Go to Post Its already begun folks...the Amanda you know is now one of us! mwahahahaha! - Andy Grady [more]
Unread 26-03-2012, 23:03
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Colson 101
Over the past few months I have been hearing a lot about these great wheels called Colson's. I have a few questions about them...
-Why are they so great? because I'm hearing a lot of "COLSONS ARE THE BEST" and I want to know why they are so good! These wheels sound amazing from what people have been saying!
-Which one's are the best to use? I've seen a lot of flat grey tread, are they the Encore wheels or the Performa Tread, I can't tell.
-How are team's mounting hubs on to them? I've herd of just press fitting a hub into the wheels them self's, like the ones sold on WCP. What are other effective ways to mount a hub to these guys?
-How price effective are they? cheap not cheap? Because on their site you have to get a quote on what you want to buy and I do not know what colson wheels are good for what?
Also if you have any other tips or tricks for colson's, they would be greatly appreciated.
Unread 26-03-2012, 23:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Colson 101
They're a little heavy but I like them. http://www.robotmarketplace.com/prod...on_wheels.html
All you have to do for a hub is take some aluminum round bar, turn it to size (for a press fit), knurl it, drill and ream it, part it off, and broach it, and press it in. If you do it right, the hub doesn't even need a flange on it;, just a straight cylinder through the wheel's bore.
They're not the absolute grippiest tire out there, but they grip rather well and wear well. They'll last all season long even driving on pavement, parade routes, demos, etc. The zero-maintenance aspect was my reason for using them last season. I'm over having to rivet on conveyor belt tread.
Just beware if you attempt to machine the wheels themselves. They may have small air pocket voids inside from the molding process.
Unread 27-03-2012, 07:36
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
Re: Colson 101
This is the second year FRC2168 is running Colson Performa wheels on our robot. We designed and manufactured our own hubs last year, and the second iteration of the design is what you see on the West Coast Products website. FRC2168's 2012 robot is running the WCP hubs and bearings, we were impressed with the quality of the machining and have had no issues thus far. This robot actually has a total of 11 Colson Performa wheels on it. 8 (5"x1.5") in the drivetrain, 2 (6"x1.5") for the shooter wheels, and 1 (4"x1.5") on the bridge manipulator. So they are also really grippy against this years game piece.
These hubs are designed to fit the 1.5" wide wheels. Last year we ran 4" wheels, this year we wanted some extra ground clearance and went with the 5" option. I can tell you that I don't intend to design a drivetrain without Colsons unless something major happens.
The WCP hub is designed for a 3/8" dead axle, and in the future WCP will most likely be offering a live axle option as well. The hubs allow you to put Colson wheels right onto a kitbot, which we believe is a great option and a really great way to evaluate the wheels for yourselves. If you want a live axle hub, its basically just "plug" with either a hex or key broach, and the OD sized for a press fit. They are a little heavier than other wheel options (pneumatic wheels are heavier though), but the cost is low, and 1 set should last you an entire season. That means no changing tread between matches.
Colson Performa wheels are available through a variety of sources, I've heard that a number of teams have gone to local suppliers. FRC2168 buys our wheels from Robotmarketplace.com. They are also available from McMaster and you'll get them faster but the price is not as good.
The performance of the wheels has been great. The grip is approximately the same as roughtop on carpet, but on other surfaces the Colsons have the advantage (like the bridges this year). Some teams have cut tread grooves into the surface of the wheels are report an increase in traction, however we have never seen a need for more traction (at least not yet).
Colson Performa wheels have been the wheel of choice in Battlebots for as long as I can remember. Teams such as 190, 228, 2168, 1771, 11, 125 have been using Colson wheels successfully for many years. More are more teams are looking at using them, and we welcome them to the club.
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 27-03-2012, 08:01
Adam Freeman's Avatar
Adam Freeman Adam Freeman is online now
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: Colson 101
How is the traction on the key and on the carpet with these wheel versus a standard AM performance wheel with rough top conveyor belting?
We have been having an issue of wheel slip on the key when we start to drive to the bridge, and I am wondering if these would provide better or worse traction and what the tradeoffs would be.
Thanks.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 27-03-2012, 08:06
AKA: Justin Foss
Re: Colson 101
Thanks.
Adam,
In our experience the Colsons out perform the roughtop conveyor on smooth surfaces including the key and the bridge. On the carpet they seem to be fairly equal. I strongly suggest picking up some for testing.
Unread 27-03-2012, 08:12
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Colson 101
Adam,
We are using Colson wheels for our two center wheels (one is dropped, one is raised). We found that the traction on polycarbonate and HDPE is much better than Roughtop, and quickly decided to use them over IFI wheels for the dropped wheel.
Kettering Motorsports
Unread 27-03-2012, 08:52
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Colson 101
Thanks.
We too have found that the grip the Colons have on the PC and HDPE portions of the field (bridge and key) to be awesome. We have known about Colson's performance characteristics on these types of surfaces for several years, which is what made using them this year a no brainer.
Cutting grooves into the wheels also has shown an increase in traction, to the point where I believe our Colsons will "out grip" any standard roughtop/wedgetop wheel in the same width (1.5").
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 27-03-2012, 08:56
Andrew Lawrence
Posts: n/a
Re: Colson 101
So on a standard 27x54 flat carpet field, what advantages will Colsons give over regular treaded wheel?
Unread 27-03-2012, 08:57
Forever HOT!
Re: Colson 101
Justin / Andrew / Brandon,
Thanks for the great information. I will pursue this option with the team to see if this will improve our performance consistency in Hybrid.
Unread 27-03-2012, 09:05
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Colson 101
Perhaps we should have kept HOT in the dark about this matter...
I'm also wondering about this, because the wheels my team has experience with are either 8" pneumatics from Granger, KOP grey tread wheels, mecanums, or the lunacy wheels. I'm not sure I could convince the team to switch to Colsons unless I could convey there is an absolute advantage to their use over other wheels, including fabrication of our own wheels.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 27-03-2012, 09:09
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Team Role: Leadership
Rookie Year: 2007
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: Colson 101
Has anyone tried a Colson on a swerve module?
Unread 27-03-2012, 09:11
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Re: Colson 101
Team 40 used them the last few years in their modules.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 27-03-2012, 09:13
Josh Drake's Avatar
Engineering Mentor
Rookie Year: 2007
Re: Colson 101
I would think there would be a wear and tear advantage over the treaded wheels with the side loads.
Unread 27-03-2012, 09:16
Re: Colson 101
The awesome swerve drive done by 3928 this year utilizes Colsons.
http://www.chiefdelphi.com/forums/sh...hreadid=104504
  #15   Spotlight this post!
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: Colson 101
Does anyone know where I can find a CAD model for these wheels? I know they're easy enough to make on my own, but I'm a stickler for detail.
