Go to Post They knew that the number of gracious, professional, make-your-grandmother-so-proud-she-will-puke moments of exemplary behavior by the teams would far outshine any minor mistakes or incidents of less-than-perfect decorum. - dlavery [more]
Unread 31-03-2012, 17:16
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Question?? The PD’s power input
Can I use TETRIX® 12-Volt Rechargeable NiMH Battery Pack to us with The FRC PD’s power input, instead of the regular battery so it is easier to bullied small Robot to teach the new team members?
TEAM 1946-Tamra
Unread 31-03-2012, 18:16
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
Team Role: Leadership
Rookie Year: 2012
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: Question?? The PD’s power input
Sounds like it would work.
No harm in trying, go ahead.
It obviously is not a legal source of power for actual FRC competitions, though. And it'll run out FAST.
Like, I'm talking a minute or two. MAYBE.
Unread 31-03-2012, 18:50
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
should work OK. but even just the control system will drain the tetrix battery quickly. I think our control system last year drew something like 3.5 amps.
Unread 31-03-2012, 19:07
Clark Pappas's Avatar
Clark Pappas Clark Pappas is offline
Team Captain
FRC #4068
Rookie Year: 2010
Clark Pappas is an unknown quantity at this point
Correct me if I am wrong, but what I am gathering is that you want to build (a) small practice frame(s) to familiarize students with the build and design process. If that's the case, It may be better to use the full size battery so students will realize how little room they may have to work with for placing electronics and routing wire.
My $0.02
(Wth 4068)
2012 Colorado Rookie Inspiration award
(With 973)
2011 FRC Championship Winner
2011 Galileo Division Winner
2011 Long Beach Motorola Quality Award
2011 San Diego Industrial Design Award
2010 Las Vegas Finalist
Unread 31-03-2012, 21:16
DonRotolo's Avatar
Back to humble
FRC #0832
On one hand, 12 volts is 12 volts. Go ahead for practice.
But as Hawiian Cadder mentioned, that tiny Vex battery won't last long.
Unread 31-03-2012, 21:29
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
We have a desktop system, controls, small motors attached, etc that we use for training.
We power it off of a ham radio 12V supply. Never runs out of power.
Ed
Ed Barker
Unread 01-04-2012, 16:32
yara92's Avatar
AKA: Mohamed
Originally Posted by Clark Pappas View Post
Correct me if I am wrong, but what I am gathering is that you want to build (a) (s) to familiarize students with the build and design process. If that's the case, It may be better to use the full size battery so students will realize how little room they may have to work with for placing electronics and routing wire.
My $0.02
You see I bulid at home for small practice frame with 6 kg battery it is not for my age.
TEAM 1946-Tamra
Unread 10-04-2012, 09:25
yara92's Avatar
AKA: Mohamed
Sorry it dosent work the fuse cutout in a secand
TEAM 1946-Tamra
Unread 10-04-2012, 10:23
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
What other parts did you put on the robot? Does it have motors, speed controllers, cRio, ???
Unread 10-04-2012, 14:38
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
We have a small footprint practice bot with cRIO and 4-wheel CIM motor drive interchangeable with regular or mecanum wheels. We use this battery:
http://www.all-battery.com/rectangul...ightrobot.aspx
It works great. When we add more attachments and motors to the practice bot (e.g. the shooter wheels for this season), we hooked up the regular big lead-acid battery. A picture of our practice bot with the NiMH battery can be found here:
http://www.chiefdelphi.com/forums/at...7&d=1326270647
Unread 10-04-2012, 20:52
AKA: Isaak
Team Role: CAD
That battery is 10 amp/hours, as opposed to the 17 or 18 amp/hour rating for the FRC leagal battery. Does anyone have any experience using larger batteries with the FRC system? I was thinking that a 40amp/hour marine battery would be excellent for full day demo's and parades.
Unread 10-04-2012, 21:16
DonRotolo's Avatar
Back to humble
FRC #0832
What exactly are you powering from it? That battery isn't good for more than several Amps continuous.
Perhaps a slightly larger 12 volt battery, something around 5-8 Ah? A 5 Ah battery can supply about 10 Amps for several minutes, and 40 Amps for maybe a minute. Remember that a CIM motor can easily draw 40A, so consider what you are putting on the test robot carefully.
Unread 11-04-2012, 09:05
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Isaak,
A larger battery would/should work fine. One of the sealed, no maintenance batteries is the best choice. However, most of the components in the electrical system are chosen for their ratings based on intermittent duty, i.e. two minute matches. With the derating that was chosen during design, the PD and other components ought to be able to demo most of the day without problems IF cool down periods are religiously scheduled throughout the day. Often teams who take time to change out a battery will give a cool down during the change. Please remember that heat rise in wiring, motors and motor controllers are the most significant problems. These are made worse if the robot is in the sun, in hot weather or both.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 11-04-2012, 13:05
yara92's Avatar
AKA: Mohamed
http://www.chiefdelphi.com/forums/at...d=13341638 06
TEAM 1946-Tamra
  #15   Spotlight this post!
Unread 11-04-2012, 14:25
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
The cRIO and the blue plastic pieces (DSC, PD, etc) are all rated for continuous duty: We've kept systems running for weeks (months?) with external power supplies without issues.
The cRIO is rated for continuous duty at -20C to +55C: I hope you aren't making any students march in a parade outside of that range!
After the battery running out of juice, the next most likely failure point is the circuit breakers or motor controllers. If you have an inefficient drive train, they may trip once things have heated up. You may draw significantly more current on the parade surface than on the standard FRC carpet.
