Go to Post Since our team is in possession of the school, we have no restrictions on how late we can be there. So our teams are often practicing into the wee hours of the morning. Also, the school board uses "the breeze" for storage of high jump mats, so it's a great place to nap. :) - Karthik [more]
Unread 03-22-2012, 10:32 AM
Team1605 Team1605 is offline
FRC #1605
Team1605 is an unknown quantity at this point
Help !!!!
i need serious help how can i get the buttons to work on my joystick how do i program it ??? here is my code is it correct ??
Code:
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Joystick.AxisType;
import edu.wpi.first.wpilibj.*;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SimpleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Team1605 extends SimpleRobot {
    Joystick stickDriverLeft = new Joystick(1);
    Joystick stickDriverRight = new Joystick(2);
    Jaguar leftMotor = new Jaguar(2);
    Jaguar rightMotor = new Jaguar(1);
    Jaguar shooterMotor1 = new Jaguar(3);
    Jaguar shooterMotor2 = new Jaguar(4);
    Jaguar gatherMotor1 = new Jaguar(5);
    Jaguar gatherMotor2 = new Jaguar (6);
    RobotDrive robotDrive = new RobotDrive(leftMotor,rightMotor);
    Shooter shooter = new Shooter(shooterMotor1,shooterMotor2);
    Gatherer gatherer = new Gatherer(gatherMotor1, gatherMotor2);
    final int TRIGGER_NUMBER = 1;
    final int GATHER_START_BUTTON = 2;
    final int GATHER_STOP_BUTTON = 3;
     * This function is called once each time the robot enters autonomous mode.
    public void autonomous() {
     * This function is called once each time the robot enters operator control.
    public void OperatorControl() {
        while(isOperatorControl() && isEnabled())
        robotDrive.tankDrive(stickDriverLeft.getAxis(AxisType.kY), stickDriverRight.getAxis(AxisType.kY));
        if(stickDriverRight.getRawButton(TRIGGER_NUMBER)) {
           shooter.set(1);
        else {
            shooter.set(0);
        if(stickDriverRight.getRawButton(GATHER_START_BUTTON)) {
            gatherer.set(1);
        else if(stickDriverRight.getRawButton(GATHER_STOP_BUTTON)) {
            gatherer.set(0);
        Timer.delay(.01);
Unread 03-22-2012, 01:02 PM
2869Robotics 2869Robotics is offline
FRC #2869
2869Robotics is an unknown quantity at this point
Re: Help !!!!
The way that you have your trigger set up. As long as you hold the trigger down the shooter will be set at 1 but if you let go of the trigger it will be set back at 0. Do you want the trigger to toggle the shooter on and off?
Unread 03-28-2012, 01:37 PM
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Re: Help !!!!
Can someone posta code for a toggle button or for an array of buttons that can change speeds with a press, not held down? This would be very help!
Thank you and Happy Competition!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 03-28-2012, 03:23 PM
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Help !!!!
Both toggle and cycle buttons are based on a button "press" instead of just being held down. To detect when a button is pressed:
Code:
// outside the "checking" loop
boolean prevState = false;
// inside checking loop; can be within continuous or periodic
boolean currentState = joy.getRawButton(DESIRED_BUTTON);
if(currentState && !prevState) {
    // Button DESIRED_BUTTON is newly pressed
    // Do stuff here
prevState = currentState;
To do a toggle, have an extra boolean (e.g. tracking), then when the button is pressed:
Code:
tracking = !tracking;
To do a cycle, have an int (e.g. basketChoice) and do this on button pressed:
Code:
basketChoice = (basketChoice+1)%NUM_CHOICES;
Unread 03-28-2012, 03:52 PM
FRC #1605
Re: Help !!!!
i need help. in tank drive one of my wheels keep spinning and the other responds properly with one joystick.MY SHOOTER GATHERER AND BRIDGE HAND WORK. how can i fix this. this is my code :
Code:
/* the project.                                                               */
 * directory.
    Victor bridgeHandMotor = new Victor(7);
    BridgeHand bridgeHand = newBridgHand(bridgeHandMotor);
        robotDrive.tankDrive(stickDriverLeft.getAxis(Joystick.AxisType.kY), stickDriverRight.getAxis(Joystick.AxisType.kY));
        if(stickDriverRight.getButton(Joystick.AxisType.kTrigger)) {
           shooter.set(1);
        else {
            shooter.set(0);
        if(stickDriverLeft.getButton(Joystick.ButtonType.kTrigger)) {
            gatherer.set(1);
        else {
            gatherer.set(0);
            bridgeHand.set(stickDriverRight.getAxis(Joystick.AxisType.kX));
Timer.delay(.01);
Unread 03-28-2012, 11:59 PM
Student
AKA: Marco Schoener
Re: Help !!!!
Code:
What can this do? Could this be used to add a ball count to the robot.
Team 1369
Senior
Head Electrician
Unread 03-29-2012, 10:20 AM
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
Re: Help !!!!
This is called modular arithmetic. You probably don't want to use that particular method for counting balls, because if, for example, your NUM_CHOICES were 3, then as balls enter the count would go 0,1,2,0,1,2, instead of 0,1,2,3,4 as they entered and 4,3,2,1,0 as they left.
