Go to Post We've done that autonomous. After several years of refinement we decided to skip the information collection and just drive into the wall at the earliest opportunity. - Greg Young [more]
Unread 15-10-2012, 23:53
Quix's Avatar
Quix Quix is offline
AKA: Jeremy
FRC #0604 (Quixilver)
Team Role: Student
Quix will become famous soon enoughQuix will become famous soon enough
Re: CalGames 2012: Info
Team 604 has all the videos saved, they will be upload to our website in a matter of days. Just hang tight.
Unread 15-10-2012, 23:57
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
Rookie Year: 2007
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
As an alumni, it's always great going back to CalGames, helping out my team, and enjoying the competition. As always, Woodside put on a great event, and a huge thank you to them.
On a side note, would anyone from 254 mind clarifying what happened during F1? From what we were told, a CIM was blown, but I'd be really interested in knowing the circumstances around this.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 16-10-2012, 12:59
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
From what I saw on the field, 254 lost the tread on one of their wheels and had to replace it. Im fairly sure no one on the winning alliance burned out a motor durring the finals. Correct me if I'm wrong.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 16-10-2012, 18:07
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Are you referring to the smoking smell? I believe that was a piece of material on 1678's intake roller that was rubbing elsewhere on their robot, causing it to burn/smell.
254's robot had a disconnected pneumatic tube which caused some pneumatic components to only partially work. It was reconnected between matches and was fine for F2.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 16-10-2012, 18:17
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Any smoke smell in the finials came from us, like you said. There were some problems in our intake system causing excessive friction leading to two of our 550's getting quite hot and smoky, but not fully blown.
Unread 16-10-2012, 21:23
hionwind's Avatar
hionwind hionwind is offline
Lead Mentor
AKA: Steve Harvey
hionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant future
Actually, the burning smell was coming from the motor(s) for our "sweeper" that carries the balls from the intake area up to the shooter wheel. The roller had jammed causing the motors to overheat. That is why we were unable to shoot in the first final match and why we called the time out. We un-jammed the roller and did a systems check which showed the motors to be running but, unfortunately, in the second final match the problem recurred and we were unable to shoot again.
Lead Mentor - Team 1678 (2005-Present)
2013 Curie Division Champions (with 148 and 862)
2014 Newton Division Champions (with 1114, 1640 and 5136)
2015 World Champions (with 118, 1671 and 5012)
2016 Hopper Division Champions (with 148, 364 and 2990)
Unread 17-10-2012, 00:42
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
Thanks for clearing that up. There must have been some miscommunication/misunderstanding. This makes much more sense than the impression I was under.
Unread 18-10-2012, 14:36
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Check out some pictures that Craig Zarmer took at CalGames 2012
http://www.zarmer2.com/pix/CalGames%202012/index.php
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 09-04-2012, 22:39
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Rookie Year: 2007
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Just throwing this out as an idea. Any chance that the eliminations could be run like 12 alliances with 4 getting byes? (similar to NFL playoff system)
Just a new idea that I thought could be interesting.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 09-04-2012, 23:33
Andrew Lawrence
Posts: n/a
YAY! Cal Games! Always my favorite part of each new school year, and the perfect time to train the newbies.
Unlike most off-seasons, Cal Games doesn't usually have rule-changes. I think this year it would be fun to have some rule-changes, TBD later, though ideas could be spread around now.
This is Woodside's second time hosting Cal Games. Interesting.
Unread 10-04-2012, 00:23
Rookie Year: 2007
I really like the time of Cal Games, in that lull between the beginning of school and the start of build season.
Unread 10-04-2012, 00:33
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
I'm pretty sure they've done this quite a few times, this isnt just their second time.
Thanks Team 100 for hosting again! 846 looks forward to this awesome event!
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 10-04-2012, 12:22
Andrew Lawrence
Posts: n/a
Really? I know 2009, and now.
Unread 10-04-2012, 14:17
Chinmay's Avatar
I think this is how it went... (someone correct me if im wrong, pre 2006 is fuzzy , and i couldn't find anything for pre 2002 )
02 game was played at pioneer (668)
03 game was played at woodside (100)
04 game was played at woodside (100)
05 didn't happen
06 game was played at pioneer (668)
07 game was played at woodside (100)
08 game was played at mitty (1351)
09 game was played at woodside (100)
10 game was played at lynbrook (846)
11 game was at mitty (1351)
12 game will be at woodside (100)
  #15   Spotlight this post!
Unread 10-04-2012, 17:32
Rookie Year: 2007
Considering I missed the 2010 Cal Games because of SAT's, I've only seen it at Mitty and Woodside and man they were all excellent competitions!
Side note: anyone got any opinions on the elimination suggestion I posted at the top? Wondering if I have any support or If maybe others think it's not such a good idea.
