Go to Post Sometimes, you just have to beat something (someone?) into submission. Yes, you can use your head, but its a lot easier with a hammer. - Andy A. [more]
Unread 06-04-2012, 20:56
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: Andymark Plaction wheels vs IFI wheels
colsons are another option and are much more durable than ifi/andymark plaction wheels.
Unread 07-04-2012, 10:40
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
While I understand the thread is AM Plaction vs. IFI Wheels, for a dead axle wheel, I can not recommend Colson Performa wheels enough. I may sound like a broken record by now but... We have run them for the last two seasons and I don't intend to use any other wheel again unless absolutely mandatory. The cost to go to a Colson wheel is less than an AM or IFI, the hubs are available through West Cost Products.
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 21-04-2012, 00:17
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
How are AM performance wheels compared to IFI wheels?
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-04-2012, 00:20
Andrew Lawrence
Posts: n/a
Although they are called "performance" wheels, they generally have the same advantages/disadvantages of plaction wheels. Though they can be used easier in a live axle setup than plaction/iFI wheels.
Unread 21-04-2012, 01:28
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
The performance wheels have noticeably more grip, partly due to lack of a draft from the molding that occurs in plasticon wheel manufacture, but also because the aluminum rim is not as large, and contacts the floor less than the plasticon retaining ring. I would go with performance wheels any day, as long as you keep to the 4 and 6 inch sizes they are not that much heavier or more expensive.
Unread 21-04-2012, 21:15
Gregor's Avatar
Rookie Year: 2012
So would plaction wheels or IFI wheels combined with blue nitrile tread be an ideal combination?
<Since 2011
Unread 21-04-2012, 21:24
Andrew Lawrence
Posts: n/a
Really? That's pretty cool. Didn't know that. Thanks!
Depends on how you use them. The wider the wheel, the harder it is to turn. With blue nitrile you have a lot of grip on the carpet, meaning a lot of turning scrub when you try and turn. So unless you're really experienced with them, you may find trouble turning with blue nitrile and wider IFI wheels, compared to the thinner plaction/performance wheels.
I've never had experience with the 1" width IFI wheels, so I can't say anything about them, but I've had experience with both wider ones, and plactions.
Unread 21-04-2012, 21:26
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Originally Posted by Chris Fultz View Post
If you do some testing you should see no difference between 1" and 2" wide. You are providing a bigger area but with the same total downward force (weight of robot) spreading over that larger area you don't gain. Traction is a tricky thing and some controlled tests can be cool.
To the op, we have used and had good success with all. We are using the am 4" performance wheels right now with blue tread from mcmaster. It is a little gripper than am or IFI tread but only comes in wide sizes so it has to be cut (I think 3" is the narrowest)
While this is true, I have heard that the 2 in thick wheels wear better.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
