Build Problems
We are trying to get netbeans set up for programming on a new computer. Our code is used on other computers and is compiling without a problem, however when I try and compile the code on this computer I get the following errors:
Code:
init:
Deleting directory C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\build
clean:
Created dir: C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\build
Compiling 13 source files to C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\build
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\AccelerometerController.java:7: error: cannot find symbol
import edu.wpi.first.wpilibj.ADXL345_I2C;
symbol: class ADXL345_I2C
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\AccelerometerController.java:17: error: cannot find symbol
private ADXL345_I2C accel;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonController.java:2: error: cannot find symbol
symbol: class Joystick
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonController.java:5: error: cannot find symbol
import edu.wpi.first.wpilibj.Relay;
symbol: class Relay
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonController.java:6: error: cannot find symbol
import edu.wpi.first.wpilibj.Victor;
symbol: class Victor
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\MagnetEncoder.java:5: error: cannot find symbol
import edu.wpi.first.wpilibj.AnalogChannel;
symbol: class AnalogChannel
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\MagnetEncoder.java:6: error: cannot find symbol
import edu.wpi.first.wpilibj.PIDSource;
symbol: class PIDSource
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\MagnetEncoder.java:7: error: cannot find symbol
import edu.wpi.first.wpilibj.SensorBase;
symbol: class SensorBase
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\MagnetEncoder.java:13: error: cannot find symbol
public class MagnetEncoder extends SensorBase implements PIDSource {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonSystem.java:3: error: cannot find symbol
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonController.java:43: error: cannot find symbol
public void init( Joystick joy, Joystick joy2 ) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonController.java:79: error: cannot find symbol
private Relay lifterRelay = new Relay( 7 ); // For tester robot
symbol: class Relay
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonController.java:129: error: cannot find symbol
private Relay bridgeMotor = new Relay( 8 );
symbol: class Relay
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\MagnetEncoder.java:35: error: cannot find symbol
private AnalogChannel m_Channel;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonSystem.java:10: error: cannot find symbol
Joystick m_joystick;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\ButtonSystem.java:14: error: cannot find symbol
public ButtonSystem(Joystick joystick, int buttonNumber) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\CameraTurret.java:6: error: cannot find symbol
import edu.wpi.first.wpilibj.Servo;
symbol: class Servo
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\CameraTurret.java:13: error: cannot find symbol
private Servo m_Servo1;
symbol: class Servo
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\CameraTurret.java:14: error: cannot find symbol
private Servo m_Servo2;
symbol: class Servo
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DashboardController.java:7: error: cannot find symbol
import edu.wpi.first.wpilibj.DriverStationLCD;
symbol: class DriverStationLCD
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DashboardController.java:14: error: cannot find symbol
private DriverStationLCD driverLCD;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:9: error: cannot find symbol
symbol: class IterativeRobot
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:10: error: cannot find symbol
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:11: error: cannot find symbol
import edu.wpi.first.wpilibj.RobotDrive;
symbol: class RobotDrive
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:12: error: cannot find symbol
import edu.wpi.first.wpilibj.Solenoid;
symbol: class Solenoid
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:13: error: cannot find symbol
import edu.wpi.first.wpilibj.Timer;
symbol: class Timer
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:14: error: cannot find symbol
import edu.wpi.first.wpilibj.Watchdog;
symbol: class Watchdog
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:16: error: cannot find symbol
import edu.wpi.first.wpilibj.Encoder;
symbol: class Encoder
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:17: error: cannot find symbol
import edu.wpi.first.wpilibj.Counter;
symbol: class Counter
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:19: error: cannot find symbol
import edu.wpi.first.wpilibj.PIDController;
symbol: class PIDController
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:21: error: cannot find symbol
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:22: error: cannot find symbol
import edu.wpi.first.wpilibj.Gyro;
symbol: class Gyro
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:24: error: cannot find symbol
import edu.wpi.first.wpilibj.Jaguar;
symbol: class Jaguar
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:26: error: cannot find symbol
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:82: error: cannot find symbol
public class DefaultRobot extends IterativeRobot {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:85: error: cannot find symbol
RobotDrive m_robotDrive; // robot will use PWM 1-4 for drive motors
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:88: error: cannot find symbol
ADXL345_I2C m_accel;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:89: error: cannot find symbol
Gyro m_Gyro;
symbol: class Gyro
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:93: error: cannot find symbol
Joystick m_rightStick; // joystick 1 (arcade stick or right tank stick)
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:94: error: cannot find symbol
Joystick m_leftStick; // joystick 2 (tank left stick)
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:101: error: cannot find symbol
Solenoid[] m_solenoids = new Solenoid[NUM_SOLENOIDS];
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:112: error: cannot find symbol
Jaguar m_oLeftShooterMotor;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:9: error: package edu.wpi.first.wpilibj.fpga does not exist
import edu.wpi.first.wpilibj.fpga.tCounter;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:10: error: package edu.wpi.first.wpilibj.util does not exist
import edu.wpi.first.wpilibj.util.AllocationException;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:11: error: package edu.wpi.first.wpilibj.util does not exist
import edu.wpi.first.wpilibj.util.CheckedAllocationException;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:19: error: cannot find symbol
public class PIDCounter extends SensorBase implements CounterBase, PIDSource {
symbol: class CounterBase
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:114: error: cannot find symbol
PIDController m_oLeftShooterController;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:115: error: cannot find symbol
Jaguar m_oRightShooterMotor;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\DefaultRobot.java:117: error: cannot find symbol
PIDController m_oRightShooterController;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\TiltController.java:7: error: cannot find symbol
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\TiltController.java:8: error: cannot find symbol
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:55: error: cannot find symbol
private DigitalSource m_upSource; ///< What makes the counter count up.
symbol: class DigitalSource
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:56: error: cannot find symbol
private DigitalSource m_downSource; ///< What makes the counter count down.
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:59: error: cannot find symbol
private tCounter m_counter; ///< The FPGA counter object.
symbol: class tCounter
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:61: error: cannot find symbol
private static Resource counters = new Resource(tCounter.kNumSystems);
symbol: class Resource
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:95: error: cannot find symbol
public PIDCounter(DigitalSource source) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:133: error: cannot find symbol
public PIDCounter(EncodingType encodingType, DigitalSource upSource, DigitalSource downSource, boolean inverted) {
symbol: class EncodingType
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:166: error: cannot find symbol
public PIDCounter(AnalogTrigger trigger) {
symbol: class AnalogTrigger
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:209: error: cannot find symbol
public void setUpSource(DigitalSource source) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:231: error: cannot find symbol
public void setUpSource(AnalogTrigger analogTrigger, AnalogTriggerOutput.Type triggerType) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:231: error: package AnalogTriggerOutput does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:296: error: cannot find symbol
public void setDownSource(DigitalSource source) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:320: error: cannot find symbol
public void setDownSource(AnalogTrigger analogTrigger, AnalogTriggerOutput.Type triggerType) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\edu\wpi\first\wpilibj\PIDCounter.java:320: error: package AnalogTriggerOutput does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\TiltController.java:24: error: cannot find symbol
private Victor tiltMotor = new Victor( 7 );
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\TiltController.java:29: error: cannot find symbol
public TiltController( double tolerance, Joystick joy ) {
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\EncoderClass.java:3: error: cannot find symbol
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\EncoderClass.java:4: error: cannot find symbol
symbol: class Timer
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\EncoderClass.java:15: error: cannot find symbol
private Timer systemTimer;
symbol: class Timer
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\EncoderClass.java:17: error: cannot find symbol
private Encoder leftSide;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\EncoderClass.java:18: error: cannot find symbol
private Encoder rightSide;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:3: error: cannot find symbol
import edu.wpi.first.wpilibj.SimpleRobot;
symbol: class SimpleRobot
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:4: error: cannot find symbol
symbol: class Timer
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:5: error: package edu.wpi.first.wpilibj.camera does not exist
import edu.wpi.first.wpilibj.camera.AxisCamera;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:6: error: package edu.wpi.first.wpilibj.image does not exist
import edu.wpi.first.wpilibj.image.BinaryImage;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:7: error: package edu.wpi.first.wpilibj.image does not exist
import edu.wpi.first.wpilibj.image.ColorImage;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:8: error: package edu.wpi.first.wpilibj.image does not exist
import edu.wpi.first.wpilibj.image.CriteriaCollection;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:9: error: package edu.wpi.first.wpilibj.image.NIVision does not exist
import edu.wpi.first.wpilibj.image.NIVision.MeasurementType;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:10: error: package edu.wpi.first.wpilibj.image does not exist
import edu.wpi.first.wpilibj.image.NIVisionException;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:11: error: package edu.wpi.first.wpilibj.image does not exist
import edu.wpi.first.wpilibj.image.ParticleAnalysisReport;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\RoboCon.java:12: error: package edu.wpi.first.wpilibj.image does not exist
import edu.wpi.first.wpilibj.image.RGBImage;
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:3: error: cannot find symbol
symbol: class Timer
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:4: error: package edu.wpi.first.wpilibj.camera does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:5: error: package edu.wpi.first.wpilibj.image does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:6: error: package edu.wpi.first.wpilibj.image does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:7: error: package edu.wpi.first.wpilibj.image does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:8: error: package edu.wpi.first.wpilibj.image.NIVision does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:9: error: package edu.wpi.first.wpilibj.image does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:10: error: package edu.wpi.first.wpilibj.image does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:11: error: package edu.wpi.first.wpilibj.image does not exist
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:17: error: cannot find symbol
private static AxisCamera m_oCamera; // the axis camera object (connected to the switch)
symbol: class AxisCamera
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:18: error: cannot find symbol
private static CriteriaCollection cc; // the criteria for doing the particle filter operation
symbol: class CriteriaCollection
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:46: error: cannot find symbol
private ParticleAnalysisReport[] m_arReports;
symbol: class ParticleAnalysisReport
C:\Users\Wesley\Documents\Robotics\Code\ReboundRumbleJava\src\Robot\Vision.java:125: error: cannot find symbol
synchronized ParticleAnalysisReport[] ParticleReports() {
100 errors
C:\Users\Wesley\sunspotfrcsdk\ant\compile.xml:48: Compile failed; see the compiler error output for details.
BUILD FAILED (total time: 1 second)
Dell Vostro 3550 Windows 7 Professional 64-bit Processor: Intel i5 2410M Network Card: Intel Centrino Wireless N 1030 Video Card: AMD Radeon HD 6630M I'm using Netbeans 6.9.1, the latest versions of the plugins, and JDK1.7.0. I have tried re-installing NetBeans, the FRC plugins, and also the JDK. Same error. I have also tried building the example projects in NetBeans, they compile fine, so the error would seem to be with our code, however our team uses Mecurial to back up our code and keep everyone with the latest version, and the code works on our other two programmer's computers, making that theory less valid. Is there something I'm missing? Have I set something up incorrectly? I am at my wit's end for this problem. Any help or insight would be greatly appreciated. Wesley Liao Team Captain 3660 |
