swapped our the DSC for another and it worked. But I simply don't want to trash it if it has a fix. I have a multimeter, ( even though I don't know how to use it) im a programmer not an electrician but my soldering skills are pretty good so could it be possible to find the bad component and replace it?
