Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 28-03-2012, 21:36
thecakeisalie's Avatar
thecakeisalie thecakeisalie is offline
FRC #0293
thecakeisalie is an unknown quantity at this point
Netbeans setup issue
So, I figured I'd test java a bit and installed the netbeans + frc plugins.
The only problem is that when I try to create a new command/subsystem by doing right click -> new -> command.../subsystem..., it is not there! The only options are new java class, java package, and java interface. Any help on getting this working would be much appreciated.
I'm using netbeans 7.1.1, though i don't think its an issue, as the netbeans version they are using in the video tutorials are 7.0.1
