Go to Post *Teams. The competitors, who wear brightly colored shirts, scream like crazy, and bring robots. Without them, there would be no competition. - EricH [more]
Unread 06-04-2012, 02:15
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
Rookie Year: 2011
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Crazy robot idea for this year 2
the first idea was not circulated much but it was a 3 ball shooter on segway like chassis that could fit on the bridge with any two other robots and would flop over once power is cut.
how ever the second idea is
if you made a flying ball that had about an 18" diameter with bumpers on it that could do to things; fly to opponents end and sit in oppomnents 3 point basket, fly to bridge and hover while touching an alliance robot for 30 seconds and then fall and roll to the ground at the end of the match. http://www.atomicrobotics.com/2011/10/flying-ball/
would this be legal?
would this be a game changer?
I am looking at rules now. can't find rule that says you aren't allowed to be above the opponents fender or touching rims. they assumed this would not be possible with the 14" arm and 60" height limit.
Plus I haven't seen anything about what is considered a balance if after game play your robot falls off bridge.
‎1 battery (or super capcitor if allowed to replace) 1 CIM, 3 small control motors froma quad copter rig, 1 victor, 1 quad copter control board (unless CRIO has to be used), 1 wirless controller, 1 circuit breaker, 1 light, 1 wireless adpter and walla you have a single rotor helicopter self contained that just has to fly for 1 minute with that weight
If CRIO has to be used does the crio have to be on the robot? can it be on the control board and connect to a secondary wireless RC like control system?
Specifically i would be looking for anyway to offload weight from the required "large FRC" components.
Just a thought. Good night
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 06-04-2012, 02:30
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Crazy robot idea for this year 2
Fun ideas...however, they're fraught with peril.
For the first one, if it falls over while on the bridge, doesn't that risk unbalancing it due to the centre of gravity shifting? Check out the 5 second rule, [G37].
For the second, among many other potential issues, you will need to deal with having the battery, the cRIO and other heavy things onboard to be considered a robot. Also, how will you avoid unsafe operation?
Unread 06-04-2012, 02:34
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
Rookie Year: 2011
For the first one, if it falls over while on the bridge, doesn't that risk unbalancing it due to the center of gravity shifting? Check out the 5 second rule, [G37].
Check out flying ball, no unsafe operation unless their is a control issue, in some ways no different than a ground based bot.
the 5 second rule. Doh.... then it would nee to land. as long as partner has flat spot with whole in it to land on we are good.
crazy engineer
helping team 1389
Unread 06-04-2012, 02:45
Rookie Year: 1999
In some ways no different, but different in one crucial respect: it's a lot harder to protect the scorer's table and the front row of spectators. A control issue on a regular robot rarely leads to a departure from the playing field; that's hard to guarantee on a flying robot. And because it's above the field barrier, disablement doesn't mitigate the threat nearly as well. (Plus, as determined by the required parts, it would have to weigh a minimum of around 20 lb—that's a lot of momentum to arrest.)
Unread 06-04-2012, 03:19
remulasce remulasce is offline
Rookie Year: 2007
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
This has been discussed. Flying is illegal because it is impossible to keep your bumpers in the bumper zone. Bumpers must be in the zone during normal operation, and if flying is normal, you need them there while flying.
In addition, no part of your robot may extend more than 60" off the ground- wait. Only when in contact with the other alliance's carpet. So you're good on that front.
EDIT: I stand corrected. The bumpers need only be in the Bumpers Zone while the robot is standing on a flat floor. See post below.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 06-04-2012, 03:35
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
That's not what the rule says...
[R29]
Bumpers must be located entirely within the Bumper Zone when the Robot is standing normally on a flat floor.
So it seems that a flying robot is completely legal, as long as it is deemed to be safe... good luck with that!
Does anyone else remember when TBA signatures actually worked?
Unread 06-04-2012, 03:59
Rookie Year: 2007
I stand corrected. The required battery + crio, combined with the limited set of motors, are more than enough to make this impossible in my view, but if you can do it, I think the "safety" rule is the only thing standing in your way. Which would also be near-impossible to satisfy, but you may try as you like.
Google SWE: 2015-
Unread 06-04-2012, 23:02
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
This years set of motors has one of the highest power densities I have seen in FIRST. If you ran all of the 550s (all 8) into a single gearbox (low reduction, high speed), and put a large prop on it, you could get some substantial lift.
Motor power breakdown:
-AndyMark motors (AM- 0912)> 180.83W * 2 = 361.66W (current is below limit)
-Banebots RS-550-120-------> 253.52W * 4 = 1014.08W **(slightly less due to current limits, at this power level, they draw 43.2 amps each)
-Fisher Price 00801-0673-----> 291.59W * 2 = 583.18W **(prob. not quite this high, this would require 54.76 amps per motor)
----> this comes out to 1958.92 Watts, theoretically. So, How much would that be able to lift? (more specifically, how much would that be able to lift using a propeller?)
Unread 07-04-2012, 00:59
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
It depends on the prop, and the air density. Quite possibly even the specific prop. The one overarching question which won't be answered by motor power is prop thrust--motor power is good for getting that thrust, but can't be precisely correlated without some testing. A 27x13 is quite a hefty prop, even for a hefty motor like an FP.
And I've seen a case where the same prop tested at two different thrust levels in two different locations. Not fun trying to figure out why...I suspect it had something to do with either the air density or a mounting change, or both.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 07-04-2012, 12:48
AKA: Alan Wells
FRC #1350 (Rambots)
Well, air density at FIRST venues, which are often climate controlled and at fixed altitudes, shouldn't be too hard to calculate, plus the mounting won't change as long as it is on the robot. Additionally, the same website also sells 26, 24, 22, 21, 20.5, and 20 inch props in varying pitches.
Does anyone have performance data from 2009 for similarly sized propellers?
Unread 08-04-2012, 18:41
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Don't get caught up in the details with props and their inefficiencies, sizes, etc. Do the broadest, most basic calculation possible to check and see if it is within the realm of feasibility.
If we take a minimum robot mass (25lbs) and use the entire cross sectional area of the robot envelop, 28inX38in we find that we will need to generate approximately 0.0235psi (162Pa) of dynamic pressure just to 'hover' in free air, ignoring ground effects.
Pdynamic = ( fluid density * fluid velocity^2)/2
fluid density = 1.18kg/m^2 (~STP)
Pdynamic = 162Pa
Fluid Velocity => 16.9m/s
Total air flow rate is 28in*38in*16.9m/s = 11.6m^3/s
In a basic sense we need enough power to accelerate 11.6m^3 of air to 16.9m/s in 1s. This can be simplified to a basic energy problem:
Air mass = 11.6m^3*1.18kg/m^3 = 13.7kg
air velocity = 16.9m/s
Air's kinetic energy = 1/2*mass*velocity^2 = 1950Joules
Time available to apply this energy = 1s
Total power required by this method = 1950J/1s = 1950W to maintain hover, including no inefficiencies.
This is about what PAR_WIG1350 figured that eight motors, drawing well over 280A, could produce.
It is technically unfeasible with our legal battery. It is technically unfeasible with our required main breaker. Even if these barriers were removed, the motors would not last long at peak power.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 06-04-2012, 09:06
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Well, I think that the things that make this illegal to be:
[R01-2]
The Frame Perimeter of a Robot is defined by the outer-most set of exterior vertices on the Robot that are within the Bumper Zone, which is between 2 and 10 in. from the floor.
^Even if you were able to get flying, you're still restricted to an air ceiling ~10" above the ground.
[R08]
Robot parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other Robots.
Read it as you will.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 06-04-2012, 13:19
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
A giant Helium balloon would off set the weight. Is that legal?
Unread 06-04-2012, 13:35
Rookie Year: 1999
No it wouldn't. It would add both weight and buoyancy. The specification restricts robots on the basis of weight only.
The helium itself would be legal, unless in a hazardous state.
  #15   Spotlight this post!
Unread 06-04-2012, 13:39
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Can you fit it in the maximum size?
For something as heavy as a typical FRC robot, the required helium-carrying device will most likely have a hard time fitting in the field, if not the venue. Trust me on this. For something like a 18" sphere, with bumpers and battery, you could probably fit said helium-carrying device into the field if you didn't max-weight the robot. However, maneuverability would be highly limited due to rules about leaving the field boundary.
Past teams:
