Crio windriver programming problems
So I am a rookie coder trying to get code into our robot. Originally we were able to deploy and run code just fine onto our crio. Then all of a sudden one day we get comms but absolutely no code. I checked the system file within the crio folder and code is indeed being deployed, but the crio refuses to read it. I've already tried reimaging the crio, formatting then reimaging, using our spare crio, updating all utilities, using other computers as driver stations, deploying several different codes, checked the wiring, and pretty much done everything I could think of. If it helps on a side note I also cannot read voltage on the DS about the battery (meaning instead of reading something like 12.00V or even 0.00V we get an empty space about the communications). Any help would very much be appreciated!
P.S. extra details about what we did: try turning off and on the firewall of the deploying computer (no luck), toggle safe mode on/off (did nothing), redownload EVERYTHING (yes everything), the usual undeploy->deploy->reboot->turn on DS (didn't help), windriver deploy/undeploy and manual deploy/undeploy (using ftp).
