Go to Post I'm going through waves of excitment and panic all at the same time. - je2164 [more]
Unread 26-03-2012, 22:30
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Motors stop running in autonomous
We ran into a little issue with running motors in autonomous at the Palmetto regional. We know about the watchdog for the robot and the motor safetly timers. We disabled the watchdog and set the expiration timeout for the motors, but still sometimes the motors would shut off before the time was up. It seems to happen more on the fields than in the pits, but it did happen in the pit when tethered as well. Our code is similiar to this. I don't have access to it, the laptop is locked up at the school.
My question is if we set the expiration, can't the code delay that long before updating the drive setting? That is before the "drive isn't updated often enough" message?
This didn't always run the full 2 seconds:
Code:
myRobot.SetExpiration(6); // set MotorSafety expiration
myRobot.Drive(0.6, 0.0);
Wait(2.0); // wait 2 seconds while driving
myRobot.Drive(0.0, 0.0);
To get around this we implemented a loop that keept calling myRobot.Drive() for the time required. Something like:
Timer timer;
timer.Reset();
timer.Start();
while (timer.Get() < 2.0)
Brian K
Team 1225 Robotics Mentor
Unread 27-03-2012, 19:46
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: Motors stop running in autonomous
Yea - you may be getting bit by the automatic expiration.
Your re-vamp code looks better, but I'd suggest during your 'while()' that you also put a "Wait(0.1)" so that you're not in a total tight-loop situation which might cause other issues with other tasks on the cRio. I don't know of any such issues, but a tight loop isn't a good thing either.
Code:
Timer timer;
timer.Reset();
timer.Start();
  Wait(0.1);
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 28-03-2012, 00:25
SuperBK's Avatar
AKA: BrianK
Thanks, we did have the Wait() in the while loop, I just didn't remember to type it in when I was making the post.
Brian K
