Go to Post FIRST robots are not six week projects. They are never ending projects where the requirements are changed on an annual basis. - ChrisH [more]
Unread 28-03-2012, 15:31
Pun-isher's Avatar
Pun-isher Pun-isher is offline
Gotta Go Fast
AKA: Shakeel Madhav
FRC #1759 (P.O.T.A.T.O.E.S.)
Team Role: Driver
Pun-isher is an unknown quantity at this point
Custom Bot Paintjobs
Over the years, our team has been trying to incorporate more machined pieces into our assemblies, and I have some questions concerning the machined pieces that many teams in the LA regional are rocking:
  1. Do teams rely on local sources to paint their machined parts?
  2. Are parts pre-painted before assembly, or vice versa?
  3. If we were to paint parts on our own, what would be the suggested medium to do so?
It may seem fairly trivial, but I've always believed that one should never underestimate the influential power of appearance to your teammates, your alliance members, and the opposing alliance. Thank you for your time.
Hey bro can you pass the 7/16ths wrench? I only need it for a second hold on...
Unread 28-03-2012, 15:45
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Custom Bot Paintjobs
You might consider having them annodized. That's what we've done the last couple of years.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 28-03-2012, 16:52
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Paint them? And ruin that beautiful machined finish? There are plenty of alternatives to painting, for example, powder coating and anodizing. To make our robot look good we use a belt sander to 'enhance' some of the more visible parts (like the aluminum angle on our shooter hood for example). This gives it a finish that makes it appear to shimmer* as the robot moves. If you really want to paint it, spray paint will probably give you results quickly and without adding too much weight. The time to paint is when the frame is done, all gears, sprockets, chains, treads, motors, wires, control system parts, pneumatics, electrical stuff, bushings, and bearings, among other things, should be either removed or masked off sufficiently (note: gears and sprockets can be painted, but they should be painted separately after being thoroughly de-greased and cleaned).
*(it is honestly more of a sparkle, but that word doesn't accurately convey how awesome it looks)
Unread 28-03-2012, 17:18
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
We usually paint/powdercoat our robots as soon as the components are made (usually not all holes are drilled but that's the way it always happens). In my opinion powdercoating is by far the best way to go. Powder coats are really tough and they usually only take a few hours.
This year we powdercoated our frames and spray painted the rest of the robot.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 28-03-2012, 20:41
Billfred's Avatar
Billfred Billfred is offline
I'm proud to say that 2815 has never competed with a bare-metal robot. The method we've used to achieve this has varied:
2009: Painted red at the district career center's auto body shop
2010: Anodized garnet in a shop in-state
2011: Wrapped in black gaffer's tape and garnet racing tape (yes, that's what it was sold as) in the pits
2012: Spray-painted flat black just outside our shop
In the years we've painted, 2009 and 2012, we painted the main assembly once it was put together for final assembly. In 2009, we removed our ball dumper and had just that painted; the unpainted C-Base drivetrain was nearly impossible to see behind the bumpers. In 2012, we decided to strip the entire robot down and painted all the structural metal (C-Base included).
2011's tape job was a back-up-and-punt move for lack of time in our shop; it was noticeable up-close, but from the distance the field mandates, it's pretty hard to tell. The tape also saved us time on filing, as it covered many rough edges. The paint came out so much better, but I'd do this if the alternative was a plain robot.
Unread 28-03-2012, 20:47
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Rookie Year: 2010
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
973 Powder coats all the big stuff, like frame members, usually in their assembled form. We anodize most our gearbox plates and gears individually.
We don't 'paint' ourselves because the shelf paint flakes off fairly easy and usually doesn't look as clean.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 28-03-2012, 22:31
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Alpine Robotics has just gone plain aluminum in the past, but this year we Wire wheeled every single part to give it a buffed look. In combination with the 5000+ holes in our frame it makes the robot look pretty slick from the stands.
Unread 28-03-2012, 22:48
badger3.14's Avatar
badger3.14 badger3.14 is offline
AKA: Hayden
FRC #2512 (Duluth East Daredevils)
badger3.14 is an unknown quantity at this point
Our robot is usually straight aluminum, but to make our robot look nice we have custom stickers made with our sponsors right on them. its not too heavy and you can do whatever design you want.
Unread 28-03-2012, 23:34
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
We got a black powder coat on ours this year. It was our first time ever painting/not being bare aluminum. Powder coats took about a day. It looks pretty good now.
Name:	Screen Shot 2012-03-28 at 10.32.43 PM.png
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 29-03-2012, 02:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We sent our welded frames and welded pieces out to a local powder coating shop, and our smaller machined parts out to a local powder coating shop. We did spray paint a few parts that were manufactured late. Powder coat is certainly superior over paint.
Unread 28-03-2012, 20:42
Andrew Lawrence
Posts: n/a
256 had a custom paint job this year! And we mean custom. We painted to bot in around 30 minutes flat. Real paint. Check it out here: http://www.chiefdelphi.com/media/photos/37744?
