Go to Post If the refs are not calling something that you think should be called, you have to adjust your play style to deal with it. - Rob [more]
Unread 13-04-2012, 21:49
TacticalLuke67 TacticalLuke67 is offline
FRC #0067 (Heroes of Tomorrow)
Rookie Year: 2010
TacticalLuke67 is an unknown quantity at this point
Hybrid/Autonomous Buzzer Shots
I had a question for all of you out there regarding the point values for "buzzer" hybrid shots. What i'm referring to is when a ball that is shot while in hybrid mode does not reach the scoring ticker under the net until after the 15 seconds are up. Being that we like to shoot an extra two balls off of the co-op bridge, this is a problem we come across pretty often. What has the ruling for this been at other events? Does it stand at 3 points or is it adjusted to the full 6 points?
Unread 13-04-2012, 21:51
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: Hybrid/Autonomous Buzzer Shots
The rules say that it must pass through the hoop during the hybrid period - it does not matter when it was shot or when it passes the sensor. I have seen a couple instances of points being added after the fact.
Does anyone else remember when TBA signatures actually worked?
Unread 13-04-2012, 21:52
jyh947's Avatar
jyh947 jyh947 is offline
FRC #3322 (Eagle Imperium)
Team Role: Leadership
Rookie Year: 2010
jyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to behold
Directly from Q&A:
Q. If a robot releases a ball prior to the timer hitting zero during the hybrid period, but it completely passes through the top hoop after the timer hits zero, will this ball be worth 3 or 6 points. What is the determining factor? Time of: release, passing through the hoop, passing by the sensors? FRC1114 2012-02-29
A. Per Rule [G38], the Basketballs are scored as they pass through the Hoop. So, if a Basketball shot during the Hybrid Period passes through the Hoop before the Hybrid Period ends, it will earn the Hybrid bonus of Rule [G39]. If it passes through the Hoop after Hybrid Period ends, it will not earn the Hybrid bonus.
Eagle Emporium: We sell eagle-related products at 50% off!
2012 Rebound Rumble (Elset)
Website Award, Industrial Design Award, Regional Finalist - Kettering District
Website Award, Imagery Award, Regional Winner - Livonia District
2011 Logomotion (Cuddles)
Imagery Award - Ann Arbor District
2010 Breakaway (Seizure)
Rookie All Star Award, Highest Rookie Seed - Ann Arbor District
Rookie All Star Award - Troy District
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Rule check time!
Originally Posted by G38
[G38]
Alliances will be immediately awarded points for each Basketball that passes completely through their Hoops
Originally Posted by G39
[G39]
During Hybrid, an additional 3 point bonus will be added for each Basketball that passes completely through any Hoop.
From Q&A:
Throughout the season, if a ball enters the hoop (it doesn't matter when it triggers the sensor) during the hybrid period, it will receive the hybrid bonus. If the automated scoring can't to this, the referees have added in the extra points manually.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 13-04-2012, 21:54
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
But that addition has been made if balls get jammed in the net and should pass through in hybrid but don't until the volunteer dislodges them in teleop. I was watching 67's matches today and the calls on the shots where absolutely right, a lot of the time, the coop balls were scored in teleop but were shot in hybrid which is 3 points per ball.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 13-04-2012, 21:56
Rookie Year: 2010
Thanks for all the rules guys! guess i didn't look hard in the right places for official ruling. May be worth having a short talk with some of the MSC judges in the morning, i believe some teams may be being shorted.
Unread 13-04-2012, 22:02
FRC #0840 (ART)
Umm... what? For one thing, I'm pretty sure it's impossible for a ball to get stuck without passing through the hoop (which is not the same thing as the net!). And it doesn't matter when they were shot, but if they passed through the hoop during hybrid, it should be 4-6 points no matter when they were scored.
Unread 13-04-2012, 22:14
jblay's Avatar
AKA: Joe Blay
Team Role: Coach
That is exactly what I am saying. The ball is counted as 3 points when it passes through the sensor in teleop but it goes through the hoop in hybrid which is why the addition is made.
Unread 13-04-2012, 22:22
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Luke,
We (drive team) may have a short discussion with the head ref tomorrow morning, after reading through the rule quoted above.
I doubt that anything gets changed for this weekend, but atleast we can have an open discussion about it.
-Adam
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 13-04-2012, 22:48
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The refs were told to not manually adjust the scores. There is supposed to be a delay in the software that counts the balls as scored in hybrid even after it has ended.
I noticed a lot of times today that this wasn't happening in Michigan. I suggest checking with the FTA as well as the head ref.
Unread 13-04-2012, 23:29
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Not correctly scoring "late hybrid shots" was also a feature of the North Carolina Regional last weekend. We never spoke to the head referee about it, but our team and a couple others also shot balls right near the end of the hybrid which often passed through the hoop during hybrid, but were scored as 3-pointers by the automatic scoring system when the balls did not pass through the sensors until after teleop had started.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
