Go to Post We would expect our bot to be done by Week 5, but usually its about a day or two before shipping and then the ever-famous "all nite programmin' n driva trainin'" is done. - Bharat Nain [more]
Unread 10-04-2012, 16:07
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Camera Feed Help
So I am trying to use a custom dashboard that I have made. The problem is that everytime I run the code and open up the custom DB I get no camera feed. Although When I run the robot with the stock DB I am able to get a video feed. Basicaly what I am trying to accomplish here is to make use of some tracking code that I wrote within the custom DB. Also just to double check, I am using port 1140 to send information to the DB from robot, and port 1130 to send information to the robot from the DB. Is this correct? Thank you in advance.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
Unread 21-04-2012, 23:45
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
Rookie Year: 2011
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Re: Camera Feed Help
The UDP ports are correct. Is the camera wired to the bridge or the 2nd port on an 8 slot cRIO? And what are you using the UDP to tranfer?
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
