Go to Post The game objectives are still the same, get boxes into your scoring zone, stack approximately half of them, run for the top of the ramp. So lets sit down, shut up, and start building robots. - ChrisH [more]
Unread 25-03-2012, 21:10
tonklep tonklep is offline
FRC #4302 (Robofins)
Rookie Year: 2010
tonklep is an unknown quantity at this point
CIM Motor+Arduino
I'm a new to running CIM or other high current motors with an arduino. I've been running FTC motors using regular TIP120 transistors but now i want to run CIM motors through my arduino mega. My question is, how do i run CIM motors with an arduino without using a jaguar or victor? also are there low costs or DIY motor controllers that are capable of running CIM's with PWM for speed control?
Tony K.
Mentor(2013-present) - FRC #4302
FRC Team #4302-Robofins (2011-2013)
FTC Team #5480 and #3216 (2009-2013)
Unread 25-03-2012, 21:13
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: CIM Motor+Arduino
You're going to need a pretty heavy duty speed controller to run a CIM. It's a powerful motor, and that power needs to be controlled somehow...and the Victor or Jaguar is a good way to do it.
Unread 25-03-2012, 21:19
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
You'll need an intermediary to do the job. Since you're just looking for basic motor control a Victor will do the job.
Unread 25-03-2012, 21:45
Rookie Year: 2010
Are there any lower cost motor controller that are capable of controlling CIM's?
Tony K.
Unread 25-03-2012, 21:47
MrForbes's Avatar
AKA: Jim
There might be, but I haven't found them yet.
It also depends on what you're doing with the motor. How much mechanical load are you putting on it? If it doesn't have to work hard, then you can possibly use a controller with a lower current rating...but you might have problems with it shutting down or burning up
Unread 25-03-2012, 22:17
LeadU2Fun LeadU2Fun is offline
AKA: Sam Alexander
FRC #1290 (Wolfgang Robotics)
Team Role: Teacher
LeadU2Fun is an unknown quantity at this point
We are using the Arduino for the underwater robotics competition we host (NURC). Here is a speed controller that will work that will control 2 motors. Need to look at the amps it can handle both continous and peak. This one does 12 amps continous and 25 peak per motor. Hope this helps at least as an example:
http://www.trossenrobotics.com/p/sab...er-for-RC.aspx
The CIMs can take a lot however. For example they are on the 40 amp auto reset circuit breaker. You will have to know your power requirements first. Just make sure also that the pwm signal of the controller and arduino are compatible. Here is another link to look through some speed controllers:
http://www.robotmarketplace.com/products/speed_controllers_main.html
Unread 25-03-2012, 23:14
Scimor5 Scimor5 is offline
AKA: Brett
FRC #4520 (Misfit Toys)
Rookie Year: 2011
Scimor5 is an unknown quantity at this point
You might look into rc hobby brushed motor controllers. I'm not sure if they will work since they are mostly designed for smaller faster motors (geared down for rock crawling if necessary), but i can imagine many would drive a cim.
Good luck from team 4520
Unread 26-03-2012, 05:47
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
FRC #0294 (Beach Cities Robotics)
Rookie Year: 1998
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Hi Tony,
High Power DC motor controllers are very complex and technical.
Your darlington bipolar TIP120 transistor 60v 5A continuous, 8A peak, is fine for small On/Off motor applications
..but NOT likely for a loaded CIM! (may work for unloaded CIM)
Note TIP120 has Vce sat of 4v @5A (Vdrop CE fully ON)
so 12.6-4v = 8.6v Max at motor.
TIP120 Power dissipation is an issue P=IV 5A*4v=20W*duty switch heat loss
(unavailable to motor) R=V/I 4V/5A = .8 ohm
FETs are easier to control and parallel to achieve very low 'on' resistance
.001 ohm achievable with a few paralleled. I^2 R = 25A*.001ohm =.025W*duty switching loss
Application detail determines design needs: how you intend to use CIM:
Fwd & Reverse? Just full or zero throttle=open or variable PWM?
Dynamic braking? Battery V supply for CIM? (12.6v as in FIRST?)
A simple switching transistor needs to safely handle a few hundred peak amps until your CB cycles without smoking plus handle inductive kickback from ~100-300 uHy inductance of commutating + PWM switched CIM, then when switch opens tolerate collapsing magnetic field of rotor's flyback voltage as it attempts to reach infinity Or until something breaks down from very high voltage else switch transistor will likely fail shorted!! Protective devices must be designed with ample margin to handle this repetitive energy stress. The TIP120 internal reverse diode provides some protection but requires an external fast supplemental diode for reliability.
Some considerations:
CIM zero to full throttle step draws 133A from 12.6V 18AH AGM.
The longer it takes to get up to speed the longer 133A load draw time
(Unloaded = shortest 133A instantaneous draw = ~.05s
then continuous current draw drops to ~3A NL forever)
(NL current draw directly relates only to mechanical friction loss = commutator + 2 bearings, [NL current is a measure of internal motor mechanical loss]
a zero mechanical friction CIM would spin at 5500 RPM drawing Zero current!)
Example: FIRST Robot Drive ~133A for ~.3 s in Low gear.. .5s high gear
Stalled CIMs draw 133A ea OR until 40A reset CB begins cycling at ~50A
circuit breakers by design HOLD at marked rating, opening/recycling after ~125% marked, opening quicker as over current amplitude increases, or fails to decrease (bi-metal thermal time constant) ref: CB data sheet
or ~2s at 133A & why many robots falter or 'pulse' when stalled or nearly so pushing against resisting robot or field barrier (or one side in stalled turn)
Victor contains reverse voltage protected low on-resistance 12 FET H-bridge
3 FETs are paralleled in each of 4 switched legs in diamond cfg,
Opposing corners wired to Batt +/- , remaining corners to motor +/-
Opposing switches act together, to provide fwd / rev,
then One "On" leg turns off periodically to coincide with PWM for speed control,
'Dynamic breaking' isolates battery while shorting motor in neutral
(or open motor for 'coast')
The Victor is a rugged, complex uControlled subsystem ~100 components converting a 1.5 millisecond 0-5v PWM control signal to 120Hz variable speed, high current, Reversible power to a high power motor at 13v 50A continuous allowing hundreds of amps peaks for hundreds of milliseconds for motor start-up from stationary, or full fwd to full Rev (= worst case stress as motor acts as generator adding to battery voltage, potentially drawing >133A for brief time)
Good luck Tony.
PM me if you have questions this degree of technical not likely to be of interest to general CD reader
