Go to Post OK, repeat after me "FIRST is not about the robot". - Foster [more]
Unread 25-03-2012, 16:23
Clint Clint is offline
FRC #0308 (Monsters)
Rookie Year: 2011
Clint is an unknown quantity at this point
Bug in WPILib PIDController?
The following code excerpt is found in PIDController.cpp of revision 3111 of WPILib, on lines 128 through 141.
Code:
double potentialIGain = (m_totalError + m_error) * m_I;
if (potentialIGain < m_maximumOutput)
	if (potentialIGain > m_minimumOutput)
		m_totalError += m_error;
	else
		m_totalError = m_minimumOutput / m_I;
else
	m_totalError = m_maximumOutput / m_I;
m_result = m_P * m_error + m_I * m_totalError + m_D * (m_error - m_prevError);
In the lines of code above, a subtle problem exists, under a certain few specific conditions:
  • Output is restricted with a minimum or maximum of 0
  • m_I is 0
Under these instances, the first if statement fails (or, it continues through to the second inner statement which also fails). In both cases, the total error is calculated by dividing by m_I. When m_I is zero--a perfectly logical use case--m_totalError becomes NaN.
As a result, m_result becomes NaN as well. Subsequently, when PIDController::Calculate writes this value to the output, errors rapidly accumulate in the console.
Clint
Unread 26-03-2012, 11:41
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: Bug in WPILib PIDController?
You should file a bug at the WPILib tracker.
http://firstforge.wpi.edu/sf/tracker....wpilib_c_bugs
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 26-03-2012, 19:32
Rookie Year: 2011
Thanks. If anyone else is interested in following this issue, the artifact can be found here.
