Hi there I am new to Pro E and I looked through the 2011_FTC_KOP files and found everything but the 416mm channel. I am not sure if they made a mistake with not including it because it seems to be a standard part. Has anyone run into this problem or created their own part? Thanks for any help
Re: FTC CAD Part Help
I don't see 416mm channel in the Kit of Parts. If you need a model, I can send you one. You can make it yourself using hole patterns. Or, if you haven't used hole patterns yet, you can assemble it from two 288mm models. Cut one 13 holes long (use a cutting extrusion to remove the excess) and the other 12 holes long. Then assemble the two end to end.
Not sure why that was not included but I have attached one I created by editing one of the shorter channels. It's easy when they are parametric
