Go to Post Enjoy doing what you do. If you enjoy your life, what you're doing in it, and how you're living it, then what other people say or think doesn't matter. - Beth Sweet [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 25-03-2012, 04:23
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Bag-n-Tag and Crate Shipping
In the last couple of years, we've only had to crate our bot from event to event (i.e. not bag-n-tag); and our team would physically bolt our bot frame onto the bottom of the crate (onto the crate's superstructure) to keep it from shifting during shipment... Our team has competed in bag-n-tag events this year so far - and now we are competing at CMP this year.
We are exploring our options since we can't bolt our bot into the frame thru our bag - without ripping holes in the bag in order to do it. We thought about clamping it down (on top of the bag) or strapping it down (over and around the bag), etc. I am just wondering how you folks are doing something like that to keep your bot from being scrambled in the crate.
Thanks!
Unread 25-03-2012, 04:46
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Bag-n-Tag and Crate Shipping
We've always lashed ours down with ratchets, with or without bag. Just bolt a few u bolts to where you want to lash too (four points on the bottom usually works for us) and do up the ratchets nice and tight.
We like to try and get weight off wheels with some blocks or chocks, but in the past year we forgot, but our robot came out fine anyway.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 25-03-2012, 07:43
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
We build corner brackets that fit tight against the frame. Literally two sides shaped as a L and a triangle covering the top.
We slip the robot into the two back ones and then screw the front ones in. You can do this with the bag in place with no issues.
Blue Shirt Alaska Pics here and Amsterdam pics are here!!! and Puffin Pics
Unread 25-03-2012, 09:11
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Last year when we went to champs we were in a similar situation. We ended up bolting through the bag - 4 bolt-sized holes aren't really a problem in the bag, especially since you can explain the need for them to the inspectors. Note that we didn't rip the bag first - list laid it flat on the frame an pushed the bolt through it.
Unread 25-03-2012, 10:26
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We did the same as the others in this thread.
We built an "H" shaped 2x4 frame to set the robot up on that frame inside the crate. This got the weight off the wheels. In each corner of the crate at the bottom is an eye bolt. We used ratchet straps to strap over the robot with some foam pieces to the eye bolts in an "X" pattern.
It was very difficult to get the robot in the crate with a bag, and very difficult to find a place to try and ratchet strap your robot down while in the bag as well. So good luck with that.
If bag and tag is successful, hopefully Championship next time will be bag and tag too. That would be great.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 25-03-2012, 14:13
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Too many teams would get exemptions for it to be worth it. Teams come to the championship all over the world. Otherwise, the Championship would have been Bag & Tag this season as well.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 26-03-2012, 02:05
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
Rookie Year: 2011
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Just built our crate today. We installed a pair of 2x4s on the bottom (lag-screwed thru to the skids) to hold up the bot off its wheels, and strapped it down with ratchet straps to eyebolts on the 2x4s. The straps criss-cross over the top of the shooter. The bumpers are pressed tight against three sides of the crate as well. We'll see if she survives. It feels OK so far.
As could be expected, one of the eyebolts snagged the bag and ripped it as we put the bot into place. So remember to keep the bag out of the way!
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 26-03-2012, 08:42
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
You might consider putting a packing blanket over or around your bot before lashing it down so the straps don't rip or abrade the bag as you ratchet it down or from slight movement during shipment.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 26-03-2012, 08:44
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
Team Role: Leadership
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Does anyone know the drayage information for shipping to St. Louis? Last year it was conveniently on the CMP webpage. This year I can't find it anywhere on the FIRST site.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 26-03-2012, 10:35
ColleenShaver's Avatar
ColleenShaver ColleenShaver is offline
Asst Dir, WPI Robotics Resource Ctr
FRC #0190 (Gompei and the HERD)
Rookie Year: 1996
ColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of light
Send a message via AIM to ColleenShaver
Drayage info on Championship was emailed to teams competing there. If 78 needs it, just send me a message and I can get the doc to you.
Congrats on EI!
Colleen Shaver (Traitor) - Assistant Director, WPI Robotics Resource Center
FRC190 WPI/Mass Academy (2001-Present) :: FRC246 BU/O'Bryant School (2000) :: FRC126 Nypro/Clinton High (1996-1999)
Unread 26-03-2012, 10:46
AKA: Tom Dolan
Congrats on EI!
Thanks Colleen! We got the info now...all set. See everyone down in STL!
FRC78: 2010-Present
FRC121: 2002-2009
